Yea, I ran my water pump with the kitchen faucet open to make sure the fresh water tank was dry (I previously had drained the tank so it was surprising to see the amount of water still in the tank). I blow out the lines prior activating the water heater bypass. That expells additional water in the line through the open water heater drain. Then I activate the bypass and continue to blow out the line. That blows a little more out. Finally after blowing out the lines, opening every faucet, toilet, sprayers on the toilet and sink, I open the low water petcocks and close up the faucets. Once that stops its anti-freeze time.
And for the umteeth time I forget to close the petcocks and after a half of bottle of pumped anti-freeze I realize its pouring out the low water drains.
Jack
