10-11-2003, 06:08 PM
Profile:
1992 29' Excella
madison
, Wisconsin
getting ready for the freeze
that time of year again.
this time i added a little gadget to make adding antifreeze a little easier.
just a little three way valve....
i'll go through all the steps of winterizing for newcomers to cold climate airstreaming.
here are the supplies.....
john
you call them ferrets, i call them weasels.
10-11-2003, 06:10 PM
Profile:
1992 29' Excella
madison
, Wisconsin
my existing pump setup
in the bottom of my closet
10-11-2003, 06:13 PM
Profile:
1992 29' Excella
madison
, Wisconsin
make sure the valve...
is the right size and faces the proper direction.
otherwise you will not be able to draw antifreeze into the system.
10-11-2003, 06:16 PM
Profile:
1992 29' Excella
madison
, Wisconsin
installed
here is what it looks like installed...
i used teflon tape on the threads, although not needed because of rubber o rings in the connections.
i used it anyway because of the plastic to brass connections.
10-11-2003, 06:18 PM
Profile:
1992 29' Excella
madison
, Wisconsin
then i drained
the water heater
10-11-2003, 06:19 PM
Profile:
1992 29' Excella
madison
, Wisconsin
then bypassed the heater
showing valves....
10-11-2003, 06:22 PM
Profile:
1992 29' Excella
madison
, Wisconsin
low point drains
then i opened the two low point drains, one for hot one for cold.
not my wiring by the way....
factory original job!
10-11-2003, 06:24 PM
Profile:
1992 29' Excella
madison
, Wisconsin
time for air
my home made adaptor, run at 60 psi.
10-11-2003, 06:28 PM
Profile:
1992 29' Excella
madison
, Wisconsin
at this point...
i go around and open all the faucets and blow the water out.
after i am sure the system is purged, i shut off the air and close all valves and drains.
then i start the pump and again go around opening all the faucets and low point drains. not forgetting the shower wand and the hand spray on the toilet!
10-11-2003, 06:32 PM
Profile:
1992 29' Excella
madison
, Wisconsin
don't forget the drains!
after the entire system has been filled with rv antifreeze i add a couple of gallons to all the drain traps.
i also wipe up any excess in the shower or sinks to prevent staining or collecting dust.
don't forget your outside faucet if you have one!
10-11-2003, 06:42 PM
Profile:
1992 29' Excella
madison
, Wisconsin
that's about it, when finished i put the diverter valve to "normal" position, cap the opening, remove the hose and store in a zip loc baggie.
also i add a little antifreeze to the water strainer, there always seems to be a little sitting in there. the air cannot reach it because it is on the suction side of the pump.
also, the water filter element goes in a baggie too, stored in the house.
john
miller time!
10-11-2003, 06:54 PM
Profile:
Another excellent class!!
John,
Nice job! Since I've never had the need to winterize my trailer, I'll book mark this for future ref.
Mac
p.s. How many "Miller's" did it take to complete this job????
10-11-2003, 07:02 PM
Aluminut
Profile:
2004 25' Safari
Northern Suburbs
Noticed the High Life made another cameo!
Nicely done!
Eric
10-11-2003, 07:19 PM
Profile:
1992 29' Excella
madison
, Wisconsin
Thread
Thread Starter
Forum
Replies
Last Post
IPOD ready
mandolindave
Off Topic Forum
48
04-26-2004 08:08 AM
Dirt Road Ready
Janet's Husband
General Repair Forum
3
01-31-2004 07:16 PM
Get Ready to Chat ! !
flyfshr
On The Road...
8
07-31-2003 08:24 PM
