Old 10-11-2003, 05:08 PM   #1
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
Cool Getting ready for the freeze-Winterize
that time of year again.
this time i added a little gadget to make adding antifreeze a little easier.
just a little three way valve....
i'll go through all the steps of winterizing for newcomers to cold climate airstreaming.
here are the supplies.....
john
you call them ferrets, i call them weasels.
Old 10-11-2003, 05:10 PM   #2
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
my existing pump setup
in the bottom of my closet
Name:	pump as is.jpg
Old 10-11-2003, 05:13 PM   #3
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
make sure the valve...
is the right size and faces the proper direction.
otherwise you will not be able to draw antifreeze into the system.
Old 10-11-2003, 05:16 PM   #4
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
installed
here is what it looks like installed...
i used teflon tape on the threads, although not needed because of rubber o rings in the connections.
i used it anyway because of the plastic to brass connections.
Name:	diverter working.jpg
Old 10-11-2003, 05:18 PM   #5
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
then i drained
the water heater
Name:	heater draining.jpg
Old 10-11-2003, 05:19 PM   #6
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
then bypassed the heater
showing valves....
Name:	heater bypass.jpg
Old 10-11-2003, 05:22 PM   #7
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
low point drains
then i opened the two low point drains, one for hot one for cold.
not my wiring by the way.... factory original job!
Name:	low point drains.jpg
Old 10-11-2003, 05:24 PM   #8
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
time for air
my home made adaptor, run at 60 psi.
Name:	air adaptor.jpg
Old 10-11-2003, 05:28 PM   #9
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
at this point...
i go around and open all the faucets and blow the water out.
after i am sure the system is purged, i shut off the air and close all valves and drains.
then i start the pump and again go around opening all the faucets and low point drains. not forgetting the shower wand and the hand spray on the toilet!
Old 10-11-2003, 05:32 PM   #10
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
don't forget the drains!
after the entire system has been filled with rv antifreeze i add a couple of gallons to all the drain traps.
i also wipe up any excess in the shower or sinks to prevent staining or collecting dust.
don't forget your outside faucet if you have one!
Name:	don't forget outside faucet.jpg
Old 10-11-2003, 05:42 PM   #11
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
that's about it, when finished i put the diverter valve to "normal" position, cap the opening, remove the hose and store in a zip loc baggie.
also i add a little antifreeze to the water strainer, there always seems to be a little sitting in there. the air cannot reach it because it is on the suction side of the pump.
also, the water filter element goes in a baggie too, stored in the house.
john
miller time!
Old 10-11-2003, 05:54 PM   #12
Thumbs up Another excellent class!!
John,
Nice job! Since I've never had the need to winterize my trailer, I'll book mark this for future ref.
Mac
p.s. How many "Miller's" did it take to complete this job????
John is offline   Reply With Quote
Old 10-11-2003, 06:02 PM   #13
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
Frozen Tundra , Illinois
Noticed the High Life made another cameo!
Nicely done!
Eric
Old 10-11-2003, 06:19 PM   #14
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
three!
john
winterize
Getting Road Ready Devoman Our Community 0 10-27-2011 08:32 AM
Hindenburger Ready to Roll Nashville Wheels, Hubs & Bearings 2 09-02-2011 04:55 AM
Winterize For One Night? jambie Winterizing, Storage, Carports & Covers 15 03-22-2011 09:33 PM
Heavy Freeze / burst Pipes / New WH and Pump? robwok Water Heaters, Filters & Pumps 5 03-03-2011 09:06 AM
Ready To Begin Tear Down To Frame.?.?! Althea68 Repairing/Replacing Floor &/or Frame 11 01-26-2011 04:28 PM
