Old 10-17-2011, 03:26 PM   #211
Westfalia's Avatar
2008 27' International CCD FB
Boerne, TX / , Evergreen, CO
Images: 35
Send a message via AIM to Westfalia Send a message via Skype™ to Westfalia
Originally Posted by Gosman
Question will this hurt my hot water tank now or later , what should i do naything?
No problem, but you will probably want to flush it out good come spring, if only to get rid of the taste. I would go ahead and drain the tank to keep it from freezing as the anti-freeze is diluted and will probably still freeze if it gets cold enough.
Chris and Christina- Boerne, TX / Evergreen, CO - TAC TX-7
2008 27'FB Int'l Signature CCD
Westfalia is offline   Reply With Quote
Old 10-17-2011, 05:09 PM   #212
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Some say the antifreeze tastes bad, others say it doesn't. Some say it depends what antifreeze you buy—cheap stuff tastes bad. If you regularly drink out of the hot water faucet, I guess it matters how the stuff in the hot water tank tastes.
Somewhere it says (either Atwood instructions or Airstream manual) some water at the bottom of the tank is ok. The problem with frozen water is that it expands 11% and that is what breaks things. A gallon of water in a 6 gallon tank isn't going to expand enough to worry about. But sediment does collect in the bottom and flushing it out periodically is a good idea. Leave a cup or too of antifreeze in the fresh water, grey and black tanks to keep the valves lubricated and displace some of the water that is probably left there.
George, you could run those 2 gallons in the water heater (change the valves again) through the hot water pipes and recover it at a faucet. If it is diluted a lot, you'll know there was water in the tank and throw it away. Otherwise, you could save it (or drink it and see how it tastes; it might look good in one of those umbrella drinks).
I have never tasted the antifreeze. Why? Because we sanitize the system in the spring with chlorine and then flush it 3 times.
Gene
Old 10-18-2011, 05:11 AM   #213
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Originally Posted by Gosman View Post
I have done as was told --except i did get around 2 gal anti freeze in the hot water tank !!! Just forgot to shut the valves to by pass .
Thanks george
George,
No problem at all.
I leave our drain plug,(plastic), out for storage, stuff a scotch brite pad in the hole to keep the critters out.
In Spring I back flush thru the drain, keeps the crud from building up inside the tank.
PFC
"Tahawus"
but I’m the Husband, so we went to Cleveland. 😂
RLC
“It’s a crooked piece of time that we live in….”
John Prine
Old 10-18-2011, 07:46 AM   #214
1993 25' Excella
Scenic , Arizona
I am New to the air stream foram ,
I have a 1993 30 ft excell 1000
and in the closet do see the pump and it all ready has the valve...
to draw antifreeze all I have to do is put it in the position it in the right direction to draw antifreeze.
QUESTIONS IN THIS AIR STREAM
Not sure were to find the the two low point drains, one for hot one for cold to open and let drain?.
All so the pump is in the closet and acroos the hall in the bathroom is were the hot water heater is located.
Not sure were to find the bypass valves so as not to run antifreeze in the water heater, does any one know were they might be located?
On out side I do see were I have to unscreew what looks like a nut to let the water out of the heater . Could some one please help with the few questions I have .
Thanks all
Hello Gosman,
I am no expert , but ,I found my low point drains behind the wheel on the "driver's side" just a little in front of the fresh water tank drain .
If you physically locate the hot water heater on the outside of your trailer "a vented door" then go inside to the same location . The water lines are probably in an "H" pattern, the two on the outsides of the "H" need to be closed , the center one on the "H" needs to be opened .
Draining the water heater is nothing more than using a 7/8" wrench to remove the white plastic nut in the lower left corner .
dieppe9 is offline   Reply With Quote
Old 10-18-2011, 11:19 AM   #215
mcintoshMD's Avatar
2012 20' Flying Cloud
Hopewell , Virginia
Hello out there,
I am getting ready to winterize my AS. The manual stated remove the battery and store it in the house/ charging them regularly. Question is, is it OK to keep the AS plugged into the house current? reading some where here that it might mess up the converter or inverter could not remember where the posts are??
mcintoshMD is offline   Reply With Quote
Old 10-19-2011, 08:55 AM   #216
Master of Universe
Gene's Avatar
Mac',
If you have a three stage converter, you can leave the batteries plugged in to shore power. If you have a one stage converter, don't. In recent years Airstream has installed a one stage converter to save a few bucks—it will overcharge the batteries and you will have to add water periodically. Check the materials that came with the converter to see what kind of charge function it has.
I don't think you have to remove the batteries so long as you keep them charged every month or so. If they are left to discharge, they can freeze, so to be extra safe, people bring them inside, but be careful of fumes inside when you charge them. You need a charger to keep the batteries charged that has a 3 stage system and they are available online or from auto parts stores. You could charge the batteries while in the trailer battery box, but I would disconnect the cables first. You can reconnect the cables when you are ready to take trailer for a ride.
If you have a solar system with a 3 stage charger, you can let that keep the batteries charged and don't plug in the shore power. That way you can leave the batteries where they are.
Batteries and their care can be a controversial topic and you may soon get completely different advice. The above has worked for us. I have replaced the OEM converter with a much better one with a 3 stage charger, so I now leave shore power on. I have a solar system which could do the same thing, but I have been advised the new converter has a slightly better charger.
Gene
Old 10-19-2011, 09:20 AM   #217
CanoeStream's Avatar
St. Cloud , Minnesota
Batteries will slowly lose charge all on their own. Batteries connected to your Airstream will experience some planned drain (LP detector) and other parasitic losses, therefore losing charge somewhat faster than if disconnected. A charged battery can't freeze. I'd probably plug our Safari in overnight once every couple weeks if I stored it at the house. However I store at a garage a few miles away and it is just easier for me to put the batteries in the basement and tend them here. I don't see any need to keep a 'stream in the driveway [with the master switch off] plugged in constantly.
Remember this ad? There's hardly a better way to take care of a battery than keep it cold!
5 meter Langford Nahanni
Old 10-19-2011, 11:11 AM   #218
mcintoshMD's Avatar
Hopewell , Virginia
Thanks guys you are the best, I am planning to remove the battery, unplug AS from the shore line and forget it until next spring.
There's is a recommendation from AS web site ,if the AS is connected to the shore line all the time one does not need to remove the battery
Old 10-19-2011, 05:55 PM   #219
50KIP's Avatar
2009 19' International
Woodinville , Washington
Gene,
I live in the Seattle area and our winters are mild considering how far north we are. I usually just drain the water and blow out the lines and put some antifreeze in drains. I have kept trailer connected to shore power to keep batteries charged. Reading your piece about how a single stage converter can overcharge batteries I decided to check all the cells of both batteries (Interstate OEM). I had checked periodically the cell I could reach without disconnecting cables and they were always fine. But sure enough, when I did check the other battery after removing the cables, it was a couple of quarts down! I looked for my converter info and the only thing I could find was in French and it was not for the converter that I had, which is a Parallax Power Supply LLC 55amp Model 7355. I could not find anything to indicate if it was a multi-stage converter so I assume it is as you suggest, a single stage. You mentioned that you switched yours to a three-stage. What brand and model did you install?
DonS
"It's like magic, only real"
(Bud Light commercial)
Women and cats can do as they please, while men and dogs should relax and get used to the idea.(R. Heinlein)
50KIP is offline   Reply With Quote
Old 10-19-2011, 06:52 PM   #220
Master of Universe
Gene's Avatar
Don, just having gotten back to the house after cutting firewood, my answer won't be complete. Lew (Lewster) recommended and ordered an Iota. I don't have the model number, but if you go to the Iota website you may find which model you need.
My OEM Parallax may have been the same as yours because that number sounds vaguely familiar.
I described the installation of the Iota on another thread, but I can't remember which one. If you have a black cover plate over the converter and fuse and breaker panel, you have to remove it and the converter will be behind it. You have to cut the front of the converter
off because it has the screw holes for the cover plate and in turn, that part screws to the partition, wall or wherever yours is located. This destroys the Parallax. The hot and common wire that are attached to the Parallax can be cut after you remove the fan at the back and that will give you more wire to work with. All the grounds that are connected can be attached with split bolt connectors. It is not too hard to trace which wires go where if you are familiar with electrical circuits (black or red: hot; white: common; green or bare, ground).
Lew, the Forum's resident expert on many things RV, says the Iota and AGM batteries are a good combination. He likes Lifeline brand; they are expensive but are supposed to last far longer that the wet cells. Our trailer came with series 24 batteries, but I got series 27 to fit by cutting one lip back (on the hinge side) on the battery box.
After unsuccessfully trying a grinding wheel on a drill, I used a Sawzall with a carbide tipped blade to cut the metal.
Gene
Old 10-19-2011, 08:05 PM   #221
Yes, lewster is way cool -- and I regularly communicate back-channel with him, asking him to look in and comment. We'll really know we're on the right track for battery maintenance should bryanl look in and comment here.
Full-time plugging in is not necessary. Plug the Airstream in once every other week (even for northern climes) -- as long as your coach's electric master switch is turned off.
If you pull the batteries, store them in the house & put them on a charger or battery minder every 3-4 weeks. Storing batteries on a concrete slab does not degrade them at all.
Never have had problems with the OEM deep cycle Interstates installed by JC. I could tell that one wasn't holding a charge well at the 4 1/2 year age point. I replaced both with the exact same batteries at 5 years. Keep pairs of batteries closely matched for manufacturer, model & age.
Old 10-20-2011, 01:46 PM   #222
50KIP's Avatar
Gene and Bob,
I was hoping this AS thing was going to be simple! All this talk reminds me of my Chesapeake days when I had a boat (definition: a hole in the water to pour money into). When you talk "sawzall" it tends to scare me away (although I own two). I think I will stick with using shore power, but with the battery switch in the "store" position and turning it on every couple of months. I plan on going to Arizona after Christmas to avoid our mild but retched Seattle winter. Thank for all the info and I will probably readdress the electrical situation when I go solar. Any suggestions for my 19-footer? There is not much room on top.
DonS
Old 10-20-2011, 02:00 PM   #223
Master of Universe
Gene's Avatar
Yes Don, always have buckets of money with you when you buy an RV or a boat. You can use it for insulation too.
Lewster recommends AM Solar. They are in Oregon, so they are not that far from you. The panels get smaller and the watts get higher as the technology improves, so there may be plenty of space on your 19' roof. The AM Solar controller has a 3 stage charger and you can let the solar charge the batteries all the time you are parked leaving the shore power unplugged and replace the converter some other time.
The Sawzall may not have to be plugged in for a while. I understand the reluctance to use it since it has something of a brute force feel to it, but it is good for nasty jobs.
Gene
Old 10-20-2011, 02:02 PM   #224
50KIP's Avatar
Bob,
Fellow Minnesotan. My mother-in-law worked for the City of International Falls and I remember her talking about that Die-Hard commercial. It was legit and everyone was surprised that the car actually started in the Spring. Automotive companies like to make commercials in northern Minnesota in the winter.
DonS
winterizing
Getting Road Ready Devoman Our Community 0 10-27-2011 08:32 AM
Hindenburger Ready to Roll Nashville Wheels, Hubs & Bearings 2 09-02-2011 04:55 AM
Winterize For One Night? jambie Winterizing, Storage, Carports & Covers 15 03-22-2011 09:33 PM
Heavy Freeze / burst Pipes / New WH and Pump? robwok Water Heaters, Filters & Pumps 5 03-03-2011 09:06 AM
Ready To Begin Tear Down To Frame.?.?! Althea68 Repairing/Replacing Floor &/or Frame 11 01-26-2011 04:28 PM
