Old 10-23-2010, 06:16 AM   #155
adore's Avatar
1977 Argosy Minuet 6.0 Metre
Mont-Laurier , Québec
Device for blowing air in the pipes
Originally Posted by CrawfordGene View Post
If you don't want to make one, or can't find the parts, Camping World is selling something like what was' made. You still have to buy a proper fitting for your compressor for it.
Gene
Here is what I have, with a valve as for tires... sold at places such as Camping World, I suppose.
adore is offline   Reply With Quote
Old 11-05-2010, 11:22 AM   #156
1964 22' Safari
Albuquerque , New Mexico
Smile why
If you blow out all the water, why to you suck in RV anti freez.. Seems to be an over kill. ??? Thanks Sandy
SPasquale is offline   Reply With Quote
Old 11-05-2010, 11:59 AM   #157
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Well,we like to cover any low spots in the system,and believe me there are some. So we pump in RV antifreeze to make sure all the water is out. ITS NON -TOXIC and will not harm anything. I do not have a drain in my fresh water tank,so I pump it till it sucks air and then add 1/2 gallon to keep it from freezing. I pour some into each trap and we are go to -50F and pray it never gets that cold here,BRRRRR!
Hope that's the answer you were lookin for.
Roger
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 11-05-2010, 02:11 PM   #158
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Yep we did the winterize and also did our antifreeze injection even though we had blown out the lines. Unless you can get the lines dry there is always the possiblity of moisture collecting in a low spot and freezing. Besides unless you blow out the drain traps in the shower and sinks you need to get some antifreeze into these also.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 11-06-2010, 01:27 PM   #159
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
The Company recommends just blowing out the lines, but it is impossible to know if you really get all the water out. Drops can stick to the inside of the pipes and then flow down to a low spot. For example, the sink sprayer has a low spot and the sprayer itself breaks very easily if there's any water in it that freezes. The toilet valve (it's behind the top of the toilet) also breaks easily if there's any water in it and that means removing the toilet to replace it. The outside shower faucet is a low spot. The newer PEX pipes are not rigid and therefore there are many low spots. When you use antifreeze you know you have forced water out. I use about 1 1/2 to 1 3/4 gallons—cheap insurance.
Traps can freeze too (think about replacing the shower trap—no easy access). And some extra antifreeze in the tanks keeps the drain seals lubricated.
RV antifreeze is not toxic like car antifreeze. It is supposed to be pink. If it's not, take it back. Some people report it tastes bad and some say that's because some brands of RV antifreeze are cheap stuff. I've used Prestone for the last couple of years and I don't detect a bad smell or taste. In the spring you have to flush and sanitize the system. When you sanitize, you have to pump the chlorine solution through the lines, then flush them too with clean water. If you taste antifreeze or chlorine you probably need to flush more.
Gene
Old 11-29-2010, 09:32 AM   #160
Mount Airy , Maryland
Thanks John. We will winterize our 2000 Excella this week with your instructions. The winters in Maryland can get very cold so we want to protect our Airstream. We are new owners-so thank you.
gwillie is offline   Reply With Quote
Old 12-10-2010, 08:22 PM   #161
cms4140's Avatar
Birmingham , Alabama
Winterizing question: Is a cup of antifreeze in the toilet bowl - a good idea or bad idea?
cms4140 is offline   Reply With Quote
Old 12-10-2010, 08:32 PM   #162
dznf0g's Avatar
Oswego , Illinois
Good idea, I always keep AF in the bowl, if for no other reason than to keep the seals from drying out.
Old 12-10-2010, 08:35 PM   #163
cms4140's Avatar
Thanks for the reply. I was a bit concerned about staining the bowl with it. Perhaps that is not an issue.
Old 12-10-2010, 08:38 PM   #164
dznf0g's Avatar
Oswego , Illinois
My old trailer was 17 years old, with a Thetford toilet and had AF in it for 4 - 5 months every year. Never stained. Also, the AF doesn't evaporate very readily. If there's AF still in the bowl after months, you know your seal is good.
Old 12-10-2010, 08:43 PM   #165
cms4140's Avatar
Again, thanks for the feedback. Still learning...
I wasn't expecting to have to deal with this so early in December down here. Unusually cold already.
Old 12-10-2010, 09:25 PM   #166
1972 Argosy 20
2000 36' Land Yacht XC Diesel
narrows , Virginia
I have a washer dryer combo in my 2000 airstream.. Is there an easy way to winterize the washer or do you have to run a cycle to get the antifreeze in ..also the drain for the washer trap lets fumes into the coach if you dont use the washer for a while..can I silicone around the hose and still have it work?thanks JIMMY dogfather motor yatch
jtrivett is offline   Reply With Quote
Old 12-10-2010, 09:26 PM   #167
1972 Argosy 20
narrows , Virginia
can anyone tell me how to get to the water pump in a 2000 thirty five foot land yatch:?freightliner chasis..thanks JIMMY t dogfather
Old 12-11-2010, 11:18 AM   #168
Master of Universe
Gene's Avatar
I leave some in the bowl too. No stains after a couple of winters and I'd rather have a stain than a blown seal.
The question about a washing machine is a good one. I don't know if they are designed differently from household models so there are no low points in the hoses or pumps, but I'd check it out thoroughly and run some antifreeze through it. The trap should have antifreeze in it too—it should go to a grey water tank and that wouldn't smell all that bad when the trap dries out. If for whatever reason the washing machine drain is connected to the black tank, then it would smell much worse.
Gene
winterizing
Getting Road Ready Devoman Our Community 0 10-27-2011 08:32 AM
Hindenburger Ready to Roll Nashville Wheels, Hubs & Bearings 2 09-02-2011 04:55 AM
Winterize For One Night? jambie Winterizing, Storage, Carports & Covers 15 03-22-2011 09:33 PM
Heavy Freeze / burst Pipes / New WH and Pump? robwok Water Heaters, Filters & Pumps 5 03-03-2011 09:06 AM
Ready To Begin Tear Down To Frame.?.?! Althea68 Repairing/Replacing Floor &/or Frame 11 01-26-2011 04:28 PM
