08-19-2012, 04:42 PM
2015 28' Flying Cloud
2012 25' Flying Cloud
2007 20' Safari SE
Fuquay Varina
, North Carolina
Garage/Workshop
Wondered if anyone had plans/ideas for a good Garage/Workshop building to include an area for the Airstream.
08-19-2012, 05:49 PM
Retired.
, At Large
Our neighbor across the street has a garage for his motor home, with workshop space attached. I'll see if I can take a couple of photos in the morning, if it's over being gloomy.
08-19-2012, 05:55 PM
2005 31' Classic
2005 31' Classic
Douglass
My wife & I live in a 40' X 70' metal building that I built myself. The 20' on the very back end (800 Sq. FT.) is a garage/workshop and storage space for the Airstream with a "pull through" drive way. Pull in on one side, pull out on the other. The rest is centrally heated and cooled (2000 sq. ft.) and consist of 2 bed rooms, 2 baths, a laundry room, a storage room and a great room with a kitchen, dinning area, and living area all in one. The hall goes down the middle and the back door leads right into the door of the Airstream which provides sleeping quarters for 4. (6 if needed.) and an extra bath room.
James Rudd
2001 25' Safari
2003 Dodge 2500
08-19-2012, 06:24 PM
2012 27' FB International
Full-Timer
, South Dakota
This storage/house solution sounds very interesting. Would you be willing to post a few pictures?
08-19-2012, 06:48 PM
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View
I think I have the best. I bought an Army surplus Building from Fort Sill. This was a training building designed of instructing Soldiers on weapon maintenance. It is 40 x 40 with a drive thru capability ....from in one side to out the other. When the weapon (airstream) is pulled in the doors at both sides can be closed. Where the Army had bleachers located on one side of the building...allowing the Soldiers to look down at the subject...I built a dividing wall...... on the lower half I have an apartment set up (could be an enclosed shop) and on the upper area of that structure I built in a reinforced floor. So I have a storage area and shop above the apartment that overlooks the Airstream (weapons) drive thru area.
08-20-2012, 04:33 AM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
We are looking at a building similar to this one. Ours will be 36' wide (3 12' bays) and either 40' or 60' long. It will have 3 bay doors on the one end. If we go with the 60' it will be to add an apartment on the one end. These are full steel buildings including the frame and are very sturdy. Ours will becoming from Carolina Structural.
Aaron
WBCCI #XXXX AIR #2495
09-06-2012, 11:21 AM
1965 20' Globetrotter
2015 25' FB Flying Cloud
Keller
My wife and I are building a new home as we speak, and one of my requirements was indoor space for our '65 Globetrotter. Since getting it in and out of the living room would have proven problematic, we settled on a detached garage with 10' doors (x 9' wide) ... Thankfully, even with an a/c unit, our trailer will fit perfectly. It's a beast of a garage, but I'd rather build too much rather than too little!
(Not sure why photos aren't attaching ... I'll add links for now.)
Garage
Garage 1 Web | Flickr - Photo Sharing!
House (right) and garage, shown from rear
Garage 2 Web | Flickr - Photo Sharing!
09-06-2012, 04:33 PM
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
My RV parking with a 30'x40' shop behind it. I can park two 34' Motorhomes or Trailers side by side. I was lucky that the RV parking/shop came with a nice house as well
AIR #13
09-06-2012, 05:05 PM
"Tinbad ... the Trailer"
1965 26' Overlander
Ferndale
Hi Silver Bee:
This is about as in-expensive a way to go. Simple 30x40 pole barn 1/3 living-1/3 Trailer-1/3 Shop.
Pic's taken at different times of year (obviously).
I full time here and only on the worst days am I confined to the trailer with an electric heater (not running propane indoors unless I can get good cross ventilation) as I double insulated and run a infra-red heater that consumes 15 cents/hr in the barn.
Out back is future patio/r.v. pad which I'm just about finished with.
good luck
09-06-2012, 07:08 PM
2009 28' International
Columbia
This is where we park. Room for the trailer and the truck.
12-18-2012, 05:02 AM
1999 30' Excella 1000
Chatham
, Virginia
Now if I could just get the wife on board. like the living room wall decor
06-17-2013, 03:00 PM
Keller
Finally finished ...
I haven't posted on this thread since last September, when we were just beginning construction on our house and garage. Here are a couple shots of our 20' Globetrotter inside the new garage ... We have a 30-amp plug in the wall, and used 10' doors (and a 12' ceiling) to ensure enough clearance. Couldn't be happier now that our Airstream is in out of the crazy North Texas weather (particularly now, during hail season).
06-17-2013, 04:13 PM
2015 30' Classic
2012 28' International
Greensboro
, North Carolina
....my contribution to the thread is this custom built cedar siding set-up. Matches my pool house.
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
06-17-2013, 05:07 PM
Baltimore
, Maryland
There are some great plans here. They are free!!!
06-17-2013, 05:42 PM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
Originally Posted by 62overlander
Wow! There is some neat stuff in there!
Aaron
06-17-2013, 06:11 PM
Baltimore
, Maryland
Aaron
I know, a building for any need. A handy person can easily build from any of the plans. I am thinking of building the large granary. You never know when you might need something like that.
06-17-2013, 09:27 PM
Keller
BAB -- I really like the carport and the way it blends with the other building. Very nice. Something like that was my fallback position in case we couldn't build our garage the way we did.
06-18-2013, 04:20 AM
Baltimore
, Maryland
06-19-2013, 08:08 PM
2015 30' Classic
Greensboro
, North Carolina
I feel really fortunate that I didn't have to deal with a HOA or some code issue. Having handy access to my trailer is wonderful, and because I was able to put in a 30 Amp box, water and a sewer connection, it can (and has) done double duty as an occasional extra set of guest quarters when the house is full. I made the building long enough so I could put a 30' trailer in there (heh, heh). And, it can easily be finished on three sides with matching cedar siding and a garage door. OH, and my two basset hounds LOVE going out there when it's warm. The cement slab stays very cool and they sack out under the trailer where it's peaceful, quiet, and a place to watch for a stray bunny!
_________________
ProPride 3P
AIR# 58452
06-20-2013, 06:38 AM
Normal
Too cool, Barry!
Maggie
