I recently backed my new 07 Safari 27 FB into a 6x6 post in my garage. I dented the rear bumper enough to jam it into the rear storage box. This apparently pushed the storage box back enough so that now I cant get the two taps to pull up and open. Does anybody have any ideas.
Do you have a digital camera?
If you can post a picture here, someone may have a couple of ideas.
Oh, and welcome to the forums.
What a bummer, but it's better that denting the aluminum skin.
The rear bumper storage compartment has a single piano hinge along its entire length. Try taking a hammer and punch and tap the hinge pin out to one side if its not too bent. Get a pair of Vice Grips locked on the hinge and pull it out. If you can get the pin out, you should be able to access the storage area.
__________________ SuEllyn & Brian McCabe WBCCI #3628 -- AIR #14872 -- TAC #FL-7 2015 FC 25' FB (Lucy) with ProPride 2020 Silverado 2500 (Vivian) 2023 Rivian R1T (Opal)
Thanks Terry, SuEllyn and Brian! Thanks for the nice welcome. This is our first camper and first Airstream. We've had it out only one night and loved it. Anyway, I think we are on our way to fixing the damaged bumper and storage box. I managed to get the tabs opened with a screw driver and then took off the bumper. I am going to see if my local body shop can straighten the bumper. The piano-hinge was not damaged and the bumper barely bent. Thanks again. I'll let you know how it works out.
