Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Winterizing, Storage, Carports & Covers
Old 10-20-2010, 08:22 AM   #1
BarryIowa's Avatar
Polk City , Iowa
Garage Lift - Making Room for Your Airstream
I am adding this post because I looked everywhere online and could not find any information on how to raise my garage so I could make it tall enough to house my 1955 Flying Cloud. The job is done and I hope many of you find this information useful. A little history: in 2001 I bought a garage for $200 and moved it from a lot that was going to be developed. I stripped the shingles and siding to make it lighter but because it was built in (I'm guessing) the 1950's, it was covered in 1" x 12" boards for the sheathing on the sides and roof. In other words, it was built like a tank. My dad and brother helped me lift and move it. I mention this because that information helped me when I later decided to lift it. At first, I was going to just try to raise the roof but later decided that it would be too difficult to change the wiring and since it was a hip roof, there was very little room to work and to further complicate matters, I had since finished the interior including drywall.
The pictures tell a 1000 words to I'll just put them in order and follow up with a few details. The first picture shows the removal of 1' of drywall at the top when I was thinking of lifting only the roof. The second picture shows the bottom siding removed to allow for the removal of the anchor bolts the the beginnings of the interior bracing need before the lift.
Name:	01 drywall.jpg
ID:	113563   Click image for larger version
Name:	02 BeforeLift.jpg
BarryIowa is offline   Reply With Quote
Old 10-20-2010, 08:28 AM   #2
BarryIowa's Avatar
Polk City , Iowa
More Progress
Here are some more bracing shots. I doubled up two 2" x 10"s and lag bolted into every stud. Then and did the same 2" x 10" boards across and beneath in three spots which gave me 6 jacking spots. I used six 8 ton bottle jacks that you can buy at Harbor Freight for about $24 each and solid concrete blocks. We had one guy on each jack and would go up at the same time until there was enough room to slide in another block. Then we would let the jacks down, pull out the jack and add another block under it and repeat. Kind of scary when we were getting close to full 3' lift height. It was swaying just a bit.
There is also a picture of my dad, a retired electrician, making some temporary jumpers so we would continue to have power while we lifted.
Name:	03 bracing1.jpg
ID:	113565   Click image for larger version
Name:	05 DadElectrical.jpg
ID:	113567   Click image for larger version
Name:	06 wallsBuilt.jpg
Old 10-20-2010, 08:32 AM   #3
BarryIowa's Avatar
Polk City , Iowa
More Progress
And we have lift off. This doesn't look like much but getting it off the ground even an inch was a BIG deal to me.
More picture during lifting, the team and the garage with the walls in.
Finally the garage gets some siding.
Name:	07 LiftOff.jpg
ID:	113571   Click image for larger version
Name:	08 LiftOff2.jpg
Name:	09 LiftingGang.jpg
ID:	113573   Click image for larger version
Name:	10 WallsIn.jpg
Name:	12 lifted.jpg
ID:	113575   Click image for larger version
Name:	12 garageSheathing1.jpg
Old 10-20-2010, 08:34 AM   #4
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Looks like your FC is going to have a happy little home. To paraphrase Johnnie Cochran - if it doesn't fit, you must raise it!
Neat job.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 10-20-2010, 08:35 AM   #5
BarryIowa's Avatar
Polk City , Iowa
Completed Garage
Here is the fruit of about 4 months of work. I hope you find this useful and motivational if you would also like to attempt this type of project. My Airstream finally has an indoor home and can be out of the weather in the rain and rough Iowa winters. I also have a place to restore my 55 Cloud anytime of year. After all this work, the restoration may not seem like that big of deal!
Name:	17 Complete1.jpg
ID:	113580   Click image for larger version
Name:	17 Complete2.jpg
Name:	18 Complete3.jpg
ID:	113582   Click image for larger version
Name:	19 Complete4.jpg
Old 10-20-2010, 08:37 AM   #6
BarryIowa's Avatar
Polk City , Iowa
Some more technical information. The garage is 20' x 30'. It now has a 9' overhead door with an 11' interior ceiling height. It used to have a 7' overhead door and an 8' ceiling height. I also added a window air conditioning unit that I installed into the north wall before siding.
Old 10-20-2010, 08:38 AM   #7
BarryIowa's Avatar
Polk City , Iowa
Thanks Pat!
I had some of this posted in my 1955 Flying Cloud restoration thread but thought posting a new thread made more sense.
Old 10-20-2010, 08:39 AM   #8
bredlo's Avatar
1954 22' Safari
Deerfield , Illinois
Send a message via AIM to bredlo
This is great! I've definitely seen another similar thread recently, but thanks for sharing your process anyhow. Not only is this a success story in regards to the "big lift", but you recycled an entire garage - that's got to feel good as well.
bredlo is offline   Reply With Quote
Old 10-20-2010, 08:40 AM   #9
Kevin245's Avatar
Interesting approach to solving your access problem. Thanks for sharing.
Kevin
William C. Swinney
Old 10-20-2010, 08:44 AM   #10
oh2bcarefree's Avatar
HOUSE SPRINGS , MO
Images: 48
Very Cool!
...and very creative design. I am sure it was bear to get it lifted, but what a great solution. Enjoy the new digs to work on your trailer.
Tina
oh2bcarefree is offline   Reply With Quote
Old 10-20-2010, 09:21 AM   #11
teagues's Avatar
2008 20' Safari SE
Charlotte , North Carolina
Well done!
teagues is offline   Reply With Quote
Old 10-20-2010, 10:04 AM   #12
BarryIowa's Avatar
Polk City , Iowa
I did recycle that garage and I'm a big fan of that! I was also able to use some of the bracing/lifting wood as a new overhead garage door header and sold the rest on Craigs List. I was also able to return all of the unbroken block used in the lift and sold 4 of the 6 bottle jacks. As many of you probably noticed, I had to completely re-side the garage since I added on to the bottom. I was able to re-use nearly all of the siding and installed it on the north and west walls and only bought enough new siding for the south and east walls. The singles were still in great shape so they were left alone. I also sold the 7' garage door on Craigs List (the guy even took it down himself) which eased the pain of the $1000 for the new door.
Old 10-20-2010, 10:27 AM   #13
LJH
LJH's Avatar
1985 27' Sovereign
Defiance , Ohio
And in your spare time you......? Very nice work. LJH
LJH is offline   Reply With Quote
Old 10-20-2010, 02:03 PM   #14
BarryIowa's Avatar
Polk City , Iowa
Yes, in my "spare time" between working full time, being married, raising three boys, playing bass in a rock cover band, honey do lists, and Airstreaming.
BarryIowa ....... If life is dull, shine it up!
TAC IA-8
Old 10-20-2010, 04:30 PM   #15
Jezibels's Avatar
1966 24' Tradewind
Chicago , Illinois
Great job Barry!
Im hoping a 10' door will work for us, building a 3rd car garage (addition) next year for "Belle".
Happy Trails!
Jezibels is offline   Reply With Quote
Old 10-21-2010, 06:51 PM   #16
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Impressive! Makes me wish my garage was detached!
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 10-21-2010, 07:17 PM   #17
r carl's Avatar
Lin , Ne
Can you lower your floor?
Old 10-21-2010, 08:03 PM   #18
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
Originally Posted by Jezibels View Post
Great job Barry!
My shop door is 10' and the 51 Flying Cloud clears nicely. It is 8' 3" high - no roof A/C.
What gets some people in trouble is they put a garage door opener in that hangs down lower, or their lights are low, and that is what they end up hitting.
Barry & Donna
Life is short - so is the door on a '51 Flying Cloud (ouch)
safari57 is offline   Reply With Quote
Old 10-22-2010, 07:31 AM   #19
BarryIowa's Avatar
Polk City , Iowa
That is a good point Barry. I was thinking about putting in an opener but I don't open and close that door all that often and don't need the extra expense.
TAC IA-8
Old 10-22-2010, 07:33 AM   #20
BarryIowa's Avatar
Polk City , Iowa
Bye the way, Barry, I love your tow vehicle. I really want something vintage once my AS is restored. I need to be able to haul my wife and three boys and it HAS to have AC. Any ideas?
TAC IA-8
3rd Car Garage Ideas for Airstream Storage Jezibels Winterizing, Storage, Carports & Covers 30 11-17-2010 03:20 PM
1999 Airstream Bambi - Garage Kept w/ Damage Functional eBay Watch Airstreams on eBay 0 09-20-2010 07:30 PM
1999 Airstream Bambi - Garage Kept w/ Damage Functional eBay Watch Airstreams on eBay 0 09-15-2010 11:30 AM
First Airstream, already making it my own sfelsheim General Interior Topics 6 07-03-2008 06:04 PM
My Airstream Won't Fit in the Garage! campadk Winterizing, Storage, Carports & Covers 25 01-22-2007 05:49 PM
