Old 10-30-2015, 10:47 AM   #1
rfield54's Avatar
2002 19' Bambi
1989 29' Excella
1980 28' International
Avon , Colorado
Images: 106
Send a message via AIM to rfield54
Fully Drain The FW Tank?
Regarding winterizing, how important is it to completely drain the FW tank via the petcock ('89 Excella), versus running most of the water out via the water pump. I ask because the drain valve handle snapped off two winters ago. I didn't drain via the valve last winter, and all seemed well this year. (cold winter climate, nights usually in the teens or colder)
PS: I've already done the requisite search, with very few specific results.
AIR #2753
www.roybloomfield.com
rfield54 is offline   Reply With Quote
Old 10-30-2015, 10:53 AM   #2
mandolindave's Avatar
The tank can handle a small amount of freezing water
But the hose pipe going to the pump AND the small outlet of the tank that the hose is attached to ……could freeze and crack.
Try tilting the trailer to get as much water out as you can, then store the trailer in a slight pitch so the water flows away from the outlet
mandolindave is offline   Reply With Quote
Old 10-30-2015, 10:57 AM   #3
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
I would put a small amount of antifreeze in the FW tank and run it through the pump to be sure. Next year when you replace the broken valve, you can easily flush the remaining antifreeze out of the FW tank.
Bob Martel
WBCCI# 5766
Old 10-30-2015, 11:34 AM   #4
rfield54's Avatar
2002 19' Bambi
1989 29' Excella
Avon , Colorado
Images: 106
The trailer is set semi-permanently, so tilting is not a realistic option.
Maybe I've been lucky the past 12 years with regard to not putting antifreeze in the pipe leading to the water pump from the FW tank. I guess emptying the FW tank via the pump has been enough. (I add antifreeze to the system thru the pump, after the air compressor purge...no effect on the pipe from the FW tank)
AIR #2753
Old 10-30-2015, 11:43 AM   #5
Long Island , New York
Could you get the broken drain valve replaced, or is it inaccessible because of the way your rig is stored? Might be a good investment, but since you have gotten away with things for this long, you may be OK.
You could pour a gallon or so of AF directly into the fresh water tank via its fill spout, which would help out IMO.
Old 10-30-2015, 11:51 AM   #6
rfield54's Avatar
2002 19' Bambi
1989 29' Excella
Avon , Colorado
Images: 106
I guess I'm a bit reluctant to put anything but fresh water into the FW tank, though oddly I don't seem to mind AF in the lines post water pump ��. Maybe I'll try that.
AIR #2753
Old 10-30-2015, 05:01 PM   #7
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Did the broken valve look like this?
This is how I fixed ours
Good Luck!!
PFC
"Tahawus"
but I’m the Husband, so we went to Cleveland. 😂
RLC
“It’s a crooked piece of time that we live in….”
John Prine
Old 10-30-2015, 06:02 PM   #8
rfield54's Avatar
2002 19' Bambi
1989 29' Excella
Avon , Colorado
Images: 106
That's it!
AIR #2753
Old 10-31-2015, 02:41 PM   #9
Wolf Alaska's Avatar
Madison , Alabama
It won't hurt nothin' to put pink RV A-F into fresh water tank & then run pump to get pink water out of nearest faucet. Then the tank, line, & pump will be protected. If tank is empty, a gallon of A-F will be enough.
Blowing out lines with air won't protect this area.
Wolf Alaska
M.S./CFI/IR/ME/CP
FMCA SKP GS GPAA NRA USN (Ret)
Wolf Alaska is offline   Reply With Quote
Old 10-31-2015, 03:05 PM   #10
rfield54's Avatar
2002 19' Bambi
1989 29' Excella
Avon , Colorado
Images: 106
I'll try it. Thanks for the replies 😎
AIR #2753
Old 10-31-2015, 05:04 PM   #11
Flying Cloud 27
smlbob's Avatar
2015 27' Flying Cloud
Union Hall , Virginia
I swear I drained mine on the 170 mile trip home today...but the meter reads 100% !! Guess I'll ignore it !
smlbob is offline   Reply With Quote
Old 10-31-2015, 05:13 PM   #12
Castaway's Avatar
2012 25' FB Flying Cloud
Celina , Ohio
Drain the tank as well as possible then buy a bottle of cheap Vodka or Gin and pour it in the FW tank and then run some through the lines. Next spring fill the tank with fresh water and flush out the lines and all should be well
Gary
Castaway is offline   Reply With Quote
Old 10-31-2015, 06:31 PM   #13
enduroryda's Avatar
1994 21' Sovereign
Down on the corner... , CT
My valve broke off also. I now drain my tank by removing the plug under the tank. I replaced the original with a PVC plug. Easy to get on and off with an adjustable.
enduroryda is offline   Reply With Quote
Old 10-31-2015, 07:45 PM   #14
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
I have replaced that petcock valve twice on the last 14 years. Easy fix. And it is a cheap part. Takes about 45 minutes to do it.
David
TAC # TX-18
AIR # 410
http://www.flickr.com/photos/dsphotoscapes
dscluchfc is offline   Reply With Quote
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Re working kitchen drain- pex for drain lines?? Bwilson11 General Repair Forum 4 04-20-2014 08:42 PM
Help w/ fully dead bat's RiskIt Batteries, Univolts, Converters & Inverters 18 06-17-2007 07:18 AM
Value....of 1994 Airstream Classic limited....."Immaculate , fully loaded"!!! route66 Off Topic Forum 7 09-22-2004 07:02 PM
A/C Drain ...leaking at drain hose connection Sav'h Steve Furnaces, Heaters, Fireplaces & Air Conditioning 5 08-01-2004 04:09 PM
