Old 10-31-2015, 08:07 PM   #15
rfield54's Avatar
2002 19' Bambi
1989 29' Excella
1980 28' International
Avon , Colorado
Images: 106
Send a message via AIM to rfield54
I like what ROBERT CROSS did (post #7). I think I'm going to make that happen in the spring, which is when I'll be back to my place in UT (where two of my three AS's live).
AIR #2753
www.roybloomfield.com
rfield54 is offline   Reply With Quote
Old 11-01-2015, 06:13 AM   #16
1996 25' Excella
Tillsonburg , Ontario
I would think that putting antifreeze in the FW tank without the ability to drain it would mean you could never get the taste out of the water. Even a small bit of diluted antifreeze still tastes bad. Lines flush....a tank with out a drain means you can only dilute the antifreeze; it would take forever filling and pumping...repeat!...repeat!
I have never tried Vodka but at least that doesn't taste bad!
I never worry about a bit of water in the tank, and we live in Ontario where it routinely gets to Zero and below. I do leave the drain valve cracked open .. if I remember...Haven't had one crack, just broke it off on the '89 trying to open it.
JCW
JCWDCW is offline   Reply With Quote
Old 11-01-2015, 04:53 PM   #17
1998 30' Excella 1000
Livingston , Texas
There are two kinds of RV antifreeze. The slightly more expensive glycol, and the slightly cheaper one that is alcohol based. The latter includes a "bitterant" to discourage someone from drinking it. The bitterant takes quite awhile to remove from your plumbing. If you're having residual taste issues, take note of which one you used.
Siegmann is offline   Reply With Quote
Old 11-02-2015, 08:16 PM   #18
1996 25' Excella
The taste of RV Glycol tastes bad too. It is non-toxic propylene glycol, unlike Auto antifreeze which is ethylene glycol based and toxic. There are, as Siegmann notes alcohol based antifreeze products and mixtures of the two (alcohol/ propylene glycol)
The use of cheap vodka starts to make sense for the FW tank. No residual taste and non-toxic. I have not and am unlikely to put any antifreeze in my mostly empty FW tank since a frozen 'puddle' in the bottom of the tank will not burst the tank liner.
JCW
Old 11-03-2015, 05:03 AM   #19
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Originally Posted by rfield54 View Post
That's it!
54....
Order the Aluminum Fitting now, the gentleman makes them at home in his machine shop, they were not available for quite awhile earlier this year. Got the 1/4" ball valve & fittings at ACE Hardware.
FWIW....he also makes some nice accessories for the Honda generators, ck 'em out.
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Re working kitchen drain- pex for drain lines?? Bwilson11 General Repair Forum 4 04-20-2014 08:42 PM
Help w/ fully dead bat's RiskIt Batteries, Univolts, Converters & Inverters 18 06-17-2007 07:18 AM
Value....of 1994 Airstream Classic limited....."Immaculate , fully loaded"!!! route66 Off Topic Forum 7 09-22-2004 07:02 PM
A/C Drain ...leaking at drain hose connection Sav'h Steve Furnaces, Heaters, Fireplaces & Air Conditioning 5 08-01-2004 04:09 PM
