Old 01-21-2016, 06:21 AM   #15
Ok,
We have one of our units thawed. Praise God!
Thank you for all of your suggestions and I have learned about closing the tank.
As for winter camping...we are living in our units while we build a new house.
Moved from Texas to the Tennessee mountains, so riding off into the sunset was not an option, well not without sawing off a pipe or two!
pepsigns is offline   Reply With Quote
Old 01-21-2016, 07:00 AM   #16
CaptMac's Avatar
2014 25' FB Flying Cloud
Asheville , North Carolina
We also moved to the mountains and stayed in our trailer while we built a home (about 20 years ago) what we did was bought bales of hay and rapped them around the bottom of the unit so no air could get in and packed them around the water and sewer lines about a foot or more thick and we went through the winter without any problems, give it a try
CaptMac is offline   Reply With Quote
Old 01-21-2016, 07:25 AM   #17
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Originally Posted by pepsigns View Post
Ok,
You might think about skirting your trailer with straw or hay bales. Don't block the furnace or WH exhausts! You will be more comfortable inside and the pipes will not be exposed so much. There's a lot more winter left.
Alan
Old 01-22-2016, 11:07 AM   #18
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Yea ! put hay bales around you camper and see how many mice it brings, so buy plenty of mice traps....
Old 01-22-2016, 11:54 AM   #19
1977 31' Sovereign
Lynnwood , Washington
Without doubt, the proper tool for a frozen 3" sewer valve is a hair dryer. I've used a small propane grille with great success as well. But nothing beats a hair dryer for convenience and portability.
But if your sewer valve is mid-ship and inside the belly pan, and if you've got furnace ducting flowing into your belly pan, then you've gotta run the furnace 'til your dump valve thaws out.
Tom
TomKirk is offline   Reply With Quote
Old 01-28-2016, 04:33 AM   #20
hang up and drive
kry226's Avatar
2010 30' Classic
:) , Germany
Had this happen to us during the "Polar Vortex" from a couple of years ago, except our valves were frozen shut with full tanks. Low temperatures got down to near zero every night for about two weeks.
We tried just about everything and the frozen valves just laughed at us, especially when one of the valve handles came off in my hand. I finally broke down and purchased a Mr. Heater propane space heater from the local Bass Pro and after about 45 minutes, we were back in business with working valves again. Had to do this one more time later in the week.
But to the trailer's credit, it handled the cold VERY well. The poor furnace almost never kicked off, but nothing ever broke. My wife was especially thankful that we never had to make the "Walk of Shame" to the bath house as many other campers in the campground had to do.
2004 Dodge Ram 2500 5.9L Cummins 4WD (SOLD)
2010 Classic 30
ProPride P3-1400
kry226 is offline   Reply With Quote
Old 01-28-2016, 05:37 AM   #21
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
OP,
Skirt your trailer with bales of hay or straw and place a work light of around 100 watts under the trailer.
Plumbing won't freeze and you will be warmer inside.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Frozen Dump Pipes bertheep Waste Systems, Tanks & Totes 11 11-23-2013 05:42 PM
Frozen gas valve robert claus LP Gas, Piping, Tanks & Regulators 6 05-10-2011 07:18 AM
HELP frozen black water tank, not valve wildwoodmusi Full-Timing, Winter Living & Workamping 21 01-20-2009 03:37 PM
Staining Sewer vent from sewer gas TheProfessor Cleaning, Stripping & Polishing 6 02-16-2008 01:42 PM
frozen black water dump valve Rick Alston Waste Systems, Tanks & Totes 6 10-28-2003 01:17 PM
