Old 10-22-2008, 06:35 PM   #1
2006 19' International CCD
Philadelphia , Pennsylvania
front low point drains, 19' int'l
hello all,
i can find two drain valves under the dinnette seat. however it appears one is cold water and one is the water tank.
am i missing a hot water line low point valve up there?
i looked underneath and only saw two exit points.
thanks!
eric
ericwarren is offline   Reply With Quote
Old 10-22-2008, 06:47 PM   #2
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Originally Posted by ericwarren View Post
hello all,
thanks!
eric
Eric,
You may have already located the hot and cold low point drains if they point straight down. The drain valve on the potable water tank on our '06 is a plastic valve on the side of the potable water tank enclosure behind the curb / passenger side wheels.
I'll ask the question...Did you take a look at your owners manual???
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 10-22-2008, 06:47 PM   #3
2002 19' Bambi
Lafayette , California
Assuming your 19' has the same layout as our 2002 19' Bambi, you have 3 low-point drains and a drain for the freshwater tank. You have found the tank drain and the low-point drain at the front of the trailer. At the back, under the bed, are the shutoff valves for the rear two low-point drains, one of which is for cold water and one for the hot water system. You should be able to see the two drains coming out of the bottom of the trailer if you look underneath on the curb side just back of the water heater. The water heater itself also has a drain plug you can unscrew. It is visible when you open the water-heater hatch on the outside of the trailer.
Tim A. is offline   Reply With Quote
Old 12-18-2008, 02:58 PM   #4
petersburg , Tennessee
try searching on google or mabye buy a book on your question from books a million or barnes and nobel
my work
jroland is offline   Reply With Quote
Low point drains runningbarre Winterizing, Storage, Carports & Covers 5 09-25-2008 06:07 AM
Failure of low point drain valve? desidou Fresh Water Systems 8 12-24-2006 08:29 AM
dinette slipcovers for 06 Int'l CCD 19' Bambi indiancreek 2005 and newer - Bambi all models 0 09-17-2006 09:25 PM
Proper Front Support Point for Chassis guy99 Mechanics Corner - Engines, Transmission & More... 2 10-05-2004 05:54 PM
