Old 11-05-2019, 11:08 AM   #1
Fresh water tank petcock valve
Just stored my 2020 Bambi 22FB for the winter. Itís inside in a heated garage.
Canít remember if my fresh water drain valve was open or not.
Additionally, not sure which way is closed and which is open as there is no water left in it so nothing drains no matter how I position it.
My questions:
1) Which way is open?
2) Big deal if I leave it open all winter?
Thanks!
steilkurve is offline   Reply With Quote
Old 11-05-2019, 06:58 PM   #2
My questions:
Thanks!
So I called Airstream and they told me it didnít matter open or close when in storage and that open was probably best to help the tank dry out. Experts on here would agree?
Old 11-05-2019, 07:10 PM   #3
2007 22' International CCD
I keep my drain valves shut to keep critters out. I put some quality RV antifreeze through the system as a precaution. It flushes out fairly easily.
Old 11-05-2019, 07:34 PM   #4
2019 30' International
Pennsylvania , Pennsylvania
I close mine after draining so as to keep vermin out. Don't ask me what I'm afraid of, just the thought of some bug or something crawling up in there.
Chances of that are slim, but hey, I'm OCD
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 11-05-2019, 08:03 PM   #5
2007 27' Safari FB SE
Forest Grove , Oregon
I have hundreds and hundreds of spiders and bugs in my shop...I close it to keep things from crawling in over the winter. I gently close my low point drains for the same reason as well.
bweybright is offline   Reply With Quote
Old 11-05-2019, 09:20 PM   #6
Ok but letís say something does crawl in, it would have to be very small and would be spit out after a good flush come Spring, no?
And what position is closed, left or right?
Old 11-06-2019, 05:38 AM   #7
Ok but let’s say something does crawl in, it would have to be very small and would be spit out after a good flush come Spring, no?
On mine, when facing the valve, left is closed, turn to right to open.
And I think you are correct, an ant, or other little bug, would likely get flushed out if you do that. Otherwise it would either get caught up in the water pump filter, or just disintegrate.
I once popped the lid on a private well, and there was quite a colony of earwigs tucked in and happily living under the lid. So, you KNOW that person had earwig carcasses falling in to that well water. He and his wife, and children, and family, all survived
Old 11-06-2019, 06:45 AM   #8
Baby Zeppelin's Avatar
2018 28' Flying Cloud
Suwanee , Georgia
On mine with the handle pointed toward the front of the trailer it's closed, to the rear of the trailer it's open.
Name:	Drain Valve.JPG
valve closed in photo above
Erik & Carol
Suwanee, Georgia
AS: 2018 Flying Cloud 28 "Baby Zeppelin"
TV: 2017 Ford F250 Lariat w/ Blue Ox Sway Pro
AIRForums #126944 WBCCI #1297
Baby Zeppelin is offline   Reply With Quote
Old 11-06-2019, 07:08 AM   #9
Thanks.
Not sure why the manual and valve itself are so cryptic in terms of telling you which way is open and which way is closed.
From memory the handful of times Iíve used the fresh water tank in this first few months of ownership, I think you are correct. Left closed, right opened. Others feel free to chime in.
Iíll probably pay the visit fee and go check at the storage facility the AS is at. While Iím not too worried about bugs because of the above, why take the chance.
Old 11-06-2019, 07:13 AM   #10
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Take a little water and pour it in the tank. Drain it out and close the valve.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 11-06-2019, 09:19 AM   #11
Al
Guess I could though itís been winterized and all.
Old 11-06-2019, 10:26 AM   #12
VeloBuckeye's Avatar
2018 27' Flying Cloud
Easton , Pennsylvania
I placed a dot of red paint on the petcock while in closed position, and a dot of green paint on the other side while in open position. Helps this aging brain remember...
VeloBuckeye
2018 Flying Cloud 27FB
2018 F150 Lariat PowerStroke Diesel
VeloBuckeye is offline   Reply With Quote
Old 11-06-2019, 10:43 AM   #13
Attachment 355707
Thanks. Looks like the same valve. Pretty sure now closed is left/front pointing for mine.
Old 11-06-2019, 10:52 AM   #14
banderabob's Avatar
2008 19' Bambi
2012 23' Flying Cloud
Bandera , Texas
Iím no expert, but I leave it open.
banderabob is offline   Reply With Quote
Old 11-10-2019, 08:46 AM   #15
Thanks all for the advice. Ended up going back to the indoors storage facility. They had a few clients still coming in with their trailers so let they let me access without charging me their usual fee. Valve was indeed open so I shut if off. It was open for a few days so it probably dried out if it was still wet. It’s now closed for the winter. Best of both worlds I guess.
Petcock drain pouring water GypsyKarma Water Heaters, Filters & Pumps 11 10-10-2016 04:01 PM
Where is my fresh water tank petcock drain plug? '76 Tradewind Bobkatbry Fresh Water Systems 8 03-24-2016 04:56 PM
Newb: petcock to dump water not working? 3campers 1984-1988 Limited 4 06-09-2012 03:49 PM
Replacing Fresh Water Drain Petcock on 99 Safari Clawdan Fresh Water Systems 10 01-14-2010 05:15 PM
Metal Petcock Valve Replacement, Help! HowardD Fresh Water Systems 3 06-10-2005 10:41 PM
