Old 11-23-2014, 11:18 AM   #1
2014 23' Flying Cloud
2015 25' FB Flying Cloud
seattle , Washington
Fresh water pump
Have a 2014 Flying Cloud 23D I purchased new 6 weeks ago. I would like do the routine maintenance when possible. There was a thread in AF on winterizing the fresh water pump by pouring RV antifreeze in the inlet screen. I removed the panel under the wardrobe closet. Is that all the access for pump access?
reddogboyce is offline   Reply With Quote
Old 11-23-2014, 12:10 PM   #2
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I'm not sure how similar our arrangement is, but in our 2005 Classic 30, there is a large lift out panel on the floor of the wardrobe.
Removing that reveals a large plastic storage bin underneath and lifting that bin out then gives excellent access to the pump and all its connections.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 11-23-2014, 01:10 PM   #3
murreywalker's Avatar
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson , Missouri
Yes, and your access through the bottom of the wardrobe on the 23 is a lot easier than many others.
As stated, there are many threads on winterizing your trailer, and there's a pretty good walk through in your manual.
One hint regarding your water filter (assuming it's still the same). If you run antifreeze through that filter, it will remove the red color of the antifreeze, and will run clear. Don't worry, the antifreeze is still effective.
Good luck!
2013 25 FC FB (Twin)
2013 Suburban 2500
http://www.pbase.com/murreywalker
2011 23 FC FB
murreywalker is offline   Reply With Quote
Old 11-23-2014, 02:35 PM   #4
2007 27' Classic FB
Ridgefield , Washington
If I might make a suggestion...If you've never winterized yourself, hire someone that winterizes RV's and watch what they do. Helps to have Airstreams checklist with you and take a few notes. I always felt like that was money in the bank when I first winterized. As a side note, we blow out the lines, antifreeze in the p traps, a little for the gray and black tank and toilet.
John & Lisa
Woosch is offline   Reply With Quote
Old 11-23-2014, 04:36 PM   #5
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Just did mine today. Blow all the lines, RVAF in the traps and toilet, drain the hot water tank and remove the whole house filter element. I disconnect the inlet /outlet lines at the water pump and run the pump for a few seconds to evacuate any water. I have thought about removing the pump and bringing it home but have not done so. I would need to install plugs for the wiring. One side plugs into the pump and the other has a crimp connector. I would just need to eliminate the crimp and put a plug. Easy but haven't done it yet. So now my trailer is put to bed for a few months. Off to Florida in late January if the snow allows.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 11-23-2014, 08:26 PM   #6
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
Make sure there is no water left in the toilet valve. I had to replace the base of our toilet this year because there was enough water left in the valve to break it when it froze. Fortunately I was able to find a toilet on Ebay at a much reduced price that had a broken porcelain part. I also had to replace the hand sprayer nozzle at the kitchen sink one year for the same reason.
I enjoy learning, and I've heard that you learn from your mistakes, so I make lots of them!
Grant Davidson
Milton, ON
1946 Spartan Manor
1954 Va-Ka-Shun-Ette
1964 Overlander
1965 Avion C-10 Truck Camper
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
DavidsonOverlander is offline   Reply With Quote
Fresh Water Pump Quit scf31 General Repair Forum 2 05-17-2009 06:52 PM
New water pump-? fresh water tank adonh Water Heaters, Filters & Pumps 24 06-19-2008 07:00 PM
fresh water pump safari 28 Water Heaters, Filters & Pumps 4 02-14-2008 08:42 AM
Fresh water air pump conversion LHall Fresh Water Systems 3 08-28-2007 12:11 PM
Fresh Water Tank to Grey + Shower Pump? foshejh Fresh Water Systems 7 12-08-2005 09:22 AM
