Old 02-20-2007, 07:03 PM   #1
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Florida is sold out!
I stopped today at Camping World near St Augustine. yeah I am heading north. I am going to need to winterize Buttercup for my trip into Washignton, DC/PA/OH.
I was shopping for a collapsible ladder and some RV anti-freeze. None to be found. I suspect anywhere north of Tampa is sold out!
Can I use Canola or Corn oil to winterize the traps, and tank? I am planning on blowing out the water lines.
Michelle TAC MT-0
Sarah, Snowball
Old 02-20-2007, 07:10 PM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I would just use some cheap wine Try your nearest Wallymart they have an RV section and typically keep the RV antifreeze in it...some autoparts stores may have it too.
Aaron
WBCCI #XXXX AIR #2495
Old 02-20-2007, 07:11 PM   #3
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Are you go through Mississippi on the way home or another route? If so - you are welcome here. I have a gallon of RV antifreeze in the garage for you. BTW - Walmart here overstocked with RV antifreeze - lots of FEMA trailers but the people in them just don't care, many are being returned in deplorable shape. Drive safe.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 02-20-2007, 07:15 PM   #4
lewster's Avatar
Naples, FL , Hood River, OR
Antifreeze!!!
Hey Michelle,
I just spent 4 hours today rescuing a trailer that just arrived from Quebec. The poor folks had water coming out of every water fitting. The place where they store it was supposed to winterize it, but they only blew out the lines and did not add antifreeze.
The result was a busted water heater tank, a kitchen and lav faucet that were both leaking badly, and a dozen or so fittings that needed replacement. The only thing that held was the Pex tubing itself.
Try Wally World for some anti freeze if you can't find any at CW and be sure to open EVERY faucet to be doubly sure thatthe pink stuff is flowing thru.
Old 02-20-2007, 07:17 PM   #5
Keymar , Maryland
I maybe coming through mississippi on I-40. I suspect this will be northern MS. I can check Walmart but I expect they will be out as well. Just looking for alternatives.
Michelle TAC MT-0
Sarah, Snowball
Old 02-20-2007, 07:18 PM   #6
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Sanders had some for almost $10 a gallon. Used to get it in Ohio for $1.79.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 02-20-2007, 07:23 PM   #7
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Vodka. Rot gut....nothin' fancy. Works in a pinch.
Old 02-20-2007, 07:28 PM   #8
Keymar , Maryland
The factory blew out the lines back in Nov/Dec when they were fixing it. It is still doing ok. I have a short piece of hose so I can hook it up to the pump. I plan on draining the water heater and fresh water tank, activating the heater bypass and putting antifreeze down all the drains and holding tanks.
That should do it.
Michelle TAC MT-0
Sarah, Snowball
Old 02-20-2007, 07:52 PM   #9
lewster's Avatar
That should do it.
Don't forget the lines for the toilet and shower......... and outdoor shower if you have one!
Old 02-20-2007, 08:07 PM   #10
Silver Threads's Avatar
2000 25' Excella
Kingston , Tennessee
Are you taking 40 all the way? I live right off of I-40 and there is a small RV store, right off the exit and they had a couple of cases of it yesterday. It is suppose to be in the 60's all week, so they may still have some, if you dont find it before you get here, let me know.
John & Tammy Adams
Silver Threads Custom RV Curtains
2000 Airstream Excella | AIR 15902
https://www.etsy.com/your/listings
Silver Threads is offline   Reply With Quote
Old 02-20-2007, 08:11 PM   #11
New Borockton , Alabama
Images: 21
That's what I was theenkin'
Really though, you should be able to find the stuff at any wally world along the way or in a pinch, SOB parts store along the highway.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 02-20-2007, 08:59 PM   #12
2002 34' Classic
Tecumseh , Ontario
Michelle :
Two words to solve your problem...
"West Marine"
Your welcome.
Paul.
PaulO is offline   Reply With Quote
Old 02-21-2007, 07:18 AM   #13
Keymar , Maryland
how many gallons? two? three?
Michelle TAC MT-0
Sarah, Snowball
Old 02-21-2007, 07:24 AM   #14
1975 27' Overlander
High River , Alberta
Originally Posted by lewster
Hey Michelle,
I would guess that they *may* have blown the lines out, but didn't drain the water heater at all. You can't get all of the water out, but a few inches in the bottom of the tank won't cause any problem as long as there is expansion room.
AlbertF is offline   Reply With Quote
Florida RV Condominium Resorts Cracker On The Road... 4 04-19-2004 06:50 PM
Forum Rally's - Anyone interested? John Our Community 26 10-30-2002 10:27 AM
The Perfect Airstream miquael Airstream Motorhome Forums 4 10-02-2002 04:11 AM
Rivet Lounge PeterH-Airstreamer Our Community 68 09-24-2002 11:22 PM
Parts is Parts!!! TRAPEZE Airstream Motorhome Forums 13 09-03-2002 11:48 AM
