Old 02-21-2007, 07:55 AM   #15
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
When disconnecting the pump from the tank and feeding the system straight from the bottle, I can typically do it in 2 or 3 bottles. Some do it in 1, but after blowing the lines out, I make sure the pink stuff gets everywhere...low side valves, water heater, traps, faucets, sink sprayer, head, etc...so 3 bottles....in my mind, it's cheap enough and having a bit too much is always better than not enough. Even if I spend an extra $3-4 for the added gallon or $6-$8 for 2 gallons more, in my mind, $8 is far less than the outcome of a possible problem.
Old 02-21-2007, 09:19 AM   #16
CanoeStream's Avatar
St. Cloud , Minnesota
Hadn't seen that this was about winterizing. Hope you have time yet -- but take the carbon filter out of the kitchen faucet before you run pink stuff through it. Otherwise you'll probably have to buy a new one.
Michelle, your karma account has a lot of upswing due. Wishing the best in travels to you! We're getting Gulf air this weekend with heavy wet snow before Sunday (mostly northern half of the state). I don't know the path predicted when it heads east.
5 meter Langford Nahanni
Old 02-21-2007, 09:21 AM   #17
Pet Sitter Extraordinaire
kposey's Avatar
1975 27' Overlander
Chattanooga , Tennessee
Images: 56
Antifreeze
Try auto parts stores too. I have been able to find it there sometimes too.
Kathy, Tommy, & Crew, Chattanooga, TN
Air #2757
1989 SquareStream (Annie #8)
kposey is offline   Reply With Quote
Old 02-21-2007, 11:16 AM   #18
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Good news is that you are catching us in a warming spell. I don't think you need to worry about it at all for the next several days - and there is always plenty of antifreeze up here. I think they ran out in the south because there is usually not much market for it.
Pat
pmclemore is offline   Reply With Quote
Old 02-21-2007, 06:19 PM   #19
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
I tried the local Wal-mart. Cleaned out.
The local auto parts place had three gallons. I bought them all.
Michelle TAC MT-0
Sarah, Snowball
Old 02-21-2007, 07:11 PM   #20
lewster's Avatar
Naples, FL , Hood River, OR
Originally Posted by AlbertF
I would guess that they *may* have blown the lines out, but didn't drain the water heater at all. You can't get all of the water out, but a few inches in the bottom of the tank won't cause any problem as long as there is expansion room.
Albert,
I'm sure that they blew out the lines and neglected the water heater tank completely! Compressed air is a great way to get the lines ready for ANTIFREEZE. It is the only way to get the pink stuff into every nook and cranny in the water valves to keep them from exploding (which is what happened!)
A few gallons of antifreeze is really cheap insurance. The repair tab on this trailer is currently at $1250 and still rising!!!!!!!
Old 02-21-2007, 09:16 PM   #21
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
Don't forget to drain the hotwater heater, blowing out the lines will not remove the water from the tank.
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Florida RV Condominium Resorts Cracker On The Road... 4 04-19-2004 06:50 PM
Forum Rally's - Anyone interested? John Our Community 26 10-30-2002 10:27 AM
The Perfect Airstream miquael Airstream Motorhome Forums 4 10-02-2002 04:11 AM
Rivet Lounge PeterH-Airstreamer Our Community 68 09-24-2002 11:22 PM
Parts is Parts!!! TRAPEZE Airstream Motorhome Forums 13 09-03-2002 11:48 AM
