Old 10-17-2016, 04:23 PM   #57
Long Island , New York
Ditto to recent comments. 40 PSI is plenty, as it does not take much air to blow out the lines if they have already been drained by gravity. We don't use any antifreeze except in the drain traps. Extra care must be taken with the pump, filter, supply line from the water tank, and water heater. The benefit is that the AF chemicals are never an issue.
Old 10-23-2016, 06:35 PM   #58
FishByFly's Avatar
2017 25' Flying Cloud
Oak Park , Illinois
For starters, I have been winterizing air streams for the past fourteen winters. My process has been blowing out the lines and the following up with RV antifreeze. In my process, I have not ever pumped the antifreeze into the city water inlet or the black tank rinse. This post got me consider this additional step.
I found a "hand siphon pump" at Home Depot for less than $10. With the needed connections, the setup was less than an additional $5. The pump allowed me to pump antifreeze with ease into both inlets. I feel better knowing I have additional antifreeze coverage on these lines and their associated backflip valves.
FishByFly
because I catch fish on a fly...
2017 25' FB Flying Cloud Queen
2010 F250 Lariat
FishByFly
2017 25' Safari FB
2010 F250 Lariat
FishByFly is offline   Reply With Quote
Long Time RVer, first time Airstream(er) Lucas S Member Introductions 4 03-19-2014 03:39 PM
Own your own scale? Ag&Au Jacks, Stabilizers, Lifting and Leveling 8 01-26-2014 02:52 PM
Frisco, TX - Long time lurker, first time poster johnfmiller Member Introductions 11 06-08-2011 07:50 AM
First Time and Full Time! JRoss3030 Member Introductions 9 03-20-2010 11:28 PM
first-time poster.....long-time reader ("lurker") happyfella Member Introductions 3 08-21-2006 08:55 PM
