Old 10-16-2016, 09:46 AM   #43
HowieE's Avatar
Princeton , New Jersey
Images: 12
Never pressurize the system until someone has opened one of the faucets. I then give short bursts until they indicate just droplets are coming out of the faucet. We start with the closest faucet to the city connection and work forward. When pumping in the antifreeze we open the closest faucet to the pump until antifreeze comes out and move from there.
2004 Excursion 4x4
Old 10-16-2016, 10:36 AM   #44
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
first time winterizing on my own
Well - I did something stupid. Welcome your thoughts...
I did everything right - drained the water heater, fresh tank, low point drains, etc. but forgot to set the bypass when I started flushing antifreeze through the lines. Cold water flowed very quickly with pink stuff. Hot water was VERY slow and eventually brought pink through the lines. I'm imagining some pink got in the HWheater which isn't a big deal, but do I need to do it again to make sure there's plenty of pink in the HW path in the lines?
I was so psyched until I started driving home and realized I forgot to do the one thing I was telling myself not to forget all week! 😕
Old 10-16-2016, 10:48 AM   #45
HowieE's Avatar
Images: 12
If you got pink stuff out of each hot water faucet while the bypass was not set you may have filled the hot water heater with stuff. That would have required a coupe of gallons of antifreeze but is OK. I would set the bypass, open a faucet and turn the pump on for a few seconds. That hopefully will move some antifreeze into the bypass valve. If you are still concerned then pump some additional antifreeze into the system with a faucet open and the bypass set to winter.
The plastic line are not that susceptible to freezing as they can handle the expansion of water while freezing. You want to make sure antifreeze is in all the metal faucets, pump head, input filter, filter can under sink if there, and bypass valve.
If you have blown out the system the city connection was purged of water while that took place.
I would drain the hot water heater now or you will have to run gallons of water through it in the spring. While draining the heater put about 18 ins. of a 1/4 in hose, in the drain hole to the bottom of the tank and draped outside. This should start a siphon and drain the last 1/2 gallon off the bottom of the tank. If the siphon does not start itself you know what to do, but politically correctness precludes you from instructions.
I always drain the bottom of the tank anyway to get some of the scale that collects on the bottom of the tank
2004 Excursion 4x4
Old 10-16-2016, 10:53 AM   #46
W , New England
Thanks HowieE.
Old 10-16-2016, 10:57 AM   #47
CruizinDux's Avatar
Eugene (Tracktown USA) , Oregon
SSM, personally I'd close the bypass, and push some more AF thru the lines and drain HW tank for the winter. I'd have to re-read the manual but is seems they recommend leaving it empty. I'd also flush the tank with one of those plastic flush wands.
Good luck.
CruizinDux is online now   Reply With Quote
Old 10-16-2016, 11:01 AM   #48
W , New England
Agreed. Will do, Bob.
Old 10-16-2016, 09:16 PM   #49
FishByFly's Avatar
2017 25' Flying Cloud
Oak Park , Illinois
How does one hand pump the antifreeze into the sewer clean out and the city water fill? What device are you using?
FishByFly
because I catch fish on a fly...
2017 25' FB Flying Cloud Queen
2010 F250 Lariat
Past: 2005 30' Safari Bunkhouse
Past: 1986 28' Excella Twin
FishByFly
2017 25' Safari FB
2010 F250 Lariat
FishByFly is offline   Reply With Quote
Old 10-17-2016, 08:04 AM   #50
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Hey Fly. I think you're making this harder than it is. There's no need to pump antifreeze into the dump cleanout. Just pour " some " down the toilet as well as some down any sink. That will just put SOME on the upstream side of the dump valves. I don't do this. I pour some down each drain to fill the traps against freezing and see no need to add to the actual tank. I simply blow the lines with my compressor and don't pump any antifreeze through the plumbing either. I also do not put any into the city water fill. I drain the fresh tank and leave the valve open.
Been working for me for 10 years of northeast winters.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 10-17-2016, 09:00 AM   #51
2017 27' Flying Cloud
London , Ontario
I understand emptying the water tank, blowing out the fresh water lines, emptying the water heater, and putting RV antifreeze in each P trap, but how does one empty the water pump? Just run it dry for a few seconds? I presume I should do that before blowing out the fresh water lines?
Second, when blowing out the black tank flush line, this just moves any residual water that might be in the flush line into the black tank itself, via the shower head?
Lastly, my understanding is that the water heater drain valve is actually above the bottom of the tank. In other words, simply draining it by gravity will not completely empty it. Is this true? Is the residual water an issue for freeze expansion?
I would appreciate knowing if the above is correct. We had our dealer winterize our Airstream this year, but we plan to do ourselves in the future.
Thanks!
Philip Jones is offline   Reply With Quote
Old 10-17-2016, 09:14 AM   #52
Ayr , Ontario
Don't forget that water can get trapped in the bypass lines to the hot water heater. Now I make sure that I operate all of the valves there while blowing the lines out. I also do the same while adding the antifreeze. That way I know that there is no water in that section. Make sure you drain the hot water tank first though. Pulling the plug on the tank while blowing the lines out can be a rude awakening.
I also make sure that antifreeze comes out of the low point drains just to ensure that no water settled into the lower recesses after blowing it out. Just make sure that in the spring time you run water out to purge the system of the antifreeze.
I also run antifreeze through the outside faucet.
One year I forgot to blow the lines out in the bypass section and the fitting on the bypass line came off. It was an easy fix, but required a trip to the dealer since I didn't have a crimping tool.
Where I live minus 30-40C can be normal for several weeks in winter.
gator.bigfoot is offline   Reply With Quote
Old 10-17-2016, 11:58 AM   #53
CruizinDux's Avatar
Originally Posted by Philip Jones View Post
I understand emptying the water tank, blowing out the fresh water lines, emptying the water heater, and putting RV antifreeze in each P trap, but how does one empty the water pump? Just run it dry for a few seconds? I presume I should do that before blowing out the fresh water lines? {Disc the output & put a rag down and turn in on for 5-10 seconds...a couple of times. There isn't much water there and the rag will catch it. I also manually blow on the supply side any water back into the CW tank. Couple of lung fulls seems to do the trick}
Second, when blowing out the black tank flush line, this just moves any residual water that might be in the flush line into the black tank itself, via the shower head? { the interior and exterior shower heads should be disconnected and blown out with the other faucets. Blowing out the black flush tank line should push the eater into the BW tank which needs to be drained.}
Lastly, my understanding is that the water heater drain valve is actually above the bottom of the tank. In other words, simply draining it by gravity will not completely empty it. Is this true? Is the residual water an issue for freeze expansion? {my remembrance of reading the WH cut sheet is that a little residual is fine. I flush out the tank with water using a plastic flush wand to remove any sediment. I have heard of folks using that tool to connect to shop vac to get the residual, but IMO you're OK with some remaining}
Thanks!
Good Luck
p.s. check out my post #13. There are a couple of general attachments for the winterization process. If you send me PM I'll send you my check list...maybe a little too detailed but but I wanted to make sure I didn't overlook anything.
b
Old 10-17-2016, 12:09 PM   #54
retired USA/USAF
2001 30' Excella
Water expansion is the problem. When in a confined space it has no where to expand to and will exert enough force to crack / break it's containment. In an open virtually empty space like an empty water tank, water heater tank it has plenty of space to expand. Copper water lines will freeze and the copper has no give to it, therefore will crack. Modern PEX plumbing is a bit more forgiving. I think the PEX as a little expansion give to it. The fittings that are used do not and are the weak link in the system. So in the short term soft freeze the PEX just might be OK. Some of the other materials maybe not so much.
Roger in NJ
TAC - NJ 18
Old 10-17-2016, 03:46 PM   #55
Ayr , Ontario
You would be amazed at how much water is remaining in the HW tank after all of the lines and gravity plugs have been drained. I ran my compressor to the trailer for a half hour and no water came from the faucets or the gravity drain lines even when they were exercised individually. I then remembered about the tank plug and took it out. Try it next time. I'm sure my tank isn't that different from others.
Old 10-17-2016, 03:59 PM   #56
2017 28' Flying Cloud
Stow , Massachusetts
First off ....thanks to all of you for your advise!
As you know I questioned the compatabiltiy in towing with our Ram 1500 5.7 Hemi towing a 2017 FC 28'.
Our 2nd truck is a Ram 2500 Cummins with full tow package and air brakes.
I only mentioned the 1500 as I knew most may say just use the 2500. We all really enjoy traveling in the 1500 Longhorn.
So I will set up both trucks for the airstream any consider the topography of our travels. For what it's worth....The airstream mechanic and our truck mechanic both agree that the 1500 Hemi will tow it just fine. I'm just glad I will have the choice. Again thanks for your input and we are psyched to get our FC next month!!!
comeonletsgo is offline   Reply With Quote
Long Time RVer, first time Airstream(er) Lucas S Member Introductions 4 03-19-2014 03:39 PM
Own your own scale? Ag&Au Jacks, Stabilizers, Lifting and Leveling 8 01-26-2014 02:52 PM
Frisco, TX - Long time lurker, first time poster johnfmiller Member Introductions 11 06-08-2011 07:50 AM
First Time and Full Time! JRoss3030 Member Introductions 9 03-20-2010 11:28 PM
first-time poster.....long-time reader ("lurker") happyfella Member Introductions 3 08-21-2006 08:55 PM
