Old 10-12-2016, 03:48 PM   #29
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I usually pump enough AF into the lines where there is little if any risk of dilution. It is a step I chose not to do. There is nothing wrong with using air to purge the lines.
Old 10-13-2016, 08:37 AM   #30
2016 23' International
Salem , Oregon
TG Twinkie do you live next to the antifreeze factory? I am finding rv antifreeze for about $4.00 a gallon.
Dave
NoResults is offline   Reply With Quote
Old 10-13-2016, 02:11 PM   #31
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
first time winterizing on my own
No. I live in far western Nebraska. I was in Wal-Mart yesterday and saw it for $2.58 a gallon. I bought mine at Bomgaars in Torrington, WY for $2.50 a gallon.
We passed thru Salem on our way home from a month long trip to the Oregon coast. Had a great time with beautiful weather.
Old 10-14-2016, 09:24 AM   #32
Salem , Oregon
Well next winter bring me a couple of gallons of course it will cost me about 500.00 for transportation. If I ever get to your part of the country I could bring something from Oregon.
Dave
Old 10-15-2016, 09:25 AM   #33
FishByFly's Avatar
2017 25' Flying Cloud
Oak Park , Illinois
I feel this may be a dumb question, but how does one hand pump the antifreeze into the sewer clean out and the city water fil? What device are you using ?
FishByFly
because I catch fish on a fly...
2017 25' FB Flying Cloud Queen
2010 F250 Lariat
Past: 2005 30' Safari Bunkhouse
Past: 1986 28' Excella Twin
FishByFly
2017 25' Safari FB
2010 F250 Lariat
FishByFly is online now   Reply With Quote
Old 10-15-2016, 10:15 AM   #34
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you have blown out the system via the city connection that length of pipe is free of water and when you pump in antifreeze via the trailer pump it will be back filled sufficiently. You have to fill the anti freeze via the pump to protect the pump. If you have a filter before the pump make sure you connect before that filter when filling the system.
As for the tanks you should pour about 8 oz. of anti freeze in each trap and dump some directly int the black tank via the toilet, leaving a 1/2 in or so in the toilet. If you remove the cap on the black tank flush connection the water in it should drain the the tank thus clearing itself.
2004 Excursion 4x4
Old 10-15-2016, 12:12 PM   #35
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I leave anti freeze in the black and grey tanks to help prevent the dump valve seals from drying out and sticking to the blade.
Old 10-15-2016, 04:50 PM   #36
Roadhoop's Avatar
2016 25' Flying Cloud
Fort Worth , Texas
What do people use for the compressed air?
Roadhoop is offline   Reply With Quote
Old 10-15-2016, 04:56 PM   #37
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Compressor, air tank, or bicycle pump.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 10-15-2016, 04:59 PM   #38
FishByFly's Avatar
Oak Park , Illinois
I have an electric air compressor with a tank. Husky Air Scout. Allows me to control the pressures. Easy for my whole family to use to air up bikes and vehicle tires. I can travel with it but don't see the need.
FishByFly
2010 F250 Lariat
FishByFly
2017 25' Safari FB
2010 F250 Lariat
Old 10-15-2016, 09:02 PM   #39
HowieE's Avatar
Images: 12
When I am headed north and expect freezing before I get home I stop in a truck stop and use their air tower.
2004 Excursion 4x4
Old 10-15-2016, 09:22 PM   #40
Holly Springs , Mississippi
How much air pressure should I use to blow out the lines?
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
Old 10-15-2016, 09:30 PM   #41
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I turn mine down to about 45 # or so. I think anything less than 60# is safe. Seems to work for me.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 10-15-2016, 09:32 PM   #42
FishByFly's Avatar
Oak Park , Illinois
I keep mine at just below 50lbs but recently read 40lbs. It doesn't take much to blow out the lines. I do a systematic walk through all points and then go back for a second pass. Follow up with RV antifreeze. I do a double pass on that too.
Whole process takes 30 mins.
FishByFly
2010 F250 Lariat
FishByFly
2017 25' Safari FB
2010 F250 Lariat
Long Time RVer, first time Airstream(er) Lucas S Member Introductions 4 03-19-2014 03:39 PM
Own your own scale? Ag&Au Jacks, Stabilizers, Lifting and Leveling 8 01-26-2014 02:52 PM
Frisco, TX - Long time lurker, first time poster johnfmiller Member Introductions 11 06-08-2011 07:50 AM
First Time and Full Time! JRoss3030 Member Introductions 9 03-20-2010 11:28 PM
first-time poster.....long-time reader ("lurker") happyfella Member Introductions 3 08-21-2006 08:55 PM
