Old 12-11-2009, 06:20 AM   #15
oleschool's Avatar
1973 31' Sovereign
chapin , South Carolina
Nice info 2 air.........I just wish Rolly Polly's PO would have known this kind of info, buy heck that copper needs to go anyway......
oleschool is offline   Reply With Quote
Old 12-11-2009, 09:20 AM   #16
1972 29' Ambassador
Harrah , Oklahoma
Originally Posted by tmarquis View Post
Yes I am plugged in and I do have both the furnace and a portable heater running. (I only failed at that one day.) I do have all the cabinets open. I'm also worried about the water in the battery? does having the trailer plugged in keep that from freezing? If i can keep the interior at 40 and the fresh and hot water tanks drained. I should not worry about pinking the lines. (I really want to avoid that stuff in the lines. I still drink from the tap it doesn't seem like the pink stuff would rinse well)
The oil filled radiator heaters are fairly inexpensive, and much safer than the little blower types. They also seem to be a bit more efficient.
I wouldn't worry about the water in your battery. Do you plug in your car at night? Rather than drink from the tap, drain your lines and for drinking water take one of those cheap water jugs with you. Think of it as a metal tent with heat, lights, and a camp stove. Forget about using the plumbing during the winter.
My Brain Project and Tech Notes
airbassador is offline   Reply With Quote
Old 12-11-2009, 09:31 AM   #17
banjobill
wmarsha's Avatar
2000 30' Limited
battle ground, , Washington
Moffett Railroad history
If you read the history of the Moffett Road, you'll find that the rails in the mountains would be surrounded by snow/ice melt during the day, and then freeze at night causing the rail to split along the length of the rail-causing many derailments right in the rail yards...Caused them to increase the cross section of the rail-I believe from 80 lb rail to at least 100 lb rail (per ft) -oh the Moffett was a standard guage line that climbed out of Denver (near Boulder) up and over the Continental Divide-the Moffett tunnel is still in operation, but originally, the rail line went up and over the top. Yep, it can get cold there. Frazier, CO is one of those frosty places....Rest in peace, Mr. Bollinger, author "Rails that Climb"
wmarsha is offline   Reply With Quote
New and a little worried? Lifestreamer Member Introductions 6 09-08-2009 06:05 PM
**How Cold is it?** Silvertwinky Off Topic Forum 728 02-05-2009 06:36 AM
Worried! wander'n Member Introductions 9 05-06-2007 04:24 PM
Worried, help! Walt Stanton Member Introductions 8 04-07-2006 07:30 AM
Ok Now I'm Worried! Opinions please! 59toaster Our Community 11 10-15-2003 09:00 AM
