Old 11-12-2014, 10:45 PM   #1
Danny Bell's Avatar
1966 28' Ambassador
Colville , Washington
Exercising your A/C in winter months ?
Hi All,
I've been told over the years that one should run the A/C in your car for a few minutes each month, even in the winter as to keep seals lubed to help prevent freon leakage.
I have an old Armstrong unit (that works great) in my 1966 Ambassador. Should I run it a little during the winter ? Is there any advantage or disadvantage to this ? Is there a potential to freeze something up ? I live in a cold (winter) climate.
Dan
Danny Bell is offline   Reply With Quote
Old 11-13-2014, 07:20 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
It's already 48 years old. If you've never run it in winter before, why start now? Empirical evidence should prove that it's not required.
But if you do decide to run it briefly, wait until the temperatuee is warm enough for the thermostat to actually let it come on. Trying to run it in temperatures lower than the thermostat will go would be pointless. And because of the thermostat, there's no chance you'll freeze it up, because it simply won't run when it's that cold.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 11-13-2014, 07:24 AM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Most modern cars today will start the A/C compressor when you run the defrosters. Which is why the compressors tend to last longer.
Not sure this is a requirement on none automotive units.
Old 11-13-2014, 07:47 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
The reason for running the AC in a car was the seal on the compressor. Running it was a means of reseating the seal. Hermetically sealed units such as home and Rv units don't need this exercise.
As mentioned above most newer cars subconsciously do this.
2004 Excursion 4x4
HowieE is online now   Reply With Quote
Old 11-13-2014, 09:01 AM   #5
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I don't think it is necessary to just run the a/c in the winter just for the sake of running it.
In your car, every time you turn on the defroster the compressor and evaporator/drier are operating. This is what makes the glass clear of fog/mist so quickly.
Our a/c unit is run by default because we have heat pumps- basically the a/c system running in reverse- compressor running. Last year we camped in November and January.
We will probably camp in January this year, too.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Shower Control Valve Froze and Cracked over the winter months. mountainman1 Sinks, Showers & Toilets 11 05-11-2009 01:36 PM
Storing (storage) of Honda Gen. winter months... crazylev On The Road... 5 11-08-2004 11:30 AM
Looking for somewhere to park our coach for 2 months in the Los Angeles area!! HELP!! williamhenshall Our Community 5 10-22-2003 08:58 PM
Six whole months Pahaska Our Community 3 12-02-2002 08:44 AM
