Old 10-10-2016, 08:49 PM   #1
Stay CazuaL
cazual6's Avatar
2014 19' Flying Cloud
Reseda , California
Electrical Cap
Anyone has anything to cover the 30a cords? I am looking to cover them while in storage.
The "why" isn't important at this time. I am just looking for a solution.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
"Sweat is your fat crying"
WBCCI 9164
cazual6 is offline   Reply With Quote
Old 10-10-2016, 09:34 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Confused, Do you mean while still connected to the trailer or disconnected? I put mine in the rear storage compartment when not connected. Suppose you could split a rubber water hose and put over the cord when connected. Personaly I see no reason to do that as the cord is thick, heavy duty rubber coated and designed to be outside in the elements.
MICHAEL
Old 10-10-2016, 09:36 PM   #3
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Do a Google search for Marine Shore Power Bag.
Ray B.
WBCCI #6497
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is offline   Reply With Quote
Old 10-10-2016, 10:21 PM   #4
Stay CazuaL
cazual6's Avatar
Reseda , California
not connected obviously, while in storage. trying to prevent corrosion on the blades. marine products? good point. ty
WBCCI 9164
Old 10-10-2016, 11:46 PM   #5
1979 23' Safari
Wayland , New York
Give them a light coating of dielectric grease to prevent corrosion.
Or put a quart plastic ziplock freezer bag over them and zip tie it around the cord.
HiJoeSilver is online now   Reply With Quote
Old 10-11-2016, 10:16 AM   #6
AWCHIEF's Avatar
Images: 33
Thank you but not so obvious. My trailer stays plugged in while in storage. Ditto on the dielectric grease, available at an battery, auto parts store or wallyworld. Regularly apply to all electrical connections. Both ends of cord, connection socket on trailer, pig tail connections and tow vehicle plug.
Also good to give the battery post a good coating.
MICHAEL
Old 10-11-2016, 11:03 AM   #7
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Check out "wire loom" to cover the power cord. This stuff has various diameters and is split along its length to put the desired wires inside. Usually found at auto parts stores.
Pickup truck cap or no cap? weber.roger Airstream Lifestyle 28 12-04-2015 07:22 AM
Electrical probs w electrical to new fridge cooling unit. Surfairstrea Batteries, Univolts, Converters & Inverters 2 05-23-2012 08:24 PM
HELP PART NEEDED! Aluminum Termination Cap... InsideOut Waste Systems, Tanks & Totes 46 03-20-2006 07:08 AM
shower curtain "cap like" grommets Neenm Upholstery, Blinds, Walls & Interior Finishes 0 08-03-2002 03:04 PM
310 front cap Bfrank General Motorhome Topics 11 07-25-2002 09:36 PM
