Old 10-24-2011, 07:37 AM   #15
Originally Posted by dznf0g View Post
Which brand pump? I'm unaware of any of the newer ones which will be harmed by some dry running. That being said, I wouldn't want to run it dry for hours, but while doing your winterizing, it is fine if it pulls some air.
X2. The pump will make a different noise when it speeds up. It will run faster and not quite as loud.
I winterize by blowing out the lines. The last step in that process is disconnecting the inlet and outlet lines from the pump and running it briefly to push the water out of the pump. Put a rag or paper towel under the pump to catch the water.
handn is offline   Reply With Quote
Old 10-24-2011, 07:43 AM   #16
Wayne&Sam's Avatar
2007 20' Safari SE
Cuddebackville , NY
Originally Posted by gheuer View Post
Do we Virginians *have* to fill the lines with pink AS?
Nope. All I do is blow out the lines well and put pink in the traps. Even if a bit of water remains, there will be plenty of room for it to expand and not break anything. I've been doing it that way for years and it gets below zero here in the winter.
Old 10-24-2011, 01:55 PM   #17
Silver Otter's Avatar
1999 30' Excella 1000
Nellysford , Virginia
Send a message via AIM to Silver Otter
Wayne&Sam - Yay! I *love* simple. THANKS!
Greg and Linda Heuer
'99 Excella 30 w/HAHA - The Silver Otter
'08 Chevy 2500HD 6.6 DuraMax w/MBRP dual pipes
TAC VA-18 | WBCCI 1927 - Unit 149 | AIR 53869
http://www.linkedin.com/in/gheuer
Silver Otter is offline   Reply With Quote
Old 10-24-2011, 04:49 PM   #18
Well Preserved
overlander63's Avatar
Colfax , North Carolina
Yeah, that's what I thought and did. Then I had to replace some water lines from where the mostly drained water expanded and broke the pipes.
Some days, it's just not worth chewing through the restraints.
Old 10-24-2011, 05:39 PM   #19
aftermath's Avatar
Spokane , Washington
In my SOB, the water pump was under the bathroom sink and plumbed to draw pink from the gallon jug. I blew the lines, filled everything with pink and was good to go.
Purchased my used Airstream and found the pump hidden under the center closet, in very tight quarters and NOT plumbed with the valve to draw in the pink stuff. I went to our local dealer, who I have great faith in, and asked how I was supposed to winterize. He told me that all they do is blow the lines. Of course there is much more to it than just that, but they do not put pink in the lines. Part of the process is to run the pump dry for several minutes. I do it twice, waiting a good amount of time between. I live in a very cold climate and have never had trouble yet.
That said, I think putting in the pink is a good bit of insurance. Certainly nothing wrong doing that but there is nothing wrong with running your pump dry either. Perhaps Airstream has changed to a different pump?
aftermath is offline   Reply With Quote
Old 10-24-2011, 06:31 PM   #20
2011 23' Flying Cloud
Durango , Colorado
Agree with Wayne & Sam. Drain the system, inc. water heater, disconnect water pump and run dry (30 sec) then blow out thoroughly with 60 psi air. Pour a cup or two of pink antifreeze in all of the drains. Done. No residual chemical in your potable water next season.
Safe Travels,
Joe & Joan Donnaway
Durango, CO
http://web.me.com/jdonnaway1/Land_Cruising
JamuJoe is offline   Reply With Quote
Old 10-24-2011, 06:50 PM   #21
Ready-to-Travel
pmclemore's Avatar
1998 31' Limited
Walkerton , Virginia
The Airstream guys at their Alumapalooza seminar recommended using the water pump to winterize the system. They were not concerned about running the water pump "dry".
Neither am I.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
wbcci ex 9239
pmclemore is offline   Reply With Quote
Old 10-24-2011, 07:39 PM   #22
Well Preserved
I'm lobbying for that to change, at least to put the fitting there for winterization.I installed one in a brand new trailer Friday, it took me almost an hour to relocate the pump 4" and put the fitting on it. Winterization was about 10 minutes from that point to done with the pink stuff.
Old 10-24-2011, 08:42 PM   #23
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 145
ha! not so, with my pump. (and it may be just "mine"...others might be differently designed, etc).
I've had to replace the pressure switch on my pump TWICE.
and no, I'm apparently NOT smart enough to learn from the first experience.
The first time, I just did as the manual said, which was just to open the drains, and raise and lower the tongue jack to make sure everything drains.
Thats fine for the pipes, but...not the pump. (maybe the original pumps weren't so sensitive).
Second time...well, I just didn't get around to it, and we had an early cold-snap.
Anyway, both times, a tiny amount of water from behind the pressure switch swelled up when frozen, and pushed the switch housing away from the body of the pump. The weak spot that gave way was around one of the screw holes. screw held in place, but the plastic housing cracked around it.
There's no way that running the pump "dry" is ever going to get every bit of water out; the only way to do that is to replace it with something that won't freeze.
This year, I totally have the problem licked. I removed all the pipes.
(actually, as I type this...I realize that the pump is still out there, and I can't pump antifreeze through it, because it has no place to go, so I'd better just remove it from the trailer and bring it in the house).
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Chuck is online now   Reply With Quote
Winterizing & Water Pump Access 27FB DMT Winterizing, Storage, Carports & Covers 28 11-17-2011 06:15 PM
Blowing water pump fuse perryg114 Fresh Water Systems 3 10-04-2011 08:36 PM
Water pump Issue. Toronto_Guy Water Heaters, Filters & Pumps 6 09-23-2011 06:45 AM
Water pump leaking between head and motor Ezmoneybcs Water Heaters, Filters & Pumps 4 03-20-2011 06:32 AM
Is it a water pump or an electrical problem? Ag Sag Water Heaters, Filters & Pumps 7 01-23-2011 07:20 AM
