Old 10-07-2019, 06:53 PM   #1
marter's Avatar
2008 19' International
Lincoln , Nebraska
Do you leave antifreeze in all winter or drain it?
For those of you that use antifreeze to winterize, do you leave your antifreeze in your water system over the winter or run it through and drain it?
I winterized today for the first time (air compressor to blow out, then fill with antifreeze using a bypass valve on the water pump) and was told by a local RV shop that when they winterize a trailer they fill and then drain the antifreeze so it doesn't add (as much) taste to the piping and is easier to flush in the spring. Makes sense to me, but wonder what others do.
Mike (W9LG) and Jennifer
2008 International 19' Ocean Breeze, Equal-i-zer WDH
2015 Ford F150 4x4 Lariat SuperCrew EcoBoost, 3.55, Max Tow
marter is offline   Reply With Quote
Old 10-07-2019, 07:01 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
I leave it
CRH is offline   Reply With Quote
Old 10-07-2019, 07:22 PM   #3
DaveP's Avatar
2004 28' Classic
Monument , Colorado
I leave it, but I think either is okay.
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is offline   Reply With Quote
Old 10-07-2019, 07:50 PM   #4
2007 27' Safari FB SE
Forest Grove , Oregon
If using the propylene glycol formula I have never noticed a taste. Some with the alcohol formulation or a blend can leave a taste. So from my experience it depends. The Camco website has a good primer sheet on the different types of RV antifreeze and their characteristics.
Then, if you can find Starbrite (often at boat dealers) RV antifreeze I believe it is the propylene glycol formulation and cheaper than Camco from RV stores.
bweybright is offline   Reply With Quote
Old 10-07-2019, 08:52 PM   #5
Half a Rivet Short
Carlisle , Pennsylvania
Hi
The polyethylene glycol stuff most definitely has a taste. It's a bit sweet. It also has an impact on the digestive tract ( = it's MiraLAX)
Old 10-07-2019, 09:24 PM   #6
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
I've done it both ways.
The last several years I've opened the low point drains and all faucets after pumping the antifreeze in, letting it run out till is stops.
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 10-07-2019, 09:38 PM   #7
waninae39's Avatar
2017 22' Sport
NCR , Ontario
we blow our system first so its dry
then just add antifreeze to the traps
one jug does the whole AS
waninae39 is offline   Reply With Quote
Old 10-07-2019, 09:59 PM   #8
marter's Avatar
Lincoln , Nebraska
I'm leaning that way right now. I think it's protected.
Old 10-07-2019, 10:00 PM   #9
marter's Avatar
Lincoln , Nebraska
Paranoia I guess. Thought about it, this is the first year I've done this. When I was blowing out the water I kept getting a fine mist; maybe I didn't keep going long enough. How long do you keep the air going?
Old 10-07-2019, 10:23 PM   #10
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Blow out water, run a couple of gallons of "the pink stuff" through, then drain "the pink stuff" out.
We did it last weekend in less than an hour...just in time. Even though it was in the mid-sixties today and thru Wednesday, the temps on Thursday are expected to be "high 21/low 9"...our first real cold snap for the season. Brr...
Shari
RMVAC | WBCCI DenCO Unit | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 10-07-2019, 10:32 PM   #11
marter's Avatar
Lincoln , Nebraska
Shari
As I said, I'm leaning that way right now. I think I'll drain the pink stuff out tomorrow before I store for the winter.
We spent last week in Estes Park; beautiful weather with one night below freezing. We're getting a drop in temp here Thu as well, but only down to 30 here, not single digits.
Old 10-07-2019, 11:30 PM   #12
Hi
I stand corrected...please go to my reference to the Camco info page about the various formulations and their characteristics when making your decision. Sorry to confuse things with factual information vs personal opinion. Just part of the rv post thing I think.
Old 10-07-2019, 11:55 PM   #13
2017 28' International
Baileys Harbor , Wisconsin
I leave mine in all winter:
I flush the system at least once a year anyway. That means purifying the lines and tank with bleach. So when you flush clean everything out you are really getting rid of the antifreeze. Also the antifreeze is an assurance that any water left doesn’t freeze, expand, and ruin fittings. But I live in NE Wisconsin. And it gets really cold. Plus I don’t trust blowing it out. Seeing that anti freeze coming through the pipes is a visual clue that water is not left in them.
By the way be sure to disconnect ALL your fittings that you can like the shower head and store in a warm place. I didn’t do that my first year and I had to buy a new shower head.
Daquenzer is offline   Reply With Quote
Old 10-08-2019, 12:33 AM   #14
marter's Avatar
Lincoln , Nebraska
I flush the system at least once a year anyway. That means purifying the lines and tank with bleach. So when you flush clean everything out you are really getting rid of the antifreeze. Also the antifreeze is an assurance that any water left doesnít freeze, expand, and ruin fittings. But I live in NE Wisconsin. And it gets really cold. Plus I donít trust blowing it out. Seeing that anti freeze coming through the pipes is a visual clue that water is not left in them.
By the way be sure to disconnect ALL your fittings that you can like the shower head and store in a warm place. I didnít do that my first year and I had to buy a new shower head.
Thanks. Nebraska isn't exactly warm but probably not what you experience. I store it inside so it's out of the wind but no heat.
I bleach and flush every spring. And yes, I did take all faucets/strainers/hoses off and will keep inside at home.
But I still think blowing it out prior to antifreeze is a good idea to get the water out of the city fill portion of the system. I don't want to take the screen out and open up the backflow preventer to fill that part of the system with AF.
Old 10-08-2019, 08:03 AM   #15
Caffeinated's Avatar
2015 27' Flying Cloud
Portland , Oregon
I blow out and add rv antifreeze at the water pump intake. Run all water until it turns pink. Clean it out in the spring, no taste issues, and no damage from frozen pipes. Takes about a gallon and a half.
Mike
2015 27ft FC FB
WBCCI #3960
2019 F150 ecoboost
Caffeinated is offline   Reply With Quote
Old 10-08-2019, 08:27 AM   #16
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I leave it in the pipes. I drain it out of the fresh water tank.
Old 10-08-2019, 09:08 AM   #17
richw46's Avatar
Lexington , Kentucky
I leave it in as a precaution in case and water didn't get blown out. If we go south for the winter, before returning I will flush the lines with antifreeze and leave it in since I don't carry a compressor to blow the lines.
I sanitize my fresh water tank in the spring. After draining out the antifreeze I sanitize the tank and then send that through the lines. Drain that out, blow it out and run fresh water through them.
We don't usually drink the water from our AS. It's for flushing, cooking and washing dishes. I buy bottled water for the coffee and for drinking.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 10-08-2019, 09:20 AM   #18
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
We leave antifreeze in place for the winter. The one year we just used compressed air, we had to replace the pump in the spring. Minus 30F degrees is a little chilly.
We do an added step in the spring of adding baking soda to our lines and fresh water tank after sanitizing with bleach. It sits for 3 days, and then we flush the lines and tank with fresh water. Takes the bleach taste out. We do drink our water.
Kay
Old 10-08-2019, 09:28 AM   #19
rideair's Avatar
I once purchased a 1966 Overlander which had sat behind the owners house for 23 years. Even though it had tree-moss 3" thick on top of the trailer, had gone down to the axles due to four flat tires and had become a mouse hotel. The owners husband who had died, left the pink-juice in the system all that time. When I got the trailer home and hooked the water up to the trailer "NO LEAKS!!!! in the water system.
Since that day, I figured if it worked for old Mr. Jackson all those years, it should work for me over a winter.
Leave it in.
Enjoy,
Paul Waddell
rideair is offline   Reply With Quote
Old 10-08-2019, 09:45 AM   #20
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
I leave it however we mostly use bottle water for drinking, making coffee, and cooking.
urnmor is offline   Reply With Quote
Winter's almost here: ok to add antifreeze to black water tank? flyingfishy Full-Timing, Winter Living & Workamping 3 11-12-2018 02:15 PM
Interior vinyl and wood layer, to leave or not to leave? amaelish General Interior Topics 0 05-29-2017 01:18 AM
summer-do I need to drain antifreeze DTR Winterizing, Storage, Carports & Covers 6 07-14-2014 12:14 PM
Winterize, Pink Stuff, RV Antifreeze, Drain and Flush masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 12 11-19-2013 07:40 PM
Can I leave my Interstate marine flooded batts on trickle charger in winter? bonginator Batteries, Univolts, Converters & Inverters 20 10-06-2012 12:06 PM
