Old 10-21-2006, 08:10 PM   #1
Aria's Avatar
1967 20' Globetrotter
Sauquoit , New York
Do you cover your Airstream ?
We have read...do not cover your Airstream. We live in New York State where in the Fall there falling leaves. In the Winter snow. Do we cover?
I know it would be super to have it undercover in a building. At the moment we do not have a home for our Aria GT. A cover so Aria can take a breath?
Or no cover? Thanks Anne
Aria is offline   Reply With Quote
Old 10-21-2006, 09:18 PM   #2
Airstream25's Avatar
1995 25' Excella
1982 34' Limited
Albuquerque , New Mexico
Images: 21
Send a message via Skype™ to Airstream25
Do we cover?
Every comment I have seen on this subject is do not cover.
The wind moving the cover will cause abrasion.
Airstream25
KE5CKG on 2 meters
AIR #10274
Airstream25 is offline   Reply With Quote
Old 10-21-2006, 11:02 PM   #3
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
I'm in the same position as you, but with milder California weather. I asked the same question here a couple of weeks ago. Search for "soft cover" to find other posts on the subject. It seemed to be unanimous that you should not cover it with any cover (Soft or not) if the cover would touch the skin. If you come up with a way to avoid the two touching, and therefore avoid the abrasion that comes with dirt on the surfaces, then go for it. I've come to the conclusion that I will have to either put up a Metal carport type cover, or make up a framework that would hold the soft cover off of the skin.
Dave
Fyrzowt is offline   Reply With Quote
Old 10-21-2006, 11:18 PM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
In Arizona the biggest concern is the damage from the sun. I keep my trailer at a covered RV storage yard. I would never put a cover on my trailer.
Richard
Old 10-22-2006, 06:53 AM   #5
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I would not cover it. If it was an older unit that didn't have the new(er) Aloca coating on it as your unit does, I'd say sure, but in wind, the cover will rub against the finish and from what I've read here, it will rub enough to eventually damage it.
A good washing and Walbernizing should help protect the finish as much as can be expected with something exposed to the elements. Ideally, you'd like to have it inside, but when it's not possible.......
One other suggestion with outdoor parking is that you cover the tires. UV, the elements take their toll on the rubber. I read that here too, and it isn't an Airstream exclusive either. Trailer tires I've read take more abuse than car tires, covering them when not in use seems to be highly recommended.
Old 10-22-2006, 07:55 AM   #6
CanoeStream's Avatar
St. Cloud , Minnesota
My Safari spent about 4 days in the driveway under a tree this week. There were enough leaves around that it had drips and runs of "tea" down the side. It washed off very well but this was only after a short exposure. Would clearcoat develop a golden tint after a long time? There is absolutely no risk from snow, snow turning to ice, etc., on the roof of your Airstream.
I firmly believe when you look at breakdown of seals and clearcoat that Airstreams will benefit from some permanent shelter during storage. Richard's explanation about Arizona is almost as applicable up north IMHO -- we don't have the heat but imagine your skin if you sunburned 365 days a year. Floor deterioration comes after unrecognized seal breakdown. Long term care of 'our babies' does result in much better condition at the 20- and 30-year point. I rent a storage garage -- something that is not available nor affordable in many locations. I recall several threads with photos of temporary shelters in the past but found this one for now: http://www.airforums.com/forum...r-s-13941.html
5 meter Langford Nahanni
Old 10-22-2006, 10:27 AM   #7
Aria's Avatar
Sauquoit , New York
Thank you all. No Cover. Aim at shelter. Thanks again. Anne
Cost to restore a gutted Airstream Draco General Interior Topics 28 02-18-2013 11:17 PM
Late '80s Airstream Aluminum Fifth-wheel acwdgw Integrity 5th Wheel (all Years) 17 01-09-2004 10:20 PM
Trailer Life cover 83Excella Our Community 6 06-16-2002 10:14 AM
Airstream Related List Servers Andy R Link Archive 0 02-22-2002 02:05 PM
AirstreamTrailers.com - Airstream Link Library Andy R Link Archive 0 02-22-2002 01:31 PM
