Old 11-27-2005, 12:28 PM   #1
Tin Can's Avatar
2005 31' Classic
wilson , New York
Images: 8
Dealer Winterizing
Greetings all. Being a newbie I have question about winterizing. I asked my dealer how they winterized. I was told that they don't blow the system out with compressed air to clear water. Rather, they said that after draining the fresh water, gray water , black water and H2O heater tanks they put a line from the water pump and into the antifreeze and flush until antifreeze is coming out of all areas (sinks, Shower, etc.) This seems feasible to me but what do you think? Should I blow out the water or do you think this is adequate? The last thing I want to do in the spring is fix pipes. Thank-you for all thoughts.
Tin Can
Tin Can is offline   Reply With Quote
Old 11-27-2005, 12:38 PM   #2
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
My dealer blows out the lines and then uses the water pump to inject the antifreeze. Technically what your dealer told you will work. It might just take a little more antifreeze to make sure that it displaces the water in the lines.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 11-27-2005, 12:54 PM   #3
1975 29' Ambassador
Reno , Nevada
Draining and blowing out the lines still leaves water in nooks and crannies - esepcially in valves and stuff. But it does help make sure the antifreeze you put in as the next step isn't dilluted. The only thing I can see that might improve things is to use a hot water heater bypass. That'll save five gallons of antifreeze but you should absolutely remove the hot water heater drain plug.
See the weblog entry http://sierranevadaairstreams.org/snuze/?p=237 for a discussion and links to more information.
Old 11-27-2005, 01:06 PM   #4
2006 30' Classic
Farmington , New Mexico
Images: 14
Tin Can--- I use the exact method your dealer describes. There is another method that is in my opinion the absolute best. Hook up to your trailer and tow due SOUTH until warm temps are reached. Remain there until Spring!!!!!
Pieman
Mike Lewis is offline   Reply With Quote
Old 11-27-2005, 01:11 PM   #5
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
I think your dealer is treating your Airstream okay.
To a dealer, time is money. While you or I pay a reasonable cost of $3 -$4 a gallon for RV antifreeze, dealers more than likely purchase it in 50 gal drums for cents per gallon. They can waste a lot without feeling it in the pocketbook.
Skipping the blow-out-the-lines step saves labor time. Antifreeze is much cheaper than even an entry-level RV technician's time.
Don't forget that, if they do a poor job & you have freeze damage, they know they are on the hook to fix it at no charge to you.
Tom
Old 11-27-2005, 01:28 PM   #6
flyfisher's Avatar
2004 30' Classic
Field and Stream , PA & MT
Of course, everyone knows that it doesn't get cold, or snow, in the winter in your neck of the woods!
I think the dealer's procedure is OK as far as it goes, but I'd also want to make sure that my water filter is removed, antifreeze is also poured down the P-traps in the kitchen and bathroom sinks and in the shower, my hot water heater is drained and my water heater by-pass is turned on, my holding tanks are drained, etc. etc. (Read the owner's manual on winterizing and make sure all the steps are followed and you'll be Okay.)
John
Flyfisher
flyfisher is offline   Reply With Quote
Old 11-27-2005, 05:32 PM   #7
rfield54's Avatar
2002 19' Bambi
1989 29' Excella
1980 28' International
Avon , Colorado
Images: 106
Send a message via AIM to rfield54
Blowing out the lines is the most effective way to clear the section going from the city water inlet to the inlet valve. Here's one way to winterize:
Step 1. If you haven’t already done so, dump the holding tanks.
Step 2. Locate the fresh water tank drain valve or plug, & drain the water.
Step 3. Locate the water heater drain plug and remove it to drain the water heater tank.
Step 4. Bypass the water heater.
Step 5. Connect air compressor to city water inlet. Add pressure (60 psi). Open and close all faucets (hot AND cold) and toilet one by one to drain.
Step 6. Connect a short hose to the city water inlet and, while holding the open end up, pour RV antifreeze into it. Connect the compressor to the hose and blow the antifreeze into the part of the system that would otherwise remain unprotected by water pump entry alone (steps 7 & 8). Disconnect the hose and cap the city water inlet.
Step 7. Locate the water pump, disconnect the inlet fitting, install the winterizing hose and insert the other end into the jug of antifreeze.
Step 8. Turn on the water pump. Open the taps one at a time, closing each one when antifreeze appears. Once again, do the hot and cold taps at every sink or shower faucet - as well as the toilet (and toilet sprayer if you have one).
Step 9. Dump the holding tanks.
AIR #2753
www.roybloomfield.com
rfield54 is offline   Reply With Quote
Old 11-27-2005, 07:41 PM   #8
Tin Can's Avatar
2005 31' Classic
wilson , New York
Images: 8
Thanks for all of the good advice. It sounds like the way the dealer does it is safe.
Take care,
Tin Can
Old 11-28-2005, 12:58 AM   #9
rfield54's Avatar
2002 19' Bambi
1989 29' Excella
Avon , Colorado
Images: 106
That method will not protect the line from the city water inlet to the inlet valve, which in my '02 Bambi I believe is about 9' long. Why chance it?
AIR #2753
Old 11-28-2005, 09:39 AM   #10
jcanavera's Avatar
Fenton , Missouri
Images: 143
You're right. I forgot about that section of the water line or is it just a matter of leaving the end cap off the city water hookup and wait for the antifreeze to spill out?
For some reason I would think that this section of line would have a one way valve to prevent a backflow into the city line in case of a city pressure drop and where the pump is on.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 11-28-2005, 11:11 AM   #11
rfield54's Avatar
2002 19' Bambi
1989 29' Excella
Avon , Colorado
Images: 106
The regulator check valve will, if working properly, prevent antifreeze from entering that section of pipe from the water pump part of the system. Which is why step #6 from the above list is recomended. I suppose lowering and raising the jack might accomplish the same thing . . . MAYBE.
AIR #2753
Old 11-28-2005, 11:16 AM   #12
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
1964 17' Bambi II
Laramie , Wyoming
Images: 11
Before my first winter with my 2000 Airstream, I called the good folks at the factory. With their recommendation, I drain everything, bypass the waterheater, blow out the lines with compressed air and put a little antifreeze in each drain. That's it. The factory guy I talked with said that's what they do. I told the factory guy it gets 20 degrees below zero here and he said it gets real cold in Ohio too. So five winters with the 2000 and one with the 2005 and no problems.
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, 2018 Toyota Highlander
WBCCI # 4181 VAC member
Antique Pedaler is online now   Reply With Quote
Old 11-28-2005, 11:33 AM   #13
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I suppose blowing antifreeze into the city water line would work, and if that's what you do and it works, great, but simply connecting the compressor to the city water tank and blowing the lines out would be enough for me and has been enough for others.
When I had the Bambi, I didn't even blow out the lines, I just put antifreeze in the lines and didn't touch the city water connection...maybe I was lucky for two seasons.
Old 11-28-2005, 11:52 AM   #14
rfield54's Avatar
2002 19' Bambi
1989 29' Excella
Avon , Colorado
Images: 106
Originally Posted by Silvertwinkie
. . . but simply connecting the compressor to the city water tank . . .
I know I'm being a stickler for details, but I assume you meant city water "inlet"? So as not to confuse the newbies out there.
AIR #2753
Winterizing JWest Winterizing, Storage, Carports & Covers 8 11-04-2007 02:44 PM
Another Winterizing Question JWest Plumbing - Systems & Fixtures 2 11-04-2002 07:01 AM
Winterizing your plumbing 2002 BobbyW Plumbing - Systems & Fixtures 0 11-01-2002 08:23 PM
Winterizing and stuff Curtis-79MH Airstream Motorhome Forums 2 10-03-2002 09:27 AM
Used Airstream Dealer in Mississippi Raptorrider2001 Our Community 10 09-27-2002 08:08 PM
