Old 03-05-2004, 06:09 PM   #1
Confused & Wandering
Theo's Avatar
1993 34' Excella
Right here, , where ever I wake up
Send a message via AIM to Theo
de-winterizing problem
I de winterized the water heater, and filled the tank.. that went well, the electric works, the gas works, everying should be hunky dory, but for the miserable fact that the bathroom sink faucet no decides that any water passage is a bad thing. A mere trickle comes out.. It was the first faucet I opened to test the hot system...
The faucet is a pull up type Moen.
What did I do to it?????
How do I fix it???
The bathroom picture in my gallery shows the faucet type.
Theo
'05 Cargo hauler gooseneck, carrying an '05 Jeep TJ, all hauled by an '05 C4500 Kodiak Truck
Theo is offline   Reply With Quote
Old 03-05-2004, 06:17 PM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Is the screen on the faucet blocked with "gunk"?
Shari
Old 03-05-2004, 06:20 PM   #3
Theo,
Check to make sure the aerator device, which screws on the faucet opening, is not clogged with gunk. Unscrew it and clean it, and then try again. In fact, take it out and try the faucet with it out. You will know immediately it that is it. The Moen faucet has a cartridge water control device. If you need to change that, go to Home Depot or a plumbing supply shop and the can show you how to change it. Good luck. Jeff
pjlingl is offline   Reply With Quote
Old 03-05-2004, 06:20 PM   #4
Theo's Avatar
1993 34' Excella
Is the screen on the faucet blocked with gunk???
I don't know.. I will check - I did not actually know there was a screen on the faucet.. I wish i could do it right now, but I am not at home - so I have to wait until later..
Thank you for the suggestion.
Theo
Old 03-05-2004, 06:27 PM   #5
Theo's Avatar
1993 34' Excella
Originally posted by pjlingl
Theo,
Thank you, too, for that advice - I will turn off the water, and look tomorrow morning.. T
Theo
Old 03-06-2004, 04:50 PM   #6
Theo's Avatar
1993 34' Excella
That solved the problem.. Thank you guys..
Theo
Furnace Problem NOAZRK2690 Furnaces, Heaters, Fireplaces & Air Conditioning 10 04-10-2014 08:34 AM
What's the worst problem you ran into? Eaglemate On The Road... 16 10-29-2011 05:32 AM
Having and electrical problem with TV maybe toastie Batteries, Univolts, Converters & Inverters 4 07-30-2011 12:06 PM
A/C Problem: Turns on Then Shuts Off jonairstream Furnaces, Heaters, Fireplaces & Air Conditioning 4 05-11-2011 06:01 AM
