Old 08-03-2008, 10:50 PM   #1
1963 24' Tradewind
San Diego , California
Cover or not to Cover?
I see alot of SOB's that are covered with an rv cover, however when I see an AS in storage they are not covered. Is there a reason for this, and do you cover your AS? If not, why?
Sixty3TW4US is offline   Reply With Quote
Old 08-04-2008, 04:50 AM   #2
Uberphotos's Avatar
1968 22' Safari
Kalamazoo , Michigan
From what I understand covers has the potential to scratch your aluminum. However, I am not speaking from experience, just from what I have read in the forums.
'68 Safari Land Yacht, Double
Check out my blog... http://ssairstream.blogspot.com/
Uberphotos is offline   Reply With Quote
Old 08-04-2008, 07:52 AM   #3
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
If you put a cover directly on the aluminum you run the risk of scratching and black marks. Only cover your Airstream with a portable garage etc...in a barn...anything that will not actually touch the skin
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 08-04-2008, 09:58 AM   #4
willyd's Avatar
1993 34' Limited
Melbourne Florida , Springfield Ohio
Don't cover with a cover - the aluminum will be be scratched. I know for a fact.
willyd is offline   Reply With Quote
Old 08-04-2008, 10:09 AM   #5
3streams's Avatar
1948 22' Liner
1949 24' Limited
Springs , Pennsylvania
We had purchased a custom cover for our 2005 International- however- we never used it! If its inside and there is no wind to the blow the cover around the skin it might be okay- but certainly do not cover it outside where the wind will cause the cover to leave black "tarnish" marks on the skin.
April & Andy Hershberger
www.ClassicAluminumTrailers.com
3streams is offline   Reply With Quote
Old 08-22-2008, 06:36 PM   #6
mustang's Avatar
1999 27' Safari
Kent , Ohio
I always cover mine. water seeps in and freezes it will open the smallest whole up
mustang is offline   Reply With Quote
Old 08-22-2008, 07:02 PM   #7
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Here is just one thread with a lot of discussion about covering vs not covering... http://www.airforums.com/forums/f458...eam-34310.html ...and there are others in the Winterizing, Storage, Carports & Covers subforum... check it out...
TB & Greg and Abbey Schnauzer
#3954
Old 09-16-2008, 01:08 PM   #8
clio , Michigan
With this type of investment, the best option would be a metal, aluminum, or steel carport. These are available for much more reasonable pricing than you may think. It really is important to protect your investment!
dantheman972 is offline   Reply With Quote
RV Cover seareed 1997 -2001 Excella 8 06-20-2018 05:32 PM
To cover or not to cover vents? Director 1965 - 1969 Overlander 4 10-28-2007 08:01 PM
how do you cover your A/S? pinkflamingoes Winterizing, Storage, Carports & Covers 20 01-06-2005 07:14 AM
RV Cover LeeMo Off Topic Forum 10 07-21-2004 06:01 PM
cover kent osborn 1997 - 2004 Bambi 0 11-11-2003 07:24 PM
