Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Winterizing, Storage, Carports & Covers
Old 08-13-2016, 01:18 PM   #1
2016 27' International
Saint Helena Island , South Carolina
Cover Options for my Airstream
Was wondering if anyone uses a partial cover for just the roof? I'd like to cover roof without the sides for air circulation. Any help or thoughts would be appreciated. We have a 27 fb.
rollieboy is offline   Reply With Quote
Old 08-13-2016, 01:21 PM   #2
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
We are in NJ, no cover except for tires and jack. Ideally best to keep indoors. I do not have that option.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 08-13-2016, 01:33 PM   #3
1973 31' Sovereign
Middletown , California
I have cobbled together many shade covers supported by trees and/or posts in the ground. Always worth the trouble to me. However, it takes a lot of work to make sure the cover doesn't blow away! I've always wanted to use 2 of the Costco portable garage covers and make a really nice year around cover but haven't yet tried that due to the need to extend the legs for clearance. I've thought to set peeler core posts in the ground to fasten the metal frame legs to. Never tried this yet for several reasons but will probably try it when I'm going to stay in the right spot for a year or two. Shade makes all the difference in the world for comfort in my climate!
ijustlee is offline   Reply With Quote
Old 08-13-2016, 03:34 PM   #4
I was leaning more toward a cover to put directly on roof to keep leaves and whatnot off of it.
Old 08-13-2016, 03:47 PM   #5
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I guess if you put something just on the roof it would not be an issue, but for a larger cover where it overlapped the clear coat, you'd have to be careful.
I had a plastic tarp I put over a boat many years ago, and either through some sort of chemical interaction or continual movement and abrasion due to wind, the tarp took all the gloss off the the boat's finish wherever it was in contact.
I have heard similar paint damage happening due to wind acton on fabric covers when motorcycles are transported on open trailers with covers. Probably why you don't often see them with covers on when being towed that way.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 08-13-2016, 04:24 PM   #6
2016 26' Flying Cloud
Southlake , Texas
Carolina Carports
2016 Flying Cloud 26u
2017 Silverado Duramax 4x4
Equalizer Hitch
Bgibbs is offline   Reply With Quote
Old 08-13-2016, 04:45 PM   #7
Thats a nice setup. How tall and wide is your cover? Is this considered movable so I don't get hassled by code enforcement?
Old 08-14-2016, 12:27 PM   #8
2015 30' Flying Cloud
Sanford , Florida
Covers on Airstream
Other posts on this forum discuss the damage that is done due to direct contact of a cover on an Airstream. It isn't recommended due to the abrasion it causes. You might want to look up those discussions.
Tin-kerbell is offline   Reply With Quote
Old 08-14-2016, 05:02 PM   #9
2007 25' Safari
Attleboro , Massachusetts
I used a very expensive cover on the camper I had before my Airstream. It allowed the pollen through it AND it scratched the finish in many places. Now I wash my Airstream weekly but I sure would like to get a carport like BGibbs has! Or maybe a Shelter Logic portable garage. I'm interested to see what others have done.
romeb is offline   Reply With Quote
Old 08-14-2016, 08:53 PM   #10
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
Nice cover. How tall the side poles.
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D 460 watts solar, lithium 230 AH, 16" LT's, pulled by:
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 08-15-2016, 07:03 AM   #11
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Tarps and covers of that type are a bad idea and cause more damage than the protection they provide. The wind whipping the cover will rub through the clear coat.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 08-15-2016, 07:30 AM   #12
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
I know that those carport metal covers can be made to meet the codes in coastal FL. But they do have to meet code since they are required to be tied to the earth with some type of anchor or foundation. Auger anchors, a knee wall foundation, or a concrete slab can be used for anchorage.
I have seen those sized for motor homes 20' x 60'. When I got a quote on a 14'W x 40'L x 12'H a while back, if memory serves me, I think it was a little over $4,000, installed onto a foundation I provide. This was in NC.
Alan
Old 08-15-2016, 11:20 AM   #13
Southlake , Texas
My cover is 12' wide and about 10 1/2 ' tall. You can order any height you want by ordering different posts. Is it moveable? You could unbolt everything and disassemble it but it would be a lot of work. Mine is anchored to a concrete slab, but they will anchor it to soil if it is level. The city threw me a curve when they said they needed engineering drawings. The only drawings that Carolina Carports offers are for their wind rated structures, hence a couple of hundred more for the structure. Dealing with the city is always such a pleasure! We cannot build within 10' of the side property line and the city had to have a survey. "It won't cost much. We just need that one property line surveyed". Try to find a surveyor that will do a partial survey. We have over an acre and the structure is about 40' from the property line. "We still need a survey". Cheapest one I could find was $400 and most were closer to $750.
I have since partially covered 2 sides with shade cloth to keep things a little more protected. I was worried about wind, but we had 70 mile winds last week and no damage to the cover. Can't say that about a few trees!
Equalizer Hitch
Old 08-15-2016, 11:26 AM   #14
kdickinson's Avatar
Taos , New Mexico
I see the carport idea in my future also - very nice
kdickinson is offline   Reply With Quote
Old 08-15-2016, 02:44 PM   #15
64airstream's Avatar
1964 22' Safari
1968 26' Overlander
Beaver County , Pennsylvania
We also went with a carport (years ago) and ordered it wide enough that we could fit 2 Airstreams in it side by side (just in case). Our second AS is 5' longer than the first, so I wish I would have added a couple of extra feet to the length. We opted for the heavy duty frame and 9' side height. Plenty of height even with a full profile Air Conditioner.
Good hunting,
Roy and Marie
64airstream is offline   Reply With Quote
Old 08-15-2016, 03:04 PM   #16
Builder of Diesel Jeeps
westernjeep401's Avatar
2014 28' International
Sedona , Arizona
Used a cover now for two years. Despite the pundits, no damage, scratches, or the antichrist arriving ahead of schedule. No yellowed clearcoat, no abrasions, nothing except a preserved coach from the elements.
The key is a fitted cover (mine is an ADCO) a thoroughly clean and polished coach, and routine checks on the cover tension and fit. I Liquid Glass the entire coach twice a year, including the roof. The wash is Liquid Glass car wash.
It works.
14 Serenity 28'
15 Grand Cherokee EcoD
#5261
westernjeep401 is offline   Reply With Quote
Old 08-01-2017, 07:57 PM   #17
Sedona , Arizona
8/1/17:
Still using it with no issues.
14 Serenity 28'
#5261
Old 08-01-2017, 08:50 PM   #18
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
It works.
Glad to know that you're up to three years with no problems from your cover. But covers don't necessarily work for everybody. I would still put it in the "try at your own risk" category.
But for those who do want to try it and hope to get the same good results you did, could you possibly identify the make and model of your cover? With the understanding that no liability falls on you if they try the same thing and it doesn't work as well for them? After all, you don't want to be held responsible for the early arrival of the antichrist, right?
AC replacement-options, options... Belegedhel Furnaces, Heaters, Fireplaces & Air Conditioning 5 09-12-2018 08:56 AM
Propane tank cover options dekew 2002 - 2005 International 12 09-24-2017 06:38 PM
to cover or not to cover tfetterer Winterizing, Storage, Carports & Covers 8 09-16-2008 12:14 PM
To cover or not to cover vents? Director 1965 - 1969 Overlander 4 10-28-2007 07:01 PM
To cover or not to cover goldenlily Winterizing, Storage, Carports & Covers 1 10-03-2005 11:48 AM
