Old 10-04-2006, 06:11 PM   #1
bluegrass's Avatar
2007 34' Classic S/O
Buffalo , New York
Cover for Safari FB
Being new to the Airstream family, I hope this question isn't redundant. I am considering covering my 25' FB instead of wintering it in RV storage and leaving it in my driveway with the possibility of using it a few times in the winter months. Any recommendations for covers, fabrics or other related tips are welcome.
Thanks, Joseph
Buffalo, NY
bluegrass is offline   Reply With Quote
Old 10-04-2006, 06:30 PM   #2
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
Hi, the standard advice is don't use any cover that will touch the skin of the trailer. It will ultimately abrade scratches into the skin (flapping in wind etc).
maybe you could put up one of those temp canopy garages ala costco?
I recently learned that my local fair grounds rent trailer storage space in their stock barns during the winter - cheap!
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 10-04-2006, 06:38 PM   #3
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
I'll echo Janet's reponses, with added info that the Airstream's coated finish (now factory coated by Alcoa on aluminum supplied to Airstream) can easily get scratched by any of the fabric covers, and that starts process of failed clearcoat... It's actually easier on the aluminum to clean it and then let snow build up on the metal...
The Costco "tent shelters" might not hold up well in Buffalo winters, though they do OK in Calif leeping leaves and gentle rains from trailer, and primary purpose is sunshade...
Neighbors and codes probably don't allow more permanent "carport" kind of shelter, but that might protect from snow and hail and ice and sun and wind... Winterizing to prevent frozen waterline damage would seem to be required for any storage option other than heated indoor garage...
Condoluminum
Condoluminum is offline   Reply With Quote
Old 10-04-2006, 08:07 PM   #4
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
A cover on an Airstream might do more harm than good. It is not only the potential for scratching. A cover can sometimes trap moisture inside the cover.
SuEllyn & Brian McCabe
moosetags is online now   Reply With Quote
Old 10-04-2006, 08:29 PM   #5
codybear's Avatar
1964 22' Safari
SACRAMENTO , California
Images: 315
camping world sells covers!
We just got the flyer ad from Camping World..they sell these covers in all sizes for motorhomes, trailers..after reading about moisture, etc..I don't think I'd ever cover the Safari with these clothlike covers..I do like the idea of these shelters made of aluminum roofs and poles...
codybear is offline   Reply With Quote
Old 10-04-2006, 09:14 PM   #6
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
I have one of the portable 'fabric' garages to house my convertible. It is a bit more sturdy than the 'cheap' fabric garages but I still reinforced it some more. We do get an occassional snowfall at our 3000' elevation and it is 'Sierra cement' as it is called....wet. So far no real problems (I did have a cheapy completely collapse on my pick-up one year) so I raised the reinforced 'garage' for the Tradewind. Now I have to move the Camry out of the garage for the convertible. Priorities. Bottom line is nothing should touch the aluminum. If you have the space and no zoning regulations a steel canopy would be the ticket if you feel you need to cover your aluminum pet.
Neil.
Old 10-04-2006, 09:19 PM   #7
codybear's Avatar
1964 22' Safari
Images: 315
Hi Neil,
I think one of those tall aluminum roof w/poles might work for us someday..we get that hot sun beating down on the top of the Safari in the summer..don't know about regulations though, I've heard even when you put up one of those 'tuff shed' units, there are cerain size limitations and permits to be considered.
Old 10-05-2006, 12:41 AM   #8
CaddyGrn's Avatar
1963 16' Bambi
Yreka , California
I would "winter" your trailer... then when you want to use it, bring it home a day early and get it ready to go. I have no idea what kind of winter NY has... but I would think chilly! ??? You can't beat having it actually under a real roof! Second solution. Build a big garage!
Mrs. NorCal Bambi (traveling in S Tardis)
CaddyGrn is offline   Reply With Quote
Old 10-05-2006, 12:53 AM   #9
FreshAir's Avatar
1966 24' Tradewind
I put up a fabric 'portable' garage for my convertible. This year I raised it for the Tradewind. Since we sometimes get snow at our 3000' elevation I reinforced the roof some. However, you in the northeast get to much snow so you may consider a strong metal canopy but do not cover your AS with anything that touches the aluminum. My problem is now is the Camry has to come out of the garage this winter for the convertible to go in. Priorities.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
64 Globetrotter Stove Vent Cover Trotter Roof Vents, Skylights & Fans 2 12-15-2007 06:03 PM
vent cover repair.... Chuck Windows & Screens 10 11-13-2002 12:05 PM
cover for univolt maznblu Electrical - Systems, Generators, Batteries & Solar 2 09-15-2002 07:02 PM
Need Suburban Furnace Cover For 79/31' Soverign montanaandy Furnaces, Heaters, Fireplaces & Air Conditioning 0 07-29-2002 10:54 AM
Trailer Life cover 83Excella Our Community 6 06-16-2002 10:14 AM
