Old 01-09-2014, 10:00 AM   #1
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Corrosion X how to apply please
I'm in process of applying first application of corrosion X - tips and pointers - how to please - heading for FL tomorrow
PharmGeek is offline   Reply With Quote
Old 01-09-2014, 10:13 AM   #2
dznf0g's Avatar
Oswego , Illinois
I don't apply it as a preventative. I only use it to retard the very few areas of filiform corrosion I have. In that case, I dab a small amount in and around the area, rub it in well with my finger and wipe away excess. I have used it when installing bolts which attach aluminum to steel, to, hopefully, slow any galvanic corrosion.
-Rich-
Old 01-09-2014, 10:15 AM   #3
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I just spray it on a rag and wipe the edges where corrosion has started. I do it when I get ready to travel in the spring, maybe once during the season and again when winterize.
Old 01-09-2014, 10:29 AM   #4
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I have so far only some filiform on the grab handle next to door entrance - pretty common - already sprayed - I've already sprayed the seams if the entire bet line with a thin small bead of the stuff - will do all hinges as they seem more likely as handle already did - have not decided if I will do prophylactic on seams - I probably will overkill and do it - but contemplating
For seems IF I do - I could spray on rag then wipe or less penetration that way?
Old 01-09-2014, 10:32 AM   #5
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I can't wait to see your corrosion- I still don't know what it looks like-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 01-09-2014, 11:18 AM   #6
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I'll post a shot right quick in a few
Old 01-09-2014, 11:22 AM   #7
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I forget how long you leave the stuff on before wiping down ??
Old 01-12-2014, 06:25 PM   #8
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Well I applied to all seams and such - wiped excess - then next day cleaned off the rest - but still some came streaming out when I drove to canopener - I'm thinking after this I will not pretreat - kind of a pain- messy etc - but still looked good for the rally - needs a wash bad now with this residual stuff plus from the tripClick image for larger version
Name:	ImageUploadedByAirstream Forums1389576351.558052.jpg
Old 01-18-2014, 02:05 PM   #9
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Ok - so I used a couple standard autozone microfiber cloths originally to wipe down excess - then made the mistake of washing these 2 with my other 3 griots microfiber cloths - this stuff did not come out with the wash with large amount of detergent
Any idea what I can use on these towels now to dissolve this stuff
I bought a few more new towels to finish my trailer and cars today but would like to get my others back to square one
Old 01-18-2014, 02:07 PM   #10
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Name:	ImageUploadedByAirstream Forums1390079206.075328.jpg
ID:	203835got it all washed now after canopener - it was quite dirty
Old 01-18-2014, 04:10 PM   #11
m.hony's Avatar
2013 30' Classic
There is a "The Long, Long Honeymoon" YouTube video about filiform corrosion and Corrosion-X.
TAC #MS-10
Airforums #70955
Old 01-18-2014, 04:12 PM   #12
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Yeah - but no mention of how to clean a corrosion x soaked rag as I recall
Old 01-18-2014, 04:21 PM   #13
m.hony's Avatar
2013 30' Classic
So-
You've seen the video?
No mention of cleaning the rag, but got me thinking about removing the Thor sticker...
I didn't quite understand- he said he was removing the Thor sticker because the glue caused filiform corrosion, but then he put another sticker in its place. Go figure.
TAC #MS-10
Airforums #70955
Old 01-18-2014, 04:52 PM   #14
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Yeah - but pretreated with corrosionx may prevent? I think they are less concerned about those details it seems
