I would like to blow out the lines on my 2019 19' Flying Cloud. I would like to use either the Viair 400P-RV Automatic Compressor (150psi / 2.30 CFM, 33% duty cycle @ 100psi) or the Viair 450P-RV Automatic Compressor (150psi / 1.80 CFM, 100% duty cycle @ 100psi) along with the Viair RV Winterization Kit which allows me to regulate the max psi output.
The owners manual states to:
- put 50psi to the city inlet
- open all drain valves, faucets, & toilet valve
- Make sure water pump outlet is disconnected
I question having everything open all at once as it would seem difficult to create enough pressure? I would prefer to open one drain or faucet at a time and blow out each line separately, would this be the better method? If so, would I be able to have the water pump outlet disconnected or would that be a constant pressure release? Will it cause damage to blow out the lines through the city connection with the water pump still hooked up?
Lastly, which compressor of these two would work best? If doing line by line is preferred I would assume the 400 would be best with a higher CMF rate? However, if opening all the lines at once with a constant flow is preferred I would think the 450 would be better with a 100% duty cycle?
Thanks in advance for your assistance!!
