Old 07-03-2015, 05:59 PM   #1
KYAirstream's Avatar
Northeastern , Kentucky
Compressor Dehumidifier size
I'm looking at a used dehumidifier (link to specs attached) that uses a compressor and indicates it will serve 1,000 sq ft or less. Size wise it sounds fine, but the specs say it only removes 9 pints a day. I'm curious about people's thoughts on whether this would be adequate?
http://www.mcintireco.com/products/d...5%20Manual.pdf
KYAirstream is offline   Reply With Quote
Old 07-03-2015, 06:18 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
9 pints is a lot of water in a 24 hour period. I set mine in the sink and let the water drain out.
MICHAEL
Old 07-03-2015, 09:13 PM   #3
The ones at Camping World are 45 and 70 pint, so 9 sounded low to me. Maybe those numbers are exaggerated.
Old 07-03-2015, 09:28 PM   #4
AWCHIEF's Avatar
Images: 33
This is the one I have. If using the built in reservoir I would normally have to empty once a day. It is rated at 25 pints. Tank holds 6 pints. I live in a very high humidity area. I normally only use it in the winter months as the trailer is more closed up with less fresh air flow.
NewAir AD-250 25 Pint Portable Room Dehumidifier
MICHAEL
Old 07-03-2015, 10:14 PM   #5
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
We have the newair as well. One of the best extras we've purchased for our AS. No more condensation on the windows in the morning. On a really humid day it will almost fill the reservoir by running all night.
Landrum is offline   Reply With Quote
Old 07-04-2015, 02:46 AM   #6
Vintage Kin
Fort Worth , Texas
I use a 70-pint year round.
Old 07-04-2015, 08:24 AM   #7
Using a 25 or 70 pint dehumidifier, are those actually removing that much moisture per day due to using a drain hose, or is the amount still limited due to the 6 pint or so tank size?
Old 07-04-2015, 08:41 AM   #8
AWCHIEF's Avatar
Images: 33
I think those rating are based on a 100% humidity environment of a testing laboratory not the real world. If the tank is full there is a shut off valve to keep from over filling. When full it has to be emptied to resume operation. If using a drain hose it will of course continue to run. I use a dehumidifier controller that I set to shut off at 35%. Also keep in mind that a dehumidifier is basically useless in a too well ventilated trailer. As high humidity air is continuously drawn in to the trailer.
DAYTON 1UHG2 Dehumidifier Control, Plug In 120 V - Tools Products - Amazon.com
MICHAEL
Old 07-05-2015, 08:54 PM   #9
Without any ventilation, how do you keep that stale trailer smell at a minimum when not being used?
Old 07-06-2015, 10:43 AM   #10
Vintage Kin
Fort Worth , Texas
The occasional use of an ozone generator. Do a search.
I bought and sold a '76 Silver Streak and cleaned every surface over a forty plus hour full time work week. Ran the gen about 12-hrs with A/C fan on in closed trailer. Used TT a year and then let it sit in storage in this humid city for two years. Cleaned it out and kept a few windows cracked. Sold it with none of those "old" odors.
Old 07-06-2015, 12:52 PM   #11
When sitting in storage, do folks usually leave a roof top exhaust fan running? That is, assuming a rain cover is installed and plugged into electric. This of course defeats running a dehumidifier. Just wonder which is more successful to help with those "old" odors.
Heater + Dehumidifier question deauxrite Dehumidifiers & Ozone Generators 1 10-11-2009 07:31 PM
Dehumidifier Foiled Again Dehumidifiers & Ozone Generators 9 11-08-2008 11:58 AM
Dehumidifier for Bambi 19' CCD CAK 2005 and newer - Bambi all models 1 04-11-2006 06:11 PM
Dehumidifier? ipso_facto Interior Restoration Forum 0 02-09-2006 06:35 PM
Dehumidifier tincanholiday Dehumidifiers & Ozone Generators 8 09-08-2005 09:31 AM
