Old 10-19-2011, 09:32 AM   #1
Mojave's Avatar
2011 16' Sport
Tofino , British Columbia
Climates and winterizing
Just curious as to what climates require you to fully winterize. I live in a temperate rainforest that doesn't fall below freezing. I would guess at times we get the odd winter day in the high 30's low 40's F but typically we hover between 50-60 all year round.
So far we've dumped our gray/black water tank and flushed all water out with a compressor.
Thoughts/advice for a newbie?
Mojave is offline   Reply With Quote
Old 10-19-2011, 09:53 AM   #2
Plonk
, , Minnesota
Frost damage will only occur if there are sustained temperatures below 32 degrees.
Old 10-19-2011, 10:05 AM   #3
Mojave's Avatar
2011 16' Sport
Thanks Jammer!
Old 10-19-2011, 01:15 PM   #4
BEWARE of the CAT
w7ts's Avatar
2010 31' Classic
Longmont , Colorado
If it ever freezes at night, you should do at least as much as you have done already, unless you wish to gamble. If you only get a couple days notice of a freeze, then you may not have time.
I checked the climate data for Tofino, and every month from September through May has had a below freezing temperature some time in the past.
The all time low appears to be -15c occurring in January.
Check the data here: Toward bottom of page.
Tofino, British Columbia - Wikipedia, the free encyclopedia
You might want to look for things that you have left in the trailer that could freeze.
Check this thread for a lot of good info:
http://www.airforums.com/forums/f458...rize-7222.html
Ken
w7ts is offline   Reply With Quote
Old 10-19-2011, 01:45 PM   #5
Mojave's Avatar
2011 16' Sport
Thanks w7ts, I did the same and checked the web for stats (just in case). We've only lived here for a few years but been surfing here for over 10 years and have not had below freezing yet, but never say never. Knowing my luck this will be the year we'll get a rager Thanks for the heads up on that thread, I'll check it out.
We'll always do the basic flushing that we did this year but I'm more wondering about how critical it is to use antifreeze. Maybe it's just better to be safe than sorry.
Lisa
Old 10-19-2011, 02:41 PM   #6
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 59
Lisa... Granted, you live a LOT further north than we do, but it sounds like your temperatures are rather moderate. Here in SoAZ we can certainly freeze, and we regulalry flirt with freezing temps through the winter months. But we do not have long, sustained hours of below freezing temps. We heat up enough during the daylight hours to keep things unfrozen for the most part. We did have a particularly cold winter last year ... we even had a frozen pipe in our house's kitchen ceiling that burst and put us out of our home for 4 months while the extensive repairs were being made (we lived in the Bambi). It was hell, but hell made a tad better by the Bambi.
That being said, we do not winterize. We don't even empty the fresh water tank... mostly because we can manage without it by taking a few mild precautions ...besides, we camp a lot in the winter.
When we are supposed to have a freeze, we set the furnace to about 40 degrees and let it run as it needs to during the night. We open all the interior doors, drawers and closed compartments so that the heat can permeate as many of the spaces as possible. We also turn on the water heater and keep it on all night... and the last thing I do before hitting the hay is run hot water through all the pipes.
We do a lot of camping during the winter months, and we have camped in below-freezing nights (not a lot below, but below, nonetheless)...we have not had a problem. (We do disconnect the city water if we have a water hookups so the water hose doesn't burst.)
You should be OK without a total winterization if you blow out the pipes... and if your rig's storage is such that you can take a few extra precautions, it might give you added protection. I think if we lived where we had colder weather and we weren't using the Bambi regularly, we would winterize just so we wouldn't have to worry about it.
TB & Greg - Sadie Cocker & Abbey Schnauzer
AirForums #21900 . Membership Chair, 4C
Unit #3954
Inside AZBambi: AZBambi Décors
Old 10-19-2011, 03:32 PM   #7
murreywalker's Avatar
2011 23' FB Flying Cloud
Branson , Missouri
For what it's worth, the techs at JC say they do NOT use anti freeze. And that's for the units that are there
Compressed air is their methodology to winterize.
2011 23 FC FB
2010 MB GL 450
http://www.pbase.com/murreywalker
murreywalker is offline   Reply With Quote
Old 10-19-2011, 03:47 PM   #8
BEWARE of the CAT
w7ts's Avatar
2010 31' Classic
Longmont , Colorado
Lisa
I am almost afraid to say this (knock on wood), but I never put antifreeze in the lines. I just make sure that the air compressor has purged all the water out of them. I do pour about a half gallon of antifreeze down the sink and shower drains so any water in the traps will be displaced and some antifreeze will be in gray tank. What is left in the jug, I pour down the toilet for the black tank. It at least once or more a year it gets below 0F here.
Ken
Old 10-19-2011, 04:36 PM   #9
Wayne&Sam's Avatar
2007 20' Safari SE
Cuddebackville , NY
Other than adding antifreeze to the traps and a bit in the black and grey tanks, that's all I ever do. And we freeze solid for a long time.
Old 10-19-2011, 05:00 PM   #10
Mojave's Avatar
2011 16' Sport
Thanks TBRich. Your scenario makes me feel a bit better with what we've done so far, although I'm not sure we plan to do much winter camping. It probably will be in the driveway till April/May. Main reason being a big mountain lies between us and everywhere else and being fairly new to this I'm not sure I'm super confident yet with winter towing and taking on that pass in bad weather. By the way we LOVE Tucson...so beautiful.
Thanks for all the suggestions guys! You're all making this learning curve a lot easier!
Lisa
Old 10-19-2011, 08:13 PM   #11
CanoeStream's Avatar
St. Cloud , Minnesota
murreywalker, Mojave, w7ts, Wayne&Sam -- blowing out with a compressor-only is satisfactory if one is OCD enough to persist until no trace of mist shows as one cycles each outlet, hot & cold water separately. Remember the low point drain.
Flush the traps well with RV antifreeze.
Spend a tiny few $$ and pour some cheap vodka into the emptied fresh, gray & black tanks if those worry you at all (thanks 2airishuman!). Though I usually think that an inch or two of water in the bottom of these tanks can't damage them.
5 meter Langford Nahanni
CanoeStream is online now   Reply With Quote
Old 10-19-2011, 08:31 PM   #12
Mojave's Avatar
2011 16' Sport
Thanks Bob and yes good point, definitely not OCD enough to be sure (but sometimes I can be close). Also, that last suggestion is fantastic!..one shot of vodka for the Bambi, 2 shots for Lisa, and repeat!
Old 10-19-2011, 08:36 PM   #13
moderator
Ottawa , Ontario
Lisa,
Just don't forget the drain taps, the low-point drains. On our Sov, there are three under the sink (one for the FW tank, then 1 hot and 1 cold) plus two more in the rear "trunk".
Dunno if yer li'l Bambi has more than just the main three, but check: I left the back ones closed last winter and cracked a 6" piece of copper pipe that was inconveniently buried in the wall of the bathroom.
But on the plus side, I know a lot about the rear plumbing now!
Looking to sell your Airstream or buy a different one?
Or maybe you need a part or just want to sell one?
Be sure to look in at http://www.airstreamclassifieds.com
Aage is online now   Reply With Quote
Old 10-19-2011, 08:38 PM   #14
BEWARE of the CAT
w7ts's Avatar
2010 31' Classic
Longmont , Colorado
Originally Posted by CanoeStream View Post
-------------------, w7ts, ------------------blowing out with a compressor-only is satisfactory if one is OCD enough to persist until no trace of mist shows as one cycles each outlet, hot & cold water separately. Remember the low point drain.
I guess I'm OCD enough, because that is exactly what I do.
Did you just see a turnip truck drive by?
Ken
