Old 11-13-2014, 11:27 AM   #15
2013 20' Flying Cloud
Between Here and There and Nowhere , what have you got?
One thing I haven't thought of before, is to do the blowing-out of the pink stuff in the spring before adding fresh water. I would just run water at each faucet until it wasn't pink any more, but my coffee would taste like crap for a month!
openroad118 is offline   Reply With Quote
Old 11-13-2014, 11:30 AM   #16
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
1964 17' Bambi II
Laramie , Wyoming
Images: 11
I've said this before and I'll say it again. I winterize by blowing out the lines, period. When I bought our first 1999 Airstream 14 years ago I called the factory for their recommendation. They said they just blow out the lines. I said it gets real cold here in Wyoming (minus 24 degrees night before last). They said it gets real cold in Ohio also. I've never had a problem from omitting antifreeze when I winterize.
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, 2018 Toyota Highlander
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 11-20-2014, 01:31 AM   #17
Adiredneck's Avatar
2014 27' FB Classic
Vicksburg , Mississippi
Update: It was a project - I had to take out the shelf and knee wall that were connected to the closet floor to loosen and lift the floor - but I got it out. *Now* I can get to the pump intake! Just waiting on arrival of compressor, bypass valve, etc. It has been going down to mid 20s all this week - I've gone through a complete tank of LP to keep AS @ 55 degrees. By the time I get the parts to fix it this weekend the temps will be back in the mid 70s. Timing is everything - and mine sucks! ;-)
"Hot meals, cold beer, dry bed & flush toilet - everything I look for in a wilderness experience..."
Adiredneck is offline   Reply With Quote
Old 11-10-2015, 08:16 PM   #18
nickclifford's Avatar
1972 31' Sovereign
felton , California
quick question on draining water ...
Hi all, strangest thing .. my 2nd year of ownership and draining the water tank/system preparing for some Nor Cal freezes ...
last year, just opened the valves and water drained out by itself, this year have to run the water pump to push water out ! any thoughts ?
'72 Sov ..
cheers
Nick
nickclifford is offline   Reply With Quote
Old 11-10-2015, 09:25 PM   #19
Caffeinated's Avatar
2015 27' Flying Cloud
Portland , Oregon
I just winterized our 27 FB FC. I did it the same way I winterized our old sob for twenty years in Portland, with no issues. I picked up 6 gallons of antifreeze from camping world, then dumped them into my almost empty fresh water storage tank. I emptied the hot water heater using the nylon plug, then, Using the pump, I ran water through all the sinks, shower, toilet, until everything ran red. Done. Yes some of the water in the tank dilutes the antifreeze, but it's unlikely to get to 50 below where I live. Mike get get down to the mid twenties though.
Mike
Caffeinated is offline   Reply With Quote
Old 11-13-2015, 05:12 PM   #20
Originally Posted by daveswenson View Post
Here on the eastside we don't get real hard freezes. I've winterized by draining the tanks and the lines. I drain and bypass the water heater. I blow out the lines using my tire inflator. It takes a while since it isn't high pressure but I let it run until the air coming out of the taps is mostly dry. I pour some anti freeze in the tanks and traps. That's it.
It has worked well for me. If I still lived in Minnesota I'd do things differently.
Works for me in Colorado Mountains where lows get below zero. I drain the water tank also and disconnect both sides of the water pump and run it for a few seconds to run out the water.
I run one line at a time and run each repeatedly until there is nothing but air coming out. With the water tank by passed, it only takes a few seconds to build up pressure to 40 pounds even with a tire inflator. Pay particular attention to the toilet, tight clearance and little plastic parts equal freeze damage unless all the water is out. I run it five or so times until only air is coming out.
On my trailer, there is a drain in the water line near the hot water tank. I open that drain and blow out the line.
handn is offline   Reply With Quote
Old 11-13-2015, 05:25 PM   #21
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
The key is using enough air pressure and blowing enough volume of air through the system to dry it out. My dealer uses air only but he warned me that a low pressure 12 volt pump is insufficient to provide enough air volume to remove all the droplets of water that may be in the piping and can drain back to a low spot in the piping and ultimately freeze. His method opens up all the water valves at one time. After opening the valves he connects an air system that can supply 90 psi and will blow air through the trailer for about a half hour to dry it out.
If you have any doubts that the some lurking water may still be present, then use the anti-freeze as a double check to make sure that nothing is left in the system to freeze.
I'm sure in your case, you are getting the system pretty well blown out.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 11-13-2015, 08:18 PM   #22
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Our 25gal two stage compressor supplies a steady 35psi with the tank regulator set at 125psi, it usually takes about 1/2hr to dry the system.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 11-14-2015, 06:16 AM   #23
Portland , Oregon
I have not had that problem, and I'm pretty persnickety about my coffee. (I home roast my own beans).
I also run water through the system until it's clear, and I flush. My fresh water tank four or five times before using that for drinking.
Mike
Old 11-14-2015, 12:52 PM   #24
Cool ummm...... Caffeinated
Caffeinated......Have you seen the movie with the same name?
....if you love coffee, it's pretty kool. It's on Amazon Prime.
PFC
"Tahawus"
RLC
John Prine
Old 05-09-2016, 10:11 PM   #25
2016 30' Classic
Lorton , Virginia
Jack
That's the way I plan to do it. Not messing with anti-freeze and I think I will be fine. The key will be to have a nice volume of air from a GOOD air compressor.
Zybane is offline   Reply With Quote
Old 05-10-2016, 06:07 AM   #26
Thumbs up
That's the way I've done it.....EXCEPT....the only RV/AF is in the 'traps', sink & shower.
1/4 cup of Crisco in the toilet bowl to keep the flapper subtle & un-stuck.
150psi Compressor supplying a steady 35psi on a open system for 1/2hr
Don't forget to blow out the sink sprayer & shower flex line, (I remove the head.)
PFC
"Tahawus"
RLC
John Prine
Please Clarify - Tow ratings Happydays Towing, Tow Vehicles & Hitches 14 11-22-2013 04:39 AM
Would like the "why" behind one step in blowing out lines in winterization process bonginator Plumbing - Systems & Fixtures 9 10-05-2012 12:12 PM
Help clarify my polishing options JoePfznik Cleaning, Stripping & Polishing 2 01-02-2010 10:17 AM
Compressors and winterization luckydc Winterizing, Storage, Carports & Covers 7 11-28-2004 10:06 AM
Winterization Blues - Water Heater Question BrianRegan Water Heaters, Filters & Pumps 0 06-13-2004 11:36 AM
