Old 10-28-2013, 07:06 PM   #1
1991 29' Excella
Rockwood , Ontario
Charging Batteries Once a Month in Winter
Being a newbie, after the battery switch is off, and the electrical panel is all switched off, what do I have to do to charge the batteries once a month?
I think I will go this route but I want to make sure I am doing it right.
breezyway is offline   Reply With Quote
Old 10-29-2013, 06:48 AM   #2
1981 31' Excella II
New Market , Alabama
If you have a converter that won't overcharge your batteries, you can leave it on 100% of the time. I have an old Univolt and it stays on 100% of the time and the battery has never cooked in 2 yrs. My trailer also has a switch to turn off the Univolt (converter). You can turn on the converter once a month and it will charge the batteries. You can also remove the battery and leave it connected to a battery tender in the garage or something like that. If something goes wrong and the battery discharges, it will freeze so it is best to keep it charged.
Perry
Old 10-29-2013, 07:19 AM   #3
GeocamperAS's Avatar
1974 Argosy 28
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
Images: 37
I have 2 trailers and 2 boats. A total of 6 batteries. I bring them into my attached garage. A little warmer than outside. I have them all lined up. I check the fluid level in the ones i can open. If needed I top off. Then on the 1st of every month I attach my charger, set on trickle, to the 1st battery. On the 2nd I move it to battery 2. On the 3rd battery 3....etc.
In spring when I put them back in the toys, I check the fluid level again.
A couple of them are at least 5 years old and still work well.
Judging a person does not define who they are, it defines who YOU are.
GeocamperAS is offline   Reply With Quote
Old 10-29-2013, 07:46 AM   #4
2013 20' Flying Cloud
Cream Ridge , New Jersey
I used to remove all the batteries and move them to the basement where it's warmer and keep them trickle charged all winter. It became a major project. The last five years I haven't removed any batteries from anything. I just keep a maintenance charger on the A$ batteries. I got a 45W set of solar panels that I installed on the garage roof. The controller is mounted to the inside wall and a long cord reaches all the batteries in the garage. I rotate the cord once a week so all the batteries stay topped off throughout the winter. It is important to keep an eye on the electrolyte level. If you add distilled water to any battery, make sure that battery gets charged right away. I have eleven batteries in my garage and have not had any problems.
Joe Palmieri is offline   Reply With Quote
Old 10-29-2013, 08:03 AM   #5
Lily&Me's Avatar
Normal , Illinois
Ours is in storage 2 1/2 to 3 months, during which time we do not remove, store or charge batteries.
A day or two before we aree due to head south in January, we bring it home and plug it in.
Never had a problem starting it (our car also sits, unused, for several months at a time) or with adequate coach battery to run things as we move south.
Maggie
Old 10-29-2013, 08:10 AM   #6
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
The why is a battery will loose about 15% of it's charge per month just sitting there. If the battery voltage drops too low below 12v the battery's life is compromised.
Old 10-29-2013, 08:19 AM   #7
Crusty's Avatar
1992 34' Excella
I had a pair of Trojan T105 golf cart batteries that lasted 10 years because they were always kept topped up with water and connected to a smart charger.
Crusty
"If you come to a fork in the road, take it."
Lake Travis, TX
"Rancho Deluxe"
Crusty is offline   Reply With Quote
Old 10-29-2013, 09:28 AM   #8
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
GWN...Ontario=pretty cold Winters.
5-6mos storage...I would bring indoors, inspect & maintain them in comfort. Yours and the batteries. The Deltran Battery Tender or a smart charger works very well.
ID:	198936   Click image for larger version
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 10-29-2013, 11:12 AM   #9
helmsman's Avatar
1967 22' Safari
Long Beach , California
helmsman is offline   Reply With Quote
Old 10-29-2013, 11:27 AM   #10
helmsman's Avatar
1967 22' Safari
Sorry! -- Don't know why this voltage chart doesn't make it into this reply!
Trlr Battery voltage chart.docx
Old 10-29-2013, 11:36 AM   #11
2012 30' Flying Cloud
Lake St Louis , Missouri
We keep our unit in an enclosed un-heated building on our property during the winter months we aren't on the road. We plug into 30 amps the first day of the month for 8 - 12 hours. No problems so far and used this approach many years on previous 5th wheel. I check the battery water levels regularly and top off as required. So far so good.
Barry
WBCCI 11988
AirEgger is offline   Reply With Quote
