Old 08-31-2014, 10:20 AM   #1
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Question Can I run my Fan-Tastic Fans or use a Dehumdifier non-stop?
Seems like a silly question. I have a 60 x 14 enclosed storage unit up in Pasco County here in Florida on the Gulf Coast. Since heading into the winter months it might be less of an issue.
But I'm currently repairing floor rot, and given florida's humidity, I'm wondering if it's best for me to:
  • Close the trailer entirely and use a dehumidifier or
  • Leave windows open, and run the fan-tastic fans non-stop
Anyone have any thoughts or suggestions? When the door is down, she's covered from rain and outside weather, but it is not climate controlled inside the unit.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 08-31-2014, 07:56 PM   #2
daveswenson's Avatar
2012 28' International
Issaquah , Washington
I have the same issue here in rainy Washington. I have to think it would be better to keep it closed with a dehumidifier than pulling humid air through the rig.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 08-31-2014, 08:23 PM   #3
Pat Conway's Avatar
We keep the vents closed and use "Damp Rid", a desiccant. It lasts a month or so before the pellets collecting the moisture turn to liquid and need to be replaced. Our trailer sits outside across the bay from you. The desiccant seems to do the job, no mildew or musty smells. I just mention it as an alternative to the dehumidifier.
Sun City Center, FL
1988 25' Excella
Pat Conway is offline   Reply With Quote
Old 08-31-2014, 08:34 PM   #4
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
A dehumidifier requires a drain hose for the water it removes from the air. That causes some questions to come to mind.
So do you run the unit in the shower to drain into the gray water tank?
How many gallons is it capable of removing per 24 hour period?
How big is your gray water tank?
How many days capacity does the gray tank have?
Do you have to take the trailer outside of the storage unit to drain the gray tank?
Draining the water on the storage unit floor just puts moisture back into the storage unit via water evaporation back into the air.
Round and round it goes.......
Fan Tastic Fans Gordon Watt Roof Vents, Skylights & Fans 6 02-06-2012 12:14 PM
Fan-Tastic fan install Gordon Watt Roof Vents, Skylights & Fans 28 08-15-2011 11:41 AM
Fan-tastic fans? Cedars Roof Vents, Skylights & Fans 4 06-03-2004 10:09 PM
Fan-Tastic fan??? definition needed hex Our Community 26 10-10-2002 02:17 PM
Fan-tastic Fan installation BobbyW Roof Vents, Skylights & Fans 4 06-17-2002 09:40 PM
