Old 07-26-2005, 09:29 PM   #15
Images: 14
Another garage
Our 30x50 garage has a 12 foot door and 14 foot walls. Its a steel building with skylights, 3 doors and is insulated. It has plenty of outlets including a 30 amp RV plug. Also has a 150000 btu heater.
bjond is offline   Reply With Quote
Old 07-27-2005, 03:54 AM   #16
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
The effort will be well worth it! Hope all is going well!
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 07-27-2005, 06:48 AM   #17
sovereignrwe's Avatar
1972 31' Sovereign
Oakdale , Minnesota
trying to win the prize by answering the question correctly...
Question: ...what is your height?
Answer: 6'2"
Mark
72 Sovereign: L couch, mid-twin, rear-bath
"When you come to a fork in the road, take it"
"It was impossible to get a conversation going; everybody was talking too much."
"If you don't know where you are going, you will wind up somewhere else." - Yogi Berra
sovereignrwe is offline   Reply With Quote
Old 09-09-2005, 12:42 PM   #18
Past Prez.NEU/Membership
AirHog's Avatar
2005 34' Classic
2015 Interstate Ext. Coach
N Smithfield , Rhode Island
Images: 21
Garage photos
Well folks, I have some gargage pictures to share. Check out my photo gallery!
The plywood is all done now, have to start the roof before the bad weather comes.
Gail
T & Gail
2015 Airstream Interstate Ext
2005 34'Classic- Mercury (Goddess of Travel)
2016 GMC Sierra Denali 2500HD Diesel
WBCCI #2905-NEU
AirHog is offline   Reply With Quote
Old 09-09-2005, 01:35 PM   #19
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Wow, Gail. That is some ga-rage. Great pix.
Pat
pmclemore is offline   Reply With Quote
Old 09-16-2005, 10:54 AM   #20
greg176's Avatar
Gabriola Island , British Columbia
I was looking at real estate on Gabriola Island for a possible place to live while I build there next year and came accross this.Does not include Airstream.Would keep the rain off and let in some light.
greg176 is offline   Reply With Quote
Old 09-16-2005, 11:18 AM   #21
Post We just did this earlier this year...
While building a new home, my Mother allowed us the luxury of a barn/garage that holds all the toys, including her motorhome and our A/S. Like others, we designed it to hold the largest 45-foot Airstream or Mandalay Class A if we ever went that direction. It was finished about two months ago and is really wonderful. It works perfectly. The 50-amp power is amazing to have (we have two spots for that). By the way, we also had a dump station put in... another luxury but why not.
Tom, and Frank
P.S. I can't get the design inserted here, but would email it to folks if they wanted it.
P.P.S. The barn is 46'x32', with 12 foot door that could be enlarged if needbe due to motorhome height. The center peak interior is 16'10" and at the walls it's 10'4.5".
Tom and Frank
Evanston, Illinois
2004 Safari 28 ft Slideout "Lucy" 4 HI CAMP
2004 Ford Excursion 6.0 PSD PWRSTRK,
and Brittany, the Nova Scotia Duck Tolling Retriever
PWRSTRK is offline   Reply With Quote
Old 09-16-2005, 02:46 PM   #22
My Pole Barn
I did a pole barn with a metal roof and metal roof supports that are from a portable car garage that i have made permanent.
The 4x4 posts are in concrete and the 1 1/2" round roof trusses sit inside the tops of the 4x4s and are anchored in with lag bolts.
In front is my brick pad to enter. I wanted it 'just high enough' to adaquately clear.
Sav'h Steve is offline   Reply With Quote
Old 09-16-2005, 03:01 PM   #23
OK It took a few minutes to learn how to upload a picture.
Old 02-06-2006, 04:58 PM   #24
1980 20' Caravelle
Coeur d alene , Idaho
Pole Barn
Originally Posted by Sav'h Steve
OK It took a few minutes to learn how to upload a pictur e.
I want to build a similar shelter for a 19 footer, can you give more specs on Yours? How many posts per side?, are metal panels 3x8 ? width, Length and Height? Thanks for your Time, Don
glacierrunne is offline   Reply With Quote
Old 02-06-2006, 09:37 PM   #25
Airstream25's Avatar
1995 25' Excella
1982 34' Limited
Albuquerque , New Mexico
Images: 21
Send a message via Skype™ to Airstream25
AS garage height
Originally Posted by Titu & Gail
The height of our new garage is going to be 13' to the ceiling.
For those of you who have built separate garages for you AS, what is your height?
Gail
We went the minimalist route. The height is only 10' 8" and the length only 3' more than our current AS. This pretty much garentees we will never get a bigger one :-(
We did put in 30A service however.
Airstream25
KE5CKG on 2 meters
AIR #10274
Airstream25 is offline   Reply With Quote
Old 05-14-2007, 09:03 PM   #26
janetb's Avatar
2007 25' Safari FB SE
Santa Cruz , California
Air Digs
We've finally started building the Rollertoaster its own home. As lovely as it is in all its shininess, it's great to have it away from the front entry of the house. The "hangar" is tucked back into a 3' cut on the uphill side, and off the driveway just enough to be fairly low-profile. I'm relieved because I was dreading putting another building on the property. (I've already ordered the climbing roses to cover it with..)
Dimensions are 15'Wx30Lx14'H, and the double doors will be 12'Wx10'H. It has a cat-walk on the ceiling joists above the trailer, a door adjacent to the A/S door, and vents at both ends in the gable and a couple of low vents on eacht side. Also wired for 30 amp. electrical service.
Progress so far:
ID:	37367   Click image for larger version
ID:	37369   Click image for larger version
ID:	37371   Click image for larger version
janetb is offline   Reply With Quote
Old 05-14-2007, 10:01 PM   #27
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Janet,
Nice to see things are coming along for the rollertoaster place.
I have starting thinking about mine. She will be 80X60. Room for two airplanes, two airstreams, a truck, a tractor and a car. Oh yeah a large apartment. Can't wait!
Michelle TAC MT-0
Sarah, Snowball
Old 05-14-2007, 11:03 PM   #28
janetb's Avatar
Holy Smokes, that will be one amazing hangar! So does this mean you have an eye on a 2nd trailer?
2003 Safari 25' Melvin P. Thorpe 2003 Safari 24 09-15-2007 10:53 AM
Safari VS. Classic Questions kkrogh Our Community 24 12-20-2005 11:10 AM
1977 Safari Manual RamblinRose General Interior Topics 2 04-17-2004 04:51 PM
Safari Availability JLD 1974 - 1979 Safari 4 09-12-2002 08:32 AM
Problem with electrical system (1965 safari) rslaymaker Electrical - Systems, Generators, Batteries & Solar 4 06-13-2002 05:49 PM
