Old 11-15-2015, 12:57 PM   #1
DeltaRon's Avatar
2015 28' Flying Cloud
Cumming , Georgia
Blowing pipes
Just to clarify, what's the max psi to use thru the blow-out plug? AS recommends at least 60 psi. Also, do you leave the low-points drains open and what about faucets; should they ALL be open or one at a time. We just need the process steps. Thx
DeltaRon is offline   Reply With Quote
Old 11-15-2015, 01:00 PM   #2
dznf0g's Avatar
Oswego , Illinois
I use 60psi. Fill the closed system with pressure and open faucets one at a time, starting with the furthest away from the city water inlet. Repeat twice and then open the low point drains, one at a time. Don't forget the outside shower or spigot (in my case...no shower outside but there is a spigot in the lower water compartment.)
-Rich-
Old 11-15-2015, 01:53 PM   #3
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
And don't forget the kitchen sprayer and toilet.
2012 Dodge Durango Hemi/AWD
Wayne&Sam is online now   Reply With Quote
Old 11-15-2015, 02:54 PM   #4
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I generally blow the system out and also use plumbing antifreeze!
I guess is is maybe redundant, but I have heard that when blowing the water out, it is still possible for residual amounts to pool someplace with the pipes and cause freezing problems.
I think many people only blow out the system without problems, but if there is any chance of a freezing problem, I'd just as soon do all I can to avoid it.
I have usually used about 40 psi.
The first year we had the trailer, I didn't realize there was a toilet sprayer - the previous owner had it tucked away in the back of the toilet out of sight!
Result - new sprayer and hose kit for about $45 ! Live & learn!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Wingeezer is online now   Reply With Quote
Old 11-15-2015, 03:02 PM   #5
IanPoulin's Avatar
2011 28' International
Aldie , Virginia
I use 60 psi, with low points closed to keep a closed system. start with one (I choose kitchen cold) faucet open, let the pressure in, then move in a fashion through the trailer; ala --
kitchen cold on, wait till clear
shower cold on, kitchen cold off, wait till clear
kitchen hot on, shower cold off, wait till clear
etc, etc.,
also, dont forget to hit the black water inlet line.
Ian
2011 Airstream International Serenity 28'
2016 Ford F250 Crew 4x4 KR Diesel
IanPoulin is offline   Reply With Quote
Old 11-15-2015, 03:08 PM   #6
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I use about 40 lbs pressure like Brian. [more pressure could rupture a weak spot] It's not the pressure, but the volume of air that pushes the water out of the lines. This year after a good blow out, I only put the pink stuff in the traps.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 11-15-2015, 03:10 PM   #7
IanPoulin's Avatar
Aldie , Virginia
There's a fellow in Charlottesville (colder than here) who also does that -- blows the lines out, puts the Anti-freeze only in the traps; never has had issues.
the final thing I do, only as my father passed it on, is leave the gate valves open on the black/grey tank release
Old 11-15-2015, 04:41 PM   #8
dznf0g's Avatar
Oswego , Illinois
I blow the lines and fill with AF as well. I had residual drop left in shower valve on an sob. It froze and cracked ....but I lived in Michigan then.
-Rich-
Old 11-15-2015, 07:23 PM   #9
1998 30' Excella 1000
Livingston , Texas
My 98' has a Shurflo accumulator plumbed in under the sink. It was mounted with the pressure inlet at the bottom (for easy access?) and the water in/out fittings on the top. According to Shurflo, this is not the best way to mount it:
"Can be mounted in any position. However, for complete sanitizing/winterizing, the recommended mounting position is with pre-charge valve stem up."
I presume, that if you only blow out your lines, a freeze could crack residual water below the top of the accumulator, if it is mounted with the plumbing at the top. If you have an accumulator, I advise you to check how it is mounted.
Siegmann is offline   Reply With Quote
Old 11-15-2015, 09:01 PM   #10
1974 25' Tradewind
Calgary , Alberta
The other reason is that if the pressure port is at the top, then even if the diaphragm fails, you will have air at the top and water at the bottom and the system will work as intended. If the air fitting is at the bottom and the water fittings at the top, a diaphragm rupture will let the tank fill with water and you just get a big burp of air from the tank instead of steady water pressure.
Our hydronic (pipes in concrete) basement/garage heating system has an accumulator where this happened (the rupture, not freezing). Remedy is a new tank and mounting it proper side up.
Alumineer is offline   Reply With Quote
Old 11-16-2015, 08:23 AM   #11
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
POI.....my 25gal dual stage shop compressor, set at 120psi supplies a steady 35psi with the delivery valve wide open on the gauge....the amount is just as important as the pressure.
I NEVER apply air on a closed system....at least one outlet open at all times.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 11-28-2015, 03:11 PM   #12
1969 23' Safari
Athens , Georgia
Where is the blow out point? The city water outlet?
sarasafari is offline   Reply With Quote
Old 11-28-2015, 04:02 PM   #13
2015 30' FB FC Bunk
Ayer , Massachusetts
I just blew mine out yesterday. Charged the closed system to 20-25 PSI ( less than water pressure) then opened one faucet until the pressure was gone. Repeated for each faucet.
Even on the 4th or 5th blow you could hear water gurgling albeit less and less faint.
When I received my Airstream from the factory in November, it was winterized with antifreeze. I figure that's telling me something.
Ted S. is offline   Reply With Quote
Old 11-28-2015, 04:03 PM   #14
Livingston , Texas
Returning to the Shurflo accumulator one more time, the the manufacturer indicates that more than 40 psi on the pressure side of the diaphragm/bladder could result in damage if not offset by water pressure. Seems like if you pump in 60 psi air pressure on the water side (while the system is closed) you could be risking damage.
The Pipes Froze... overlander76 Plumbing - Systems & Fixtures 18 12-08-2003 08:36 PM
First pipes now fridge... overlander76 Refrigerators 8 11-24-2003 01:46 PM
Exhaust pipes to exit left but where? Astrodokk Airstream Motorhome Forums 6 10-18-2003 08:21 AM
frozen pipes kooblekidz Airstream Motorhome Forums 4 01-20-2003 10:56 AM
Two PVC pipes? John Fresh Water Systems 11 12-06-2002 04:59 PM
