Old 11-28-2015, 04:06 PM   #15
2015 30' FB FC Bunk
Ayer , Massachusetts
Originally Posted by ROBERT CROSS View Post
POI.....my 25gal dual stage shop compressor, set at 120psi supplies a steady 35psi with the delivery valve wide open on the gauge....the amount is just as important as the pressure.
I NEVER apply air on a closed system....at least one outlet open at all times.
I agree on the volume concept, however I used my traveling air compressor to simulate how things would be winterizing on the road. I figured as long as my PSI was lower than what the system experiences when pressurized with water, I should be ok.
Ted S. is offline   Reply With Quote
The Pipes Froze... overlander76 Plumbing - Systems & Fixtures 18 12-08-2003 08:36 PM
First pipes now fridge... overlander76 Refrigerators 8 11-24-2003 01:46 PM
Exhaust pipes to exit left but where? Astrodokk Airstream Motorhome Forums 6 10-18-2003 08:21 AM
frozen pipes kooblekidz Airstream Motorhome Forums 4 01-20-2003 10:56 AM
Two PVC pipes? John Fresh Water Systems 11 12-06-2002 04:59 PM
