Old 10-21-2009, 09:24 AM   #29
clydecrashcu's Avatar
1984 31' Excella
Olsburg , Kansas
Many ideas on winterizing. I don't know if this applies to all water heaters, but I have heard that the anti-freeze is not good to use in a water heater that has the electric heating element besides the propane.
clydecrashcu is offline   Reply With Quote
Old 10-21-2009, 11:45 AM   #30
rustyrivet's Avatar
2005 22' Safari
Gresham , Oregon
I think Handn is right on with his procedure. Last year, we hired an RV professional to add a (second) battery to our Safari. He mentioned that he winterized RV's for several of the large local dealers. I ask how he did it and his procedure was precisely like the one Handn described above. He said he had done it hundreds of times and never had a problem. Keep in mind that we are in Oregon, not Maine and have milder winters. The tip about the faucet filter is also excellent. I removed ours last winter. The AS manual recommends it as a precaution. Good luck. jc
2005 22 ft Safari LS
2009 Toyota Tundra
Hensley Hitch
Lifeline AGM's
rustyrivet is offline   Reply With Quote
Old 10-21-2009, 12:11 PM   #31
rustyrivet's Avatar
2005 22' Safari
Gresham , Oregon
All liquid should have some taste. I prefer Bombay Saphire,and a touch of vermouth. Don't put the olives in. The plug the lines. jc
2009 Toyota Tundra
Hensley Hitch
Lifeline AGM's
Old 10-21-2009, 12:22 PM   #32
rustyrivet's Avatar
2005 22' Safari
Gresham , Oregon
I bought a compressor similar to CanoeStream's, just a different brand. It works great for winterizing. As far as small compressors that might work for tires and winterizing, you might want to check the Viair website. They have a number of portable compressors. Theirs will clamp on to the battery for power and have a long enough compressor hose to reach the trailer tires and the vehicle tires. I looked at a number of portable compressors (Slime, etc) before buying theirs. jc
2009 Toyota Tundra
Hensley Hitch
Lifeline AGM's
What tool to get for blowing out the lines? utahredrock Winterizing, Storage, Carports & Covers 12 03-23-2008 06:42 AM
new water lines Rob Fresh Water Systems 29 07-11-2006 08:25 PM
sterilizing water lines. Theo Fresh Water Systems 3 01-16-2004 04:33 PM
Water Lines bpaolini Fresh Water Systems 8 09-16-2003 05:43 PM
Water lines in '73 Overlander Bryan Fresh Water Systems 8 06-05-2002 11:42 PM
