Old 10-25-2015, 10:46 AM   #1
2014 23' Flying Cloud
2015 28' Flying Cloud
Kalamazoo , Michigan
Black and Grey Holding tanks
When I stored my AS, I think (fairly sure) there was a little leftover "stuff" in my two holding tanks. Now upon winterizing I'm sure some of the water from the lines added to this as well as some of the antifreeze. Should I have dumped this or do you think I'll be OK? Should I try to get to the trailer and drain these?
mwilliamsmd is offline   Reply With Quote
Old 10-25-2015, 11:49 AM   #2
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Any leftover liquid is probably resting next to the black and grey shutoff valves just below the edge of the trailer. That's the low point in the system. I suppose if it freezes, expansion could break the plastic plumbing that houses the valves.
Would it be easy to take a bucket, open the cap and valves to drain out anything there? I think any small amount of stuff inside the tanks themselves would have plenty of room for expansion inside the tanks and be harmless.
Doug and Cheryl
Old 10-25-2015, 11:52 AM   #3
65CV's Avatar
Western , Massachusetts
Or, at the very least, dump a couple gallons of antifreeze so that you don't get a hard freeze in the lines. Unless you're sure you used a lot more antifreeze than leftover water, you sound vulnerable to damage.
65CV is offline   Reply With Quote
Old 10-25-2015, 12:24 PM   #4
Not sure how much antifreeze got through?? 1/4-1/2 gallon?
Old 10-25-2015, 01:38 PM   #5
65CV's Avatar
If -- by "a little leftover stuff" -- you mean a couple of pints, you should have no trouble if you add a couple of gallons of antifreeze to each holding tank. If you haven't added to each trap in the system, now is a good time do so.
If I weren't sure that I had well under a gallon of leftover "stuff", I'd dump. I can't think of a worse place to have a crack in the plumbing!
Old 10-30-2015, 11:06 AM   #6
Went to the storage facility today. Put more antifreeze down each drain. Emptied the holding tanks. Hope I'm good for the winter???
Old 10-30-2015, 11:12 AM   #7
Long Island , New York
If the rest of your winterization was done correctly, IMO you are good to go . . .
The "GEO System" Balck and Grey tank holding tanks adonh Waste Systems, Tanks & Totes 1 05-06-2013 12:05 PM
Why aren't the grey and black holding tanks one? Kistler Waste Systems, Tanks & Totes 26 06-02-2004 03:41 PM
How to get at Black and Grey tanks... xtrm69 Our Community 7 01-30-2003 05:28 AM
