Old 06-17-2015, 04:48 PM   #15
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
carl2591,
The height with ac on a 2004 according to my manual is 9'-7.5".
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 06-17-2015, 05:57 PM   #16
larry b's Avatar
1975 31' Sovereign
howell , Michigan
I went with a 18' wide X 30' deep 10'high , park the AS tight on right hand side and park the F250 tight on the left side, this allows enough room to open the AS door. It is tight but it works, I beleive with the pitch of the roof a 8' tall side wall would also work without issue.
larry b is offline   Reply With Quote
Old 06-17-2015, 06:48 PM   #17
JaynEss's Avatar
1994 21' Sovereign
The high country. Black Mountain range. , North Carolina
Our solution. Vertical roof for snow. 12 gauge, certified with 10 foot legs. Arbor anchors.
WBCCI 28499
"Not all those who wander are lost"
J.R.R. Tolkien
JaynEss is offline   Reply With Quote
Old 06-17-2015, 10:14 PM   #18
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
very nice indeed.
now if you could hitch the boat behind the AS that would be the real deal
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 06-18-2015, 05:49 AM   #19
JaynEss's Avatar
1994 21' Sovereign
Originally Posted by carl2591 View Post
very nice indeed.
Thanks, and you are correct. However, I do have the canoe loaded on the TV.
WBCCI 28499
J.R.R. Tolkien
Old 06-18-2015, 08:49 PM   #20
Denis4x4's Avatar
Durango , Colorado
My Airstream "hanger" (see post #9) is 18' wide, 30' long and the opening is 12' tall. AS is a Safari FB 25'.
If you don't go first class, your heirs will!
Denis4x4 is offline   Reply With Quote
Old 06-18-2015, 09:21 PM   #21
1988 Argosy 32
Lomita , California
I find that 6-8 Feet all around lets me work on it nicely, 4 Ft above tallest roof bump.
add sides to stop sun burn or wind driven hail.
Wolfe is offline   Reply With Quote
Old 06-19-2015, 04:19 AM   #22
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Not sure where you are located but be sure that it is rated for the snow load for your area. I saw several this spring here in Michigan that were collapsed from the winters fury.
Dingo Girl is offline   Reply With Quote
Old 06-19-2015, 05:18 AM   #23
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by az-streamer View Post
As a side question to the carport size, has anyone dealt with carport.com or any other large shelter supplier? I am also looking to have a good shelter for our AS and it would be interesting to get opinions on who is good.
What you want is a "pre-engineered" building (maybe one without walls, but it's still a building), so check the Yellow Pages for suppliers in your area, and ask them for references in your area, so you can go check out other carports/garages they've supplied. If you just buy a kit that has not been designed for wind and snow loads in your area, you're really not saving money. That phrase "in your area" seems to be a recurring theme, but it's a valid one. Also, be prepared to put down an adequate foundation to support it; resistance to uplift forces from wind depends in part on how the building is fastened to the ground. One reason for going with a pre-engineered building is that you can get them to design the right foundation as well.
Side note, wall and roof panels tend to be standardized at 3 feet wide, so if the dimensions work out to an even multiple of 3 feet it will cost less than if you go with other sizes where some panels might have to be cut lengthwise to fit.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
I need advice on proper size metal carport type structure 31 ft AS AustinAir 1970 - 1973 Sovereign 1 05-29-2015 07:59 AM
Type 3 Glass Bar in a Type 2 Hinge rasmuw Windows & Screens 0 12-09-2013 10:18 PM
Vinyl carport blues Stefrobrts Our Community 2 12-18-2005 01:53 PM
What Type of Restoration is Your Type? ankornuta General Repair Forum 16 11-21-2005 04:13 PM
Tow bar receiver type or ball type? Astrodokk Airstream Motorhome Forums 2 06-09-2004 07:20 PM
