Old 08-17-2015, 03:03 PM   #1
DeltaRon's Avatar
2015 28' Flying Cloud
2018 33' Classic
Cumming , Georgia
AS cover
I know covers are not recommended but is there one that will not wreck the clear coat?
DeltaRon is offline   Reply With Quote
Old 11-26-2015, 06:58 AM   #2
la nomade's Avatar
2018 22' Sport
Airstream Coach - Other
ancramdale , New York
cover
did you find one ????
la nomade is offline   Reply With Quote
Old 11-26-2015, 10:31 AM   #3
mapleton , Utah
It's not usually the cover fabric that is the problem. The wind deposits a layer of dust under the cover no matter how tight you try to keep it then the wind moves the cover around and the dust becomes an abrasive- think sandpaper-
if you must cover try to get a freestanding framed cover that doesnt touch the aluminum.
tim
rumrunner is offline   Reply With Quote
Old 11-26-2015, 11:08 AM   #4
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Where are the inventors. There is waiting market for the guy who comes up with a standoff system that will keep a cover a few inches off the shell and stand up to heavy wind, and will not damage the shell if it does fail. It probably would not have to enclose the entire Airstream, maybe the upper third.
Doug and Cheryl
Old 11-26-2015, 01:14 PM   #5
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
I don't think that anyone will recommend a cover that actually touches the trailer's surface. As for a system that keeps the cover away from the surface of the trailer, make sure that there is sufficient support to deal with weight from snow or rain that may pool on the horizontal surfaces. I've seen some people use what amounts to a "hoop house" with some success.
Bob Martel
WBCCI# 5766
Old 11-26-2015, 07:39 PM   #6
DoublTrouble's Avatar
2017 25' International
Carlsbad , California
Too bad we can't make an inflatable cover.....
DoublTrouble is offline   Reply With Quote
Old 11-26-2015, 07:45 PM   #7
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
They do, Click image for larger version
Name:	ImageUploadedByAirstream Forums1448592301.648836.jpg
MICHAEL
Old 11-26-2015, 10:13 PM   #8
Chief, that's exactly what I'm talking about. However, that doesn't really exist, does it?
Does it come with solar-powered blower?
Old 11-27-2015, 06:50 AM   #9
AWCHIEF's Avatar
Images: 33
Yes, Google "inflatable garage". Sorry, can not do all the work for you.
MICHAEL
Old 11-27-2015, 07:57 AM   #10
"Cloudsplitter"
Question
Originally Posted by AWCHIEF View Post
Will it support?...and how well will the fan work during a power outage, if wet, buried in snow?
How tempting on .....Poooof All Hallows' Eve.
Old 11-27-2015, 09:12 AM   #11
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
My son left his car at "Twenty-nine stumps" while on deployment somewhere. He wanted to "save" the car paint.
Usual "prep"of fuel, oil, removed battey, removed tires, car in jackstands.. etc...
So, I suggested a "pre-wrap" before placing the "car cover".
It worked for him.
Oh, I suggested one of those big rolls of "stretch plastic" like they use for bundling several small boxes on a pallet for shipping. It resembles "Saran" wrap. The rolls are about 3' long. As you "roll" it out, you pull to stretch... Just a bit.. The car was clean, dry, fresh wax job.. He placed thin shipping blankets first for some "breathing" room as he rolled on the WRAP... He started on sides then did the top. He finished with a overall wrap. He also removed the wheels and plastic wrapped and stored them.
Next came the "car cover". It was a tight fit due to the extra material...
Result? Looked just like he left it upon return... 2 hours work to get things running... New battey, oil change, tires, etc.
For an AS, should work.. Talk to a boat yard.. They " prep" boats for storage with a heat shrink plastic wrap all the time in "winter areas"... Or, check YouTube.
Remember.."wrap that rascal"!!!!
Peace and Blessings..
Channing
WBCCI# 30676
Old 11-28-2015, 06:59 AM   #12
la nomade's Avatar
2018 22' Sport
O.K.....the answer really is to go south!!!!
Hopefully the winter will not be too bad....no cover is the strong
general opinion,thanks for the input..i will just ,with a soft brush,push the snow of the roof...maybe even tilt the trailer slightly towards the back so rain water runs of ???
Old 11-28-2015, 07:24 AM   #13
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
An option I never see considered is the most common solution used by boaters.
I live next to the ocean, every boat gets taken from the water at the end of the season and typically heat shrink wrapped for the winter.
Every new boat arrives from the manufacturer shrink wrapped, even multi-million dollar ocean going yachts.
If it is good enough not to damage the gel coat on a high dollar yacht, why not an Airstream?
There are mobile companies doing it as service, or you can buy a kit to do-it-yourself, for example.
martin300662 is offline   Reply With Quote
Old 11-28-2015, 08:03 AM   #14
Mantua , Ohio
Now that's neat! Seems it would work anywhere in any climate.
Old 11-28-2015, 10:46 AM   #15
"Cloudsplitter"
Question
AS clear is NOT fiberglass/composite gelcoat. Gel is much thicker & is formulated to be immersed in water and resist scratches.
Old 11-28-2015, 11:09 AM   #16
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Sure, and every boat is design to 'get wet', doesn't mean they don't need wrapping in the winter?
Old 11-28-2015, 11:44 AM   #17
AWCHIEF's Avatar
Images: 33
And just like Airstreams only wet on the outside.😜
MICHAEL
Old 11-28-2015, 01:20 PM   #18
"Cloudsplitter"
Wink .......never said they didn't.
Our little boat stays all Summer with it's 'garage cover' flapping in the breeze without a mark.....wonder why?
I've scratched the AS by getting too close to a twig.
AS's do not get wet on the inside?.....
Old 11-29-2015, 10:10 AM   #19
la nomade's Avatar
2018 22' Sport
that is fantastic!!!but at what cost???i like to air out the A.S.when sunny weather..need access to the door,and...need to know i can leave south at any time during jan febr...thank you...great idea..M
Old 11-29-2015, 10:30 AM   #20
Keen amature
1975 20' Argosy 20
Chestfield , Kent
My local marina charges $20 per linear foot for a boat, and we paid extra to have a door installed when wrapping our boat; there maybe cheaper services around. The doors probably wouldn't work for an Airstream as they are much smaller than an Airstream door.
That said, I am considering a hybrid, a hoop frame big enough to drive into, which is then wrapped, that could have a heat shrink door to allow access.
To cover or not to cover? steveirving Winterizing, Storage, Carports & Covers 9 07-28-2014 07:31 PM
to cover or not to cover tfetterer Winterizing, Storage, Carports & Covers 8 09-16-2008 12:14 PM
Cover or not to Cover? Sixty3TW4US Winterizing, Storage, Carports & Covers 7 09-16-2008 12:08 PM
To cover or not to cover vents? Director 1965 - 1969 Overlander 4 10-28-2007 07:01 PM
To cover or not to cover goldenlily Winterizing, Storage, Carports & Covers 1 10-03-2005 11:48 AM
