Old 04-22-2006, 01:14 PM   #29
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
Originally Posted by Jim & Susan
2Air, thanks for the suggestions. Now, I wonder where I can get some acetic acid......Google should help with that. I'm a bit weary about cutting new holes, but that may be what it comes down to. Again, thanks for the info.
Acetic acid = household vinegar
David
TAC # TX-18
AIR # 410
http://www.flickr.com/photos/dsphotoscapes
dscluchfc is offline   Reply With Quote
Old 04-22-2006, 08:00 PM   #30
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
HEY, wait a dang minute. So, First I put in the baking soda, then the vinegar? I think 2Air is pulling my leg. Maybe I'd better rethink this.......
www.nesa.org
Air No. 6427
Old 04-22-2006, 10:54 PM   #31
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
after bleaching.....think about what happens when you mix baking soda dissolved in water with vinegar.......
or just try it on a smalltime basis in a glass on the counter.....
David
TAC # TX-18
AIR # 410
Old 04-23-2006, 04:44 PM   #32
1976 25' Caravanner
Campton , New Hampshire
After chlorinating , skip the baking soda , put in a gal of white vinigar and fill the fresh water tank . Turn the pump on and run through all the water lines . Empty tank and rinse with fresh water , also through the lines , 2 more times. You can use the baking soda during the season to freshen the system if you like. I lived with that foul taste almost a whole season till I tried this.
ticki2 is offline   Reply With Quote
Old 04-23-2006, 04:55 PM   #33
1972 21' Globetrotter
nc , North Carolina
i have never used that stuff in my lines, just the drains. always used air to blow out the lines. and always took pump lose to make sure no water is in it.
rock60 is offline   Reply With Quote
Old 04-24-2006, 06:02 PM   #34
_
hey jim
the baking soda suggestion didn't come from me......
yes you will make a CO2 bomb with that combo... ....not a good thing.
i am not a fan of using baking soda in the water system.......
the amount required for actual benefit would be measured in pounds....
small amounts do little except add sodium to your water supply......
since so many of us over 40 types have hypertension, extra sodium is not wise.
sodium bicarb also raises the pH of the water supply....again not wise.
getting it out of the tank is an issue..........and may require 3-4 full tank flushings.....or it will greatly reduce any inline filter lifespan...
now back to your situation......
you are trying to clean an old scumy/scaling tank?
and trying to remove scum/scale from the tank wall.....
baking soda will do nothing to help with this process either....
neither will chlorine....unless its algae or bacteria growth....
although once the tank is clean....sanitizing with bleach would be useful.
vinegar is 5% acetic acid and usually sufficient for removing mineral scale from the tank wall....3 gallons from walmart......6-8$ or so...
higher concentration acetic acid can be purchased at chemical supply shops but really white vinegar is ok...just don't dilute it anymore....use a recirculation pump/jug and just keep spraying the vinegar on the areas in question....
good luck
2air'
Old 04-24-2006, 08:56 PM   #35
Got gandkids?
Ah ha, thanks, 2air. I'll try the straight stuff. You realize, of course, I was only poking fun, right? Since we don't do politics here any longer, I wouldn't dare "flame" anybody. You guys have too much information that I need (and respect).
Thanks again for the tips. I'll let you know how it turns out.
www.nesa.org
Air No. 6427
Water heater, Engine antifreeze? shadejo General Motorhome Topics 3 08-28-2005 09:30 PM
No Anti-freeze smily Plumbing - Systems & Fixtures 8 04-15-2003 11:11 AM
Freezing RV Antifreeze Raptorrider2001 Winterizing, Storage, Carports & Covers 1 01-13-2003 01:33 PM
RV Antifreeze Quality jcanavera Winterizing, Storage, Carports & Covers 8 11-27-2002 03:32 PM
Can I use "regular" antifreeze in my holding tank? Luckydog Airstream Motorhome Forums 6 11-25-2002 07:01 AM
