Old 11-11-2017, 12:49 PM   #1
Kensington , Maryland
Antifreeze / pump question
Faucets, low point, fresh water valves all closed...everything closed.
Camco winterizing three way valve installed...I pumped 1 gallon of AF until the system reached pressure and the pump shut off...went around to all the faucets but seemed like I needed more AF so went to pump one more gallon.
The issue is that the pump quit drawing AF. Hmmm.
Out of suspicion I broke the both low points open a crack and there was alot of back pressure.
Still, I could not get the pump to draw.
What am I missing?
2017 25' FC FB "Buck"
Too tall is offline   Reply With Quote
Old 11-11-2017, 12:56 PM   #2
2012 19' International
Southeastern MI , Michigan
Make sure the Camco fittings are tight. Mine were loose and it was sucking air.
Countryboy59 is offline   Reply With Quote
Old 11-11-2017, 01:39 PM   #3
Good call. I'll double check.
Old 12-04-2017, 04:17 PM   #4
2016 23' Flying Cloud
2010 19' Flying Cloud
Tulsa , Oklahoma
Just checking to see if problem solved......went through the same thing this afternoon trying to winterize my 2016 23FB and got through about 3/4 gallon of antifreeze when it quit being pumped thru system.....never did get any pink stuff to come out of faucets....
BulldogX5 is offline   Reply With Quote
Old 12-04-2017, 04:28 PM   #5
2016 23' International
Salem , Oregon
Use an air compressor to blow out the lines and you will be fine. Add antifreeze to all traps. Dave
NoResults is offline   Reply With Quote
Old 12-04-2017, 05:00 PM   #6
2018 27' International
Somewhere it snows , Ohio
Happened to me too. The swivel on the Camco clear hose really needs to be tightened past the point you would think it would break until it seats and quits sucking air. Poor design. I will replace with a non-swivel barb connector next year - when I remember... on an unexpectedly cold evening ... when the stores are closed.... Well, maybe I will change it over this summer
Airdream99 is offline   Reply With Quote
Old 12-04-2017, 06:36 PM   #7
Thanks for the bump Bulldog. Yep, the forum prevailed. All it needed was some pipe dope on the threads and it sucks anti-freeze like a champ.
Old 12-17-2017, 11:50 PM   #8
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, this is exactly how I do it.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
How to pump antifreeze in the lines with a 22 FB? Mario Simard Winterizing, Storage, Carports & Covers 29 10-09-2017 11:40 AM
Pump in RV Antifreeze Downstream from the Water Pump? KJRitchie Winterizing, Storage, Carports & Covers 6 01-09-2015 01:18 PM
Antifreeze through pump- how to.. crazylev Winterizing, Storage, Carports & Covers 20 01-22-2014 12:31 PM
Pump antifreeze sylvan Winter Living 5 12-06-2012 11:08 AM
Antifreeze question jcf48 Winterizing, Storage, Carports & Covers 15 11-01-2006 07:32 AM
