Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Winterizing, Storage, Carports & Covers
Old 11-02-2002, 09:15 AM   #1
Earl
Profile:
Question Airstream Height
Does anyone know the height of a 32' 1984 Excella including air conditioner? I am raising the roof of my shed so I can park the Airstream out of the sun. I tried to get a dimension but it is hard to do accurately by myself with a short ladder.
Earl
Earl is offline   Reply With Quote
Old 11-02-2002, 12:24 PM   #2
53flyingcloud
53flyingcloud's Avatar
Profile:  1984 29' Sovereign
1964 19' Globetrotter
1953 21' Flying Cloud
Amherst , New Hampshire
Lightbulb Simple
EARL,
You can use basic Trigonometry.
For example:
You'll need the distance to the Airstreaml, and the angle of inclination of the top of the A/S. Then you'll use a trig ratio to help calculate the Airstream's height.
The first step is to carefully measure the distance to the bottom of the Airstreaml from a selected location.
Say for example, You measured a distance of exactly 10 m.
The next step is to measure the angle of inclination to the top of the Airstream's A/C. This can be done using a device called a clinometer.
Let's say that, You did the angle measurement several times, and found an average value of 24 degrees.
Here is our diagram.
You will note that you had a small problem. The measurements were taken above ground level, so your triangle is actually elevated by the height of the measuring instrument.
This means you'll also have to measure that height, and add it to your final answer.
Here's the diagram of the triangle you'll be using to solve for x. The names of the sides are marked on the triangle.
Because you're using opposite and adjacent, the trig ratio needed will be opposite over adjacent, or tan.
AIR 807
53flyingcloud is online now   Reply With Quote
Old 11-02-2002, 12:32 PM   #3
53flyingcloud
part 2
this continues:
AIR 807
Old 11-02-2002, 12:34 PM   #4
53flyingcloud
part3
this continues
AIR 807
Old 11-02-2002, 12:37 PM   #5
53flyingcloud
Final
Here is the calculation.
Because all 24° right triangles are similar, the ratios of their sides are always the same. So your calculator can provide the value for what the tan24 ratio is supposed to be.
By rearranging and solving, you can determine the correct value for x to make the side ratio equal to tan24.
Now you need to add on the height of the measuring instrument (and the triangle) above the ground. That value was 1.20 m.
So the height of the Airstream A/C in this example works out to 5.65 m.
ciao
AIR 807
Old 11-02-2002, 12:38 PM   #6
RoadKingMoe
RoadKingMoe's Avatar
Profile:  2001 34' Limited
Beavercreek , Ohio
You find a straight 2X4 (sometimes I believe that's an oxymoron these days) or some other straight object (an 8' flourescent tube is VERY straight but you have to be careful with it) and tape your level to it. Get up on a step ladder and lay the opposite end of the 2X4 on top of the air-conditioner. Get your end of the 2X4 level and have someone measure from the bottom of the 2X4, while you have it level, to the ground.
Maurice
AB8XA
WBCCI 5446
The Long, LONG Trailer
Old 11-02-2002, 01:29 PM   #7
hex
hex's Avatar
Profile:
Lightbulb Pi squared to the ninth:infinity
Wow Vern I think I'm impressed. But actually I'm not smart enough to know if I should be! I may have to re-think my position on guys who say ciao!
You may be just the man to solve another Airstream problem I have.
I'll have to take some measurements at my place upstate first.
But let me give you a little background and you tell me what data you'd need. (If your interested).
If I give you the pitch/slope (rise : run) of my driveway apron between two grades (street and driveway), and the distance from center rear axle to the outside bottom edge of bumper. I guess the tire sizes might be needed and maybe the height of trailer from ground to ??belly or bumper bottom??
Armed with these facts I hope to ascertain what approach angle would result in the least tail-smack when backing-in or going-out with the the trailer. I suppose there is a point when the trailer tires would be hanging in the air on some approaches (not mine) depending on hitch heigth? That would probably destroy the trailer?
Am I dreaming? My worst nightmare is that I can't park it there. I do not want to slide it up the apron and place unknown stress on the tail end, what with tail-sag concerns etc.
BTW weren't you Flying Cloud something the other day? And Towner before that?
hex is offline   Reply With Quote
Old 11-02-2002, 02:24 PM   #8
53flyingcloud
Lightbulb do a'lil work
HEX,
Check profile...
ciao
BTW, I was the original 'ciao' on here as far as I know...
ciao
Old 11-02-2002, 09:02 PM   #9
hex
hex's Avatar
Profile:
Talking Did Sybil own an Airstream too?
OK profiles checked. Now I'm really seeing double. Guess you two are passing on my calculation request. I'll wait for your next personna.
Hope both of you vote for Sunnunu!
Old 11-03-2002, 12:44 AM   #10
53flyingcloud
Exclamation Hi Rise
HEX
Times aflying..But, it's spelled "Sununu, not Sunnunu" and, yes we're planning on casting a vote. After all, it's our duty~!
Now for your project..lol, there's more to it than that.
I have the same exact driveway except, it's gravel. No matter what I do it scraps the bottom everytime. (that's why we have skid pad builted onto the rear of the frame) The main problem is this.
As the rear-end of the A/S goes up the driveway, the wheels of the Burb is still flat on the road surface. This puts the A/S at an angle in contrast with the Burb. I've spend lots of money resurfacing the angle of driveway, etc. But, until the A/S and, the Burb are both on the driveway at the same time..(nearly the same angle) it just wants to dig in. I've thought abt adding skid wheels to the rear of A/S but, was strongly advised against this by the design engineers at A/S factory.
The one thing that might work and, I've yet to try this out is:
Lowering the front of the tongue of the A/S, thereby causing the rear to be elevated. This might work. As my unit is now in Virginia Beach, I haven't as of yet had the chance to try it.
I'm sharing with you some of my frustrations in hopes that it may shed some light on what you'll be facing.
ciao
BTW: When are you getting your A/S?
Old 11-03-2002, 04:47 PM   #11
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
Height
Earl,
My 71 Tradewind is 9ft8in to the top of the A/C. Never mind the calculations - you want some extra room for pulling under thr roof anyways.
Throw a 2x4 over the A/C, like RKM suggested, and give it a few extra inches
, and you should be fine. I would check and ake sure the A/C really is the highest point, and that ther eis no antenna or other device sticking up.
Good luck!
Uwe
Old 11-15-2002, 09:05 PM   #12
gimmejul
Profile:
The book that came with my 1985 32' Excella says the height is 115.5 inches.
gimmejul is offline   Reply With Quote
Old 11-16-2002, 05:34 PM   #13
ALANSD
GA Airstreamer Air_005
Profile:  North , Georgia
I didn't know I should be carrying an HP12C calculator in my airstream toolbox. But now I will.
I sure would like to calculate that approach and departure angle so my trailer hitvh won't scrape the driveway....or I can continue to drive across part of the lawn which seems to work.
Old 11-17-2002, 01:08 AM   #14
53flyingcloud
Exclamation Curious
ALANSD
Your info says:
1982 AIRSTREAM 280 CLASSIC MOTORHOME
Are you really a trailer in "sheep wool"??
ciao
AIR 807
airstream height Earl 1981 - 1983 Excella 1 09-01-2003 10:35 PM
airstream! airstream! airstream! 83Excella Our Community 0 03-23-2002 11:37 PM
Airstream Related List Servers Andy R Link Archive 0 02-22-2002 03:05 PM
