Old 11-17-2002, 09:19 AM   #15
NewStreamer's Avatar
Towner,
5.6 m is more than 18 feet!!!
Ron
NewStreamer is offline   Reply With Quote
Old 11-17-2002, 09:30 AM   #16
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
not a trailer , the hitch on the rear of my motorhome does occasionally drag on approacheing/departing an incline. I can usually avoid this by the angle I use.
In Helen,GA I gouged a nice piece of asphalt trying to go up a mountainous side road that had a dip before the incline started. What a mess. Didn't hurt the Airstream, only the road.
Old 11-17-2002, 11:07 AM   #17
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Lightbulb Right
NewStreamer
That's correct, I never said I was "solving" the problem but, rather showing him a method how~!!
ciao
53flyingcloud is offline   Reply With Quote
Old 02-04-2007, 07:58 PM   #18
tincantom
tincantom's Avatar
1975 25' Tradewind
Crossville , Tennessee
Exclamation Raising the roof
If the entrance to your shed is not level, take care that the angle doesn't make the rear (if elevated) or front (if below level) the high point. I saw this happen with a cover built with a slight uphill approach. The rear actually struck the rafters. Measurements of height had been from level ground and the cover built with minimal clearance. It was quite an expensive proposition to remedy this. Good luck. (just lookin' up - not being sarcastic).
tom
tincantom is offline   Reply With Quote
Old 02-04-2007, 10:55 PM   #19
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
EARL; page V-1 of my 1986 Airstream Trailer Owner's Manual indicates Height (shell) 101.3 in, Height (to closed vent) 103.0 in, Height ( vent open0 106.3 in, Height (top of tv antenna folded) 108.3 in, Height (top of air conditioner) 115.5 in. Ground cleatance 8.5 in. 7.00-15 LRD Radial (29.4 X 7.8 in at 60 psi. Pretty close to your year. Me, I'ld give myself more thanan inch or two clearance!
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 02-04-2007, 11:15 PM   #20
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
I agree with Tim, give yourself some vertical wiggle room.
Dave
Fyrzowt is offline   Reply With Quote
Old 02-05-2007, 05:27 AM   #21
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Hey doorgunner....earl posted about 4.5 years ago and hasn't posted any since then...I hope he got his shed built by now
Aaron
WBCCI #XXXX AIR #2495
Old 02-05-2007, 06:10 AM   #22
1984 31' Excella
Norfolk , Virginia
Images: 11
Airstream Height
I made my door 134 inches to allow for the slight angle up at the garage apron. The reason for the drop was to keep the water out (hopefully).
Beginner
Beginner is offline   Reply With Quote
Old 02-05-2007, 09:07 AM   #23
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
Images: 35
Thanks for keeping me honest, double A Ron!! I was recovering from the guy behind the sheet in the pouring rain half wit time show. Was not reading well as I normally do. Semper Fi
www.popasmoke.com
YETI ( 65 Quart )
Old 02-05-2007, 10:19 AM   #24
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Been there done that...more than once
Aaron
Old 02-05-2007, 01:39 PM   #25
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
The REAL test of the height of trailer plus A/C unit...
To properly check the height of the trailer with an A/C/ unit use the following:
Drive the trailer under a 13 foot clearance overpass...
Next Drive the same trailer under a 12 foot overpsss...
Continue going under lower overpasses until the A/C unit is cleanly removed from the top of the trailer...
Then note the height of the overpass... ie: 10 foot clearance...
Last take your tape measure over to the now removed A/C unit laying on the road. Measure the height of the unit shroud from the mounting flange to the top of the A/C unit.... let's say 9.5 inches...
Add the heght of trailer 10 feet and...
Add the height of A/C unit 9.5 inches...
And your total trailer with A/C unit is 10 feet 9 and a half inches. At least that is the Word on the streets! Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 03-22-2008, 08:34 PM   #26
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
(two cents worth; much later than original post)
My thinking on this is that I would want some room to both crawl and sit on the roof while under cover (out of the sun); run some lighting on the roof to shine down the sides, etc. I'd go for fifteen feet.
Airstream height Earl 1981 - 1983 Excella 1 09-01-2003 09:35 PM
airstream! airstream! airstream! 83Excella Our Community 0 03-23-2002 10:37 PM
Airstream Related List Servers Andy R Link Archive 0 02-22-2002 02:05 PM
