Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Winterizing, Storage, Carports & Covers
Old 11-06-2002, 06:25 PM   #1
Craig
Profile:
Air compressor
What size air compressor is needed to blow of the water lines for winterizing? This is my first winter, and I have a feeling the little portable 12V compressor I keep in my car won't work...
Thanks.
Craig is offline   Reply With Quote
Old 11-06-2002, 06:50 PM   #2
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
i've got an old dayton speed air, about a 30 gallon tank.
i would think one of the small to medium craftsman compressors sears sells would work fine.
the more volume (tank) the better.
john
Old 11-06-2002, 08:54 PM   #3
overlander64
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 106
Air compressor
Greetings Craig!
I took a slightly different approach to the situation. I wanted a small 120 volt unit that I could carry in the back of my tow vehicle to inflate my tires on both the trailer and tow vehicle before I left camp. It turns out that it works for all kinds of situation on the RV - - it will work for blowing out the water lines on the Airstream if you don't mind listening to the compressor motor. I chose a Sears Craftsman 1.0 horsepower unit without tank with a variable pressure control of from 20 psi to 120 psi. It cost a little over $100.00 on sale (regular price was $120) two years ago. It only weighs about five pounds and has traveled with me all over the country.
Kevin
Kevin D. Allen
AIR #827
overlander64 is online now   Reply With Quote
Old 11-07-2002, 08:28 AM   #4
Craig
Profile:
Kevin,
Sounds like a good option. What do you set the pressure at for blowing out the lines?
Craig
Old 11-07-2002, 09:21 AM   #5
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Generally when "winterizing," it is recommended that a 5 HP or more, compressor be used, so that you have an adequate volume of air. Use maximum pressure, as the water pressure regulator will accordingly reduce the pressure as well as the "pop-off" valve would come into play should the regulator fail.
Small compressors do not have adequate volume.
I am sure that some owners have been successful using a small compressor, but the rule of thumb says no.
inlandrv.com
airstreamparts.com
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
air bag air compressor dbyar Mechanics Corner - Engines, Transmission & More... 12 05-08-2004 01:58 PM
Air compressor ALANSD Airstream Motorhome Forums 15 01-02-2004 05:18 PM
Air compressor headaches. rdm General Motorhome Topics 26 07-30-2003 06:16 AM
air bag compressor zamboni Mechanics Corner - Engines, Transmission & More... 2 11-19-2002 11:38 AM
Air conditioner compressor rdm Mechanics Corner - Engines, Transmission & More... 2 05-13-2002 07:54 AM
