Old 10-02-2017, 07:39 AM   #1
2016 23' Flying Cloud
Fanwood , New Jersey
Air/Anti-freeze why we need both....
Hello,
I was thinking of upcoming winterizing (I've never done it before). I've read somewhere that some people just use compressed air to blow out the lines and don't use anti-freeze.
I didn't think much of it then, but looking at the plumbing line diagram (We have 2016FC23D), I realize there are only some sections of pipes you can remove water from by air.
https://www.airstream.com/wp-content...Parts-Book.pdf
(Page 477 shows what we got)
Also I used to wonder why do we need air if we are putting anti-freeze. But if there are back-flow protection is preventing fluid going backward, there are some sections of pipes that anti-free cannot get to.
So I've come to understand that we need both air and anti-freeze. Am I right?
Air will blow out the city water inlet line where water from the water pump does not get to, so I don't think there is benefit in putting air and open up all the faucets in the trailer. I think all you need to do is to open one faucet so that the air has place to go (otherwise, wouldn't compressed air burst the pipe?) because the rest of the lines are taken care by anti-freeze.
I'm reasonably sure that I'm correct, but I would be interested in hearing from people who have more experience with this matter.
Thanks!
Atsushi
Atsushi is offline   Reply With Quote
Old 10-02-2017, 08:14 AM   #2
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Since owning my Airstream I've always blown out the pipes using a quick connect fitting screw into the city water, but I have a small compressor. I just use about 30-40lbs of pressure. My water pump is in a spot where it would be difficult to install a antifreeze kit to pump in antifreeze so I always use air. So far so good even down to 5F since 2013. I use antifreeze in the P traps and waste holding tanks after they have be drained and flushed out. I've read some people can taste the antifreeze remnants after de-winterizing but I don't have any personal experience.
Kelvin
Old 10-02-2017, 08:24 AM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I have never used antifreeze in the freshwater system, only in the black and gray tanks and my Airstream's macerator pump. Air alone won't remove every drop of water from the freshwater system, but it doesn't need to. As long as the small remaining quantity of water cannot expand to a size larger than the pipe or tank it's in when it freezes, nothing will burst, and that's good enough.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-02-2017, 11:43 AM   #4
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
When using air and attaching the hose at the street inlet, start with the faucet farthest from the inlet. Open each faucet in turn-hot and cold and flush the toilet and operate the shower. You can also drain the hot water tank. When all done with this, open the low point drains and leave open. You will get about 99% of the water doing this.
Antifreeze in the P traps and B & G tanks and you're good.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 10-02-2017, 12:54 PM   #5
If you have an external shower, don't forget to hook it up and clear the water from the shower fixture on the side of the Airstream.
WBCCI #1105
TAC LA-4
Old 10-02-2017, 01:12 PM   #6
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
2x what bwoodtx and protagonist said. I’d add to disconnect the output line from the water pump, put a towel under it and get that bit of water too.
2012 Dodge Durango Hemi/AWD
Old 10-02-2017, 01:52 PM   #7
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
I have always simply blown out the plumbing.
Drain the fresh water tank and let the pump run dry a few minutes.
I do open the low points to let whatever water will drain out there. I then close them, bypass the water heater and attach the air line to the city water hookup.
I set the compressor regulator at 65 psi and let each faucet, commode, shower, and filtered water dispenser run until it blows only mist.
As mentioned don't forget the outdoor shower AND the black tank flush connection.
This flush connection is plumbed through a check valve that does hold enough water to freeze and break.
Drain the water heater via the external drain plug.
Add antifreeze to the traps and I have always been good.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
jdalrymple is online now   Reply With Quote
Old 10-02-2017, 02:04 PM   #8
WayneG's Avatar
1984 27' Airstream 270
Scotia , New York
Air will not help with your fresh water tank or your water heater. There are low spots that will never drain.
I do both. Blow out the system with air, then I use about 5 to 6 gallons of antifreeze to be sure the water tank, pump and hot water heater are safe. At $3 a gallon, it is cheaper than repairs.
Then I blow out the excess anti freeze and wait for spring.
PS: if you have a cartridge water filter, dont forget to pull it before antifreeze.
WayneG is online now   Reply With Quote
Old 10-02-2017, 02:42 PM   #9
Half a Rivet Short
Carlisle , Pennsylvania
[QUOTE=Atsushi;2016326]Hello,
.... I think all you need to do is to open one faucet so that the air has place to go (otherwise, wouldn't compressed air burst the pipe?) ....../QUOTE]
Hi
The pipes must withstand at least 60 PSI simply to operate with city water. Since they are actually residential plumbing, they likely are good to 120 PSI. I would not bet on the higher number, but it is a pretty good guess.
Simple answer here is to set the regulator on the compressor to something below 60 PSI.
Old 10-02-2017, 03:15 PM   #10
This is true. But water only expands by about 9% in every direction when it freezes.
A small amount of ice in the plumbing system does no harm, as long as that 9% expansion rate doesn't cause anything to bulge. A pint or two of water in a 6-gallon water heater or a 26-gallon (in my Airstream) fresh tank will do no harm even if it freezes.
There are a few places in the system where even a small amount of water could do harm, because of the presence of small moving parts. Inside a faucet, or a drain valve, or a check valve, or inside a pump. As long as compressed air clears those, a small amount of water elsewhere in the system really doesn't do any harm.
WBCCI #1105
TAC LA-4
Old 10-02-2017, 03:31 PM   #11
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Don't Leave RV Antifreeze In Plumbing Lines
Originally Posted by Atsushi View Post
Also I used to wonder why do we need air if we are putting anti-freeze. ...
So I've come to understand that we need both air and anti-freeze. ...because the rest of the lines are taken care by anti-freeze.
Atsushi
I prefer not to use the RV antifreeze in the fresh water lines as compressed air works well and I don't like the chore of flushing out the system in the spring.
However, I understand why some people would feel more secure also using the antifreeze. If you do, then consider the final step to blow out the lines with compressed air. This will take out most of the antifreeze so that you won't have the residual taste when you de-winterize next spring. If you capture the expelled antifreeze you can also use it to put into the p-traps and the black and grey water tanks.
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is online now   Reply With Quote
Old 10-02-2017, 04:20 PM   #12
richw46's Avatar
Lexington , Kentucky
We can get pretty cold sometimes. Negative temps are not unusual. I like a belt and suspenders. air and antifreeze.
I blow out the lines, including the kitchen sprayer and water lines to the water heater (before putting into bypass mode).
I rarely use the fresh water tank, although I sanitize in the spring. I leave it empty in the summer and just carry a few gallons of water for flushing and drinking if we go south for the winter. I have the connector for the pump to push antifreeze into the lines. This takes care of the pump line to the rest of the AS. The drained fresh water tank input to the pump will be empty by the time winter arrives.
In the spring, I flush the lines through the water pump using fresh water from the tank, after sanitizing it. If you don't, the residual antifreeze between the pump and first tap will be with you for a while. Don't forget the showers, inside and out. Last thing I do is to switch the bypass and fill the water heater (empty, repeat).
When all of the lines are flushed there shouldn't be any foaming or bad taste. Our results have been good, but I still buy bottled water for the coffee pot.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 10-02-2017, 06:53 PM   #13
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
I just blow mine out - don't like anti-freeze, which is not something I would choose to drink, in my water lines. Don't forget to disconnect the the water pump so it can drain out, and blow out the sink sprayer.
No WD, but a great DW!
robert claus is offline   Reply With Quote
Old 10-03-2017, 07:04 AM   #14
Before you put compressed air in the city water intake, do you close low-point drains?
I think they need to be closed otherwise the air will escape from them, right? The idea is to let the air rush out from the faucets/shower/toilet, etc.? Yes?
Atsushi
winterizing - removed water filter - will it leak anti-freeze? Pudentane Fresh Water Systems 8 02-19-2013 09:39 PM
Water Dripping From Fan During Freeze/Thaw/Freeze/Thaw Fly at Night Roof Vents, Skylights & Fans 5 12-16-2011 10:54 AM
Remove Anti-Freeze Stains In Shower DEITZ645 Sinks, Showers & Toilets 4 03-23-2008 02:32 PM
Is anti-freeze required to winterize? guy99 Winterizing, Storage, Carports & Covers 17 11-23-2006 08:34 AM
No Anti-freeze smily Plumbing - Systems & Fixtures 8 04-15-2003 11:11 AM
